hello, I tried to install tensorflow for 3.2, cuda 9.0 and cudnn 7.0.5 via the following site and can report that I was able to install after multiple attempts, running commands like ‘bazel clean’ and etc.
However, when running validation test for tensorflow, there was odd behavior. First time I had to kill the process as this repeated without end:
2017-12-29 09:45:39.801035: E tensorflow/stream_executor/cuda/cuda_driver.cc:967] failed to alloc 2304 bytes on host: CUDA_ERROR_UNKNOWN
2017-12-29 09:45:39.801065: W ./tensorflow/core/common_runtime/gpu/pool_allocator.h:195] could not allocate pinned host memory of size: 2304
After this, it sort of worked but with odd warnings and results:
~$ python3
Python 3.5.2 (default, Nov 23 2017, 16:37:01)
[GCC 5.4.0 20160609] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import tensorflow as tf
>>> hello = tf.constant('hello, all')
>>> sess = tf.Session()
2017-12-29 10:21:23.017060: E tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:878] could not open file to read NUMA node: /sys/bus/pci/devices/0000:00:00.0/numa_node
Your kernel may have been built without NUMA support.
2017-12-29 10:21:23.017180: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1030] Found device 0 with properties:
name: NVIDIA Tegra X2 major: 6 minor: 2 memoryClockRate(GHz): 1.3005
pciBusID: 0000:00:00.0
totalMemory: 7.66GiB freeMemory: 144.84MiB
2017-12-29 10:21:23.017230: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1120] Creating TensorFlow device (/device:GPU:0) -> (device: 0, name: NVIDIA Tegra X2, pci bus id: 0000:00:00.0, compute capability: 6.2)
2017-12-29 10:21:23.017267: I tensorflow/core/common_runtime/gpu/gpu_device.cc:732] Could not identify NUMA node of /job:localhost/replica:0/task:0/device:GPU:0, defaulting to 0. Your kernel may not have been built with NUMA support.
>>> print(sess.run(hello))
b'hello, all'
This doesn’t make me feel very confident in the installation, so if anyone can make any sense of this and how to resolve so that tensorflow functions more normally, it would be appreciated.
Perhaps I should note that installed with bazel 5.4 python 3.5, which differ from what the site author installed with. Also, I’d rather not revert to cuda 8.0 or 3.1 for the other known successful installations.
