Omni UI WebViewWidget (accidently let old post close)
Hello, I had just recently bumped Omni UI WebViewWidget and got a response, but didnt respond in time. I wanted to expand on the use case if possible! So I am currently using Isaacsim and Cesium. My implementation has a seperate mapbox implementation that tracks the moving assets and displays an icon on a google maps style map. I wanted to be able to display this map view as a tab in the same tabs panel as “stage” and the easiest way I could think to implement this was to hopefully display the webpage in a widget (currently doing something similar, but with pyqt5 (so I cant dock the window into omniverse). Any ideas?
Unfortunately, this is something that is still in long term development. Have you seen our amazing React Web sample demos running omniverse kit directly in a browser ? That might be a better way.
