Oc alarm
Hi NVIDIA,
The following warning is observed while running applications such as Jetson Inference on Jetson Nano Custom Carrier boards.
soctherm: OC ALARM 0x00000001
What does this signify? Is it undervoltage alarm or over-current alarm?
Reference manual for Tegra X1 states that there are 5 types of OC alarm.
What does each alarm signify? Could you please elaborate all the types of OC alarm?
Thanks and regards,
Karthik Rao
This is actually documented (although in some folds below in Porg documentation):
Direct link: https://developer.nvidia.com/embedded/dlc/jetson-nano-dev-kit-user-guide (look for J48)
if you put that jumper, then brick power will come alive and you will not see that warning
Thanks Bibek for your guidance
Can you explain about the 5 types of OC alarms (OC1-OC5)?
Thanks and Regards
Karthik
The OC1 & OC3 are dedicated only for Under voltage & Over Current protection, other three are not available for Nano
