Object has not attribute 'per instance state' when creating ros2 node as extension
When following: ROS 2 Python Custom OmniGraph Node — Omniverse IsaacSim latest documentation
I receive the following error:
2024-06-12 08:10:06 [580,038ms] [Error] [omni.graph.core.plugin] /World/ActionGraph/ros2_custom_python_node: [/World/ActionGraph] Assertion raised in compute - ‘OgnROS2CustomPythonNodeDatabase’ object has no attribute ‘per_instance_state’
“/home/Documents/$USER/Kit/shared/exts/omni.new.extension/omni/new/extension/ogn/nodes/OgnROS2CustomPythonNo
de.py”, line 105, in compute
state = db.per_instance_state
From the documentation and reference this seems to be an attribute belonging to the super class, so it seems odd that this issue is occurring. I don’t really have too much more to go on regarding this issue.
I followed the tutorial in a fresh scene and on IsaacSim 2023.1.1
My code for reference (in case I did something wrong)
Reference Code
# Copyright (c) 2020-2024, NVIDIA CORPORATION. All rights reserved.
# NVIDIA CORPORATION and its licensors retain all intellectual property
# and proprietary rights in and to this software, related documentation
# and any modifications thereto. Any use, reproduction, disclosure or
# distribution of this software and related documentation without an express
# license agreement from NVIDIA CORPORATION is strictly prohibited.
This is the implementation of the OGN node defined in OgnROS2CustomPythonNode.ogn
# Array or tuple values are accessed as numpy arrays so you probably need this import
import numpy
import omni
# OgnROS2CustomPythonNodeDatabase module is an autogenerated python module located in the extension and is used later on.
from omni.new.extension.ogn.OgnROS2CustomPythonNodeDatabase import OgnROS2CustomPythonNodeDatabase
import rclpy
from std_msgs.msg import Int32
# BaseResetNode class is used for resetting the node when stopping and playing
from omni.isaac.core_nodes import BaseResetNode
class OgnROS2CustomPythonNodeInternalState(BaseResetNode):
    def __init__(self):
        self.node = None
        self.numA = None
        self.numB = None
        self.subscriptionA = None
        self.subscriptionB = None
        super().__init__(initialize=False)
    def listener_callbackA(self, msg):
        self.numA = msg.data
    def listener_callbackB(self, msg):
        self.numB = msg.data
    def initialize_ros2_node(self, node_name):
        try:
            rclpy.init()
        except:
            pass
        self.node = rclpy.create_node(node_name)
        self.initialized = True
    def create_subscriberA(self, topicName):
        self.topicNameA = topicName
        self.subscriptionA = self.node.create_subscription(
            Int32,
            self.topicNameA,
            self.listener_callbackA,
            10)
    def create_subscriberB(self, topicName):
        self.topicNameB = topicName
        self.subscriptionB = self.node.create_subscription(
            Int32,
            self.topicNameB,
            self.listener_callbackB,
            10)
    # Overriding a function from BaseResetNode.
    # This is automatically called when simulation is stopped.
    # This is will also be called when the OmniGraph node is released.
    def custom_reset(self):
        if self.node:
            self.node.destroy_subscription(self.subscriptionA)
            self.node.destroy_subscription(self.subscriptionB)
            self.node.destroy_node()
        self.numA = None
        self.numB = None
        self.node = None
        self.initialized = False
        rclpy.try_shutdown()
class OgnROS2CustomPythonNode:
        A custom ros2 python node that adds number from 2 separate topics and outputs the
    sum as a OmniGraph Int
    @staticmethod
    def internal_state():
        return OgnROS2CustomPythonNodeInternalState()
    @staticmethod
    def compute(db) -> bool:
        """Compute the outputs from the current input"""
        try:
            if not state.initialized:
                state.initialize_ros2_node('custom_python_adder')
                if (state.subscriptionA == None):
                    state.create_subscriberA(db.inputs.topicInputA)
                if (state.subscriptionB == None):
                    state.create_subscriberB(db.inputs.topicInputB)
            rclpy.spin_once(state.node, timeout_sec=0.01)
            if state.numA != None and state.numB != None:
