Hello, I am using a Jetson Nano core board with a 5V 4A power supply. Previously, when running the main program, I encountered the “soctherm: OC ALARM 0x00000001” warning 1-2 times. However, now the warning occurs almost every second after startup. This issue can also cause the device to shut down. Is the cause due to an insufficient power supply or is it because the device is overheating?
Please refer to
