Our board is experiencing a number of the following error messages.
soctherm: OC ALARM 0x00000010
OC ARARM seems to be an error that occurs when the input voltage is unstable, however I would like to know more about the error code “0x00000010”. Is this information published anywhere?
may I know what’s the scenario to reproduce this failure?
had you boosting clocks to performance mode and making all resources loaded by your own process?
Are you saying you want to know if nvpmodel is maxn or not?
However, I simply want to know what the error code (0x00000010) indicates. Is it difficult for you to share this information?