                db.outputs.sum = state.numA + state.numB
                db.outputs.execOut = omni.graph.core.ExecutionAttributeState.ENABLED
                # Set the numA and numB to None to ensure we only calculate and trigger execOut when new messages are received.
                state.numA = None
                state.numB = None
        except Exception as error:
            # If anything causes your compute to fail report the error and return False
            db.log_error(str(error))
            return False
        # Even if inputs were edge cases like empty arrays, correct outputs mean success
        return True
    @staticmethod
    def release(node):
        try:
            state = OgnROS2CustomPythonNodeDatabase.per_instance_internal_state(node)
        except Exception:
            state = None
        if state is not None:
            state.custom_reset()
Generated Database Code
"""Support for simplified access to data on nodes of type OmniNewExtensionExtension.ROS2CustomPythonNode
A custom ros2 node
import sys
import traceback
import omni.graph.core as og
import omni.graph.core._omni_graph_core as _og
import omni.graph.tools.ogn as ogn
class OgnROS2CustomPythonNodeDatabase(og.Database):
    """Helper class providing simplified access to data on nodes of type OmniNewExtensionExtension.ROS2CustomPythonNode
    Class Members:
        node: Node being evaluated
    Attribute Value Properties:
        Inputs:
            inputs.execIn
            inputs.topicInputA
            inputs.topicInputB
        Outputs:
            outputs.execOut
            outputs.sum
    # Imprint the generator and target ABI versions in the file for JIT generation
    GENERATOR_VERSION = (1, 41, 3)
    TARGET_VERSION = (2, 139, 12)
    # This is an internal object that provides per-class storage of a per-node data dictionary
    PER_NODE_DATA = {}
    # This is an internal object that describes unchanging attributes in a generic way
    # The values in this list are in no particular order, as a per-attribute tuple
    #     Name, Type, ExtendedTypeIndex, UiName, Description, Metadata,
    #     Is_Required, DefaultValue, Is_Deprecated, DeprecationMsg
    # You should not need to access any of this data directly, use the defined database interfaces
    INTERFACE = og.Database._get_interface([
        ('inputs:execIn', 'execution', 0, 'Exec In', 'Execution Input', {ogn.MetadataKeys.DEFAULT: '0'}, True, 0, False, ''),
        ('inputs:topicInputA', 'string', 0, 'Topic Input A', 'Topic Input A', {ogn.MetadataKeys.DEFAULT: '"/numberA"'}, True, "/numberA", False, ''),
        ('inputs:topicInputB', 'string', 0, 'Topic Input B', 'Topic Input B', {ogn.MetadataKeys.DEFAULT: '"/attributeB"'}, True, "/attributeB", False, ''),
        ('outputs:execOut', 'execution', 0, 'Execution Ouput', 'Execution Output', {}, True, None, False, ''),
        ('outputs:sum', 'int', 0, 'Sum', 'sum', {}, True, None, False, ''),
    @classmethod
    def _populate_role_data(cls):
        """Populate a role structure with the non-default roles on this node type"""
        role_data = super()._populate_role_data()
        role_data.inputs.execIn = og.AttributeRole.EXECUTION
        role_data.inputs.topicInputA = og.AttributeRole.TEXT
        role_data.inputs.topicInputB = og.AttributeRole.TEXT
        role_data.outputs.execOut = og.AttributeRole.EXECUTION
        return role_data
    class ValuesForInputs(og.DynamicAttributeAccess):
        LOCAL_PROPERTY_NAMES = {"execIn", "topicInputA", "topicInputB", "_setting_locked", "_batchedReadAttributes", "_batchedReadValues"}
        """Helper class that creates natural hierarchical access to input attributes"""
        def __init__(self, node: og.Node, attributes, dynamic_attributes: og.DynamicAttributeInterface):
            """Initialize simplified access for the attribute data"""
            context = node.get_graph().get_default_graph_context()
            super().__init__(context, node, attributes, dynamic_attributes)
            self._batchedReadAttributes = [self._attributes.execIn, self._attributes.topicInputA, self._attributes.topicInputB]
            self._batchedReadValues = [0, "/numberA", "/attributeB"]
        @property
        def execIn(self):
            return self._batchedReadValues[0]
        @execIn.setter
        def execIn(self, value):
            self._batchedReadValues[0] = value
        @property
        def topicInputA(self):
            return self._batchedReadValues[1]
        @topicInputA.setter
        def topicInputA(self, value):
            self._batchedReadValues[1] = value
        @property
        def topicInputB(self):
            return self._batchedReadValues[2]
        @topicInputB.setter
        def topicInputB(self, value):
            self._batchedReadValues[2] = value
        def __getattr__(self, item: str):
            if item in self.LOCAL_PROPERTY_NAMES:
                return object.__getattribute__(self, item)
            else:
                return super().__getattr__(item)
        def __setattr__(self, item: str, new_value):
                object.__setattr__(self, item, new_value)
            else:
                super().__setattr__(item, new_value)
        def _prefetch(self):
            readAttributes = self._batchedReadAttributes
            newValues = _og._prefetch_input_attributes_data(readAttributes)
            if len(readAttributes) == len(newValues):
                self._batchedReadValues = newValues
    class ValuesForOutputs(og.DynamicAttributeAccess):
        LOCAL_PROPERTY_NAMES = {"execOut", "sum", "_batchedWriteValues"}
        """Helper class that creates natural hierarchical access to output attributes"""
            self._batchedWriteValues = { }
        @property
        def execOut(self):
            value = self._batchedWriteValues.get(self._attributes.execOut)
            if value:
                return value
            else:
                data_view = og.AttributeValueHelper(self._attributes.execOut)
                return data_view.get()
        @execOut.setter
        def execOut(self, value):
            self._batchedWriteValues[self._attributes.execOut] = value
        @property
        def sum(self):
            value = self._batchedWriteValues.get(self._attributes.sum)
            if value:
                return value
            else:
                data_view = og.AttributeValueHelper(self._attributes.sum)
        @sum.setter
        def sum(self, value):
            self._batchedWriteValues[self._attributes.sum] = value
            else:
            else:
        def _commit(self):
            _og._commit_output_attributes_data(self._batchedWriteValues)
    class ValuesForState(og.DynamicAttributeAccess):
        """Helper class that creates natural hierarchical access to state attributes"""
    def __init__(self, node):
        super().__init__(node)
        dynamic_attributes = self.dynamic_attribute_data(node, og.AttributePortType.ATTRIBUTE_PORT_TYPE_INPUT)
        self.inputs = OgnROS2CustomPythonNodeDatabase.ValuesForInputs(node, self.attributes.inputs, dynamic_attributes)
        dynamic_attributes = self.dynamic_attribute_data(node, og.AttributePortType.ATTRIBUTE_PORT_TYPE_OUTPUT)
        self.outputs = OgnROS2CustomPythonNodeDatabase.ValuesForOutputs(node, self.attributes.outputs, dynamic_attributes)
        dynamic_attributes = self.dynamic_attribute_data(node, og.AttributePortType.ATTRIBUTE_PORT_TYPE_STATE)
        self.state = OgnROS2CustomPythonNodeDatabase.ValuesForState(node, self.attributes.state, dynamic_attributes)
    class abi:
        """Class defining the ABI interface for the node type"""
        @staticmethod
        def get_node_type():
            get_node_type_function = getattr(OgnROS2CustomPythonNodeDatabase.NODE_TYPE_CLASS, 'get_node_type', None)
            if callable(get_node_type_function):
                return get_node_type_function()
            return 'OmniNewExtensionExtension.ROS2CustomPythonNode'
        @staticmethod
        def compute(context, node):
            def database_valid():
                return True
            try:
                per_node_data = OgnROS2CustomPythonNodeDatabase.PER_NODE_DATA[node.node_id()]
                db = per_node_data.get('_db')
                if db is None:
                    db = OgnROS2CustomPythonNodeDatabase(node)
                    per_node_data['_db'] = db
                if not database_valid():
                    per_node_data['_db'] = None
                    return False
            except:
            try:
                compute_function = getattr(OgnROS2CustomPythonNodeDatabase.NODE_TYPE_CLASS, 'compute', None)
                if callable(compute_function) and compute_function.__code__.co_argcount > 1:
                    return compute_function(context, node)
                db.inputs._prefetch()
                db.inputs._setting_locked = True
                with og.in_compute():
                    return OgnROS2CustomPythonNodeDatabase.NODE_TYPE_CLASS.compute(db)
                stack_trace = "".join(traceback.format_tb(sys.exc_info()[2].tb_next))
                db.log_error(f'Assertion raised in compute - {error}\n{stack_trace}', add_context=False)
            finally:
                db.inputs._setting_locked = False
                db.outputs._commit()
            return False
        @staticmethod
        def initialize(context, node):
            OgnROS2CustomPythonNodeDatabase._initialize_per_node_data(node)
            initialize_function = getattr(OgnROS2CustomPythonNodeDatabase.NODE_TYPE_CLASS, 'initialize', None)
            if callable(initialize_function):
                initialize_function(context, node)
            def on_connection_or_disconnection(*args):
            node.register_on_connected_callback(on_connection_or_disconnection)
            node.register_on_disconnected_callback(on_connection_or_disconnection)
        @staticmethod
        def release(node):
            release_function = getattr(OgnROS2CustomPythonNodeDatabase.NODE_TYPE_CLASS, 'release', None)
            if callable(release_function):
                release_function(node)
            OgnROS2CustomPythonNodeDatabase._release_per_node_data(node)
        @staticmethod
        def release_instance(node, target):
            OgnROS2CustomPythonNodeDatabase._release_per_node_instance_data(node, target)
        @staticmethod
        def update_node_version(context, node, old_version, new_version):
            update_node_version_function = getattr(OgnROS2CustomPythonNodeDatabase.NODE_TYPE_CLASS, 'update_node_version', None)
            if callable(update_node_version_function):
                return update_node_version_function(context, node, old_version, new_version)
            return False
        @staticmethod
        def initialize_type(node_type):
            initialize_type_function = getattr(OgnROS2CustomPythonNodeDatabase.NODE_TYPE_CLASS, 'initialize_type', None)
            needs_initializing = True
            if callable(initialize_type_function):
                needs_initializing = initialize_type_function(node_type)
            if needs_initializing:
                node_type.set_metadata(ogn.MetadataKeys.EXTENSION, "omni.new.extension")
                node_type.set_metadata(ogn.MetadataKeys.UI_NAME, "ROS2 Custom Python Node")
                node_type.set_metadata(ogn.MetadataKeys.DESCRIPTION, "A custom ros2 node")
                node_type.set_metadata(ogn.MetadataKeys.LANGUAGE, "Python")
                OgnROS2CustomPythonNodeDatabase.INTERFACE.add_to_node_type(node_type)
        @staticmethod
        def on_connection_type_resolve(node):
            on_connection_type_resolve_function = getattr(OgnROS2CustomPythonNodeDatabase.NODE_TYPE_CLASS, 'on_connection_type_resolve', None)
            if callable(on_connection_type_resolve_function):
                on_connection_type_resolve_function(node)
    NODE_TYPE_CLASS = None
    @staticmethod
    def register(node_type_class):
        OgnROS2CustomPythonNodeDatabase.NODE_TYPE_CLASS = node_type_class
        og.register_node_type(OgnROS2CustomPythonNodeDatabase.abi, 1)
    @staticmethod
    def deregister():
        og.deregister_node_type("OmniNewExtensionExtension.ROS2CustomPythonNode")
Hello, I am also using Isaac Sim 2023.1.1 and had the same problem as you. In my case, changing state = db.per_instance_state to state = db.internal_state in the code made it work properly. I got a hint from the following link: Inference in Isaac Sim - #10 by mgussert
