[omni.usd] Runtime Error: in _SetValueImpl at line 6068 of C:\b\w\ca6c508eae419cf8\USD\pxr\usd\usd\stage.cpp
I tried to follow the example with importing existing USD Files and give them materials. The xforms and parts are created but without material and they behave not really realistic in physical way. They are just flying around, some in a circular path, some in z direction, but none of them collide with my collider plane, so there is something wrong I guess. I also get thousand on thousand lines of error messages if I run the replicator. I will paste a small part of it and my code below.
Code:
import omni.kit.viewport.utility as vp_utils
from omni.isaac.core.utils.stage import add_reference_to_stage
from omni.isaac.core.utils.prims import create_prim, delete_prim, get_prim_at_path
from pxr import UsdShade, Gf, Sdf, Usd, UsdGeom
base_path ="omniverse://127.0.0.1/BinPicking/BinPicking/"
    # Define paths for the character, the props, the environment and the surface where the assets will be scattered in.
PROPS = base_path + "bolzen.usd"
ENVS = ''
#Materialien importieren
Materials = base_path + "materials.usd"
mat_prim_path = "/World/materials"
add_reference_to_stage(usd_path=Materials, prim_path=mat_prim_path)
#Set materials
mat = get_prim_at_path(mat_prim_path)
materials_list = []
for n in Usd.PrimRange(mat):
        if n.GetTypeName() == 'Material':
            materials_list.append(n.GetPrimPath())
rep.settings.set_stage_meters_per_unit(1)
rep.settings.set_stage_up_axis(up_axis="z")
with rep.new_layer():
    # Define randomizer function for Base assets. This randomization includes placement and rotation of the assets on the surface.
    def env_props(size=50):
        instances = rep.randomizer.instantiate(rep.utils.get_usd_files(PROPS, recursive=True), size=size, mode='scene_instance')
        with instances:
            rep.modify.pose(
                position=rep.distribution.uniform((-0.5, -0.5, 0.2), (0.5, 0.5, 0.3)),
                rotation=rep.distribution.uniform((0,-180, 0), (0, 180, 0)),
                scale = 1
            rep.physics.rigid_body()
            rep.randomizer.materials(materials=materials_list)
        return instances.node
    # Register randomization
    rep.randomizer.register(env_props)
    # Setup the static elements
    surface = rep.create.plane(
        position = (0,0,0),
        scale = 200,
        rotation = (0,0,0)
    with surface:
        rep.physics.collider()
    # Setup camera and attach it to render product
    camera = rep.create.camera(
        look_at=surface,
        position=(2,2,1)
    render_product = rep.create.render_product(camera, resolution=(1024, 1024))
    #Set Viewport
    cam = "/Replicator/Camera_Xform/Camera"
    viewport_window = vp_utils.get_active_viewport_window()
    viewport_window.viewport_api.set_active_camera(cam)
    # sphere lights for extra randomization
    def sphere_lights(num):
        lights = rep.create.light(
            light_type="Sphere",
            temperature=rep.distribution.normal(6500, 500),
            intensity=rep.distribution.normal(35000, 5000),
            position=rep.distribution.uniform((-300, -300, -300), (300, 300, 300)),
            scale=rep.distribution.uniform(50, 100),
            count=num
        return lights.node
    rep.randomizer.register(sphere_lights)
    # trigger on time
    with rep.trigger.on_time(interval= 8, num=1):
        rep.randomizer.env_props(10)
        rep.randomizer.sphere_lights(10)
        #rep.randomizer.materials(materials=materials_list)
    # Initialize and attach writer
    writer = rep.WriterRegistry.get("BasicWriter")
    writer.initialize( output_dir="_output_physics10", rgb=True,   bounding_box_2d_tight=True)
    writer.attach([render_product])
Error Messages:
2023-02-22 13:02:55 [1,793,786ms] [Error] [omni.usd] Runtime Error: in _SetValueImpl at line 6068 of C:\b\w\ca6c508eae419cf8\USD\pxr\usd\usd\stage.cpp -- Cannot set attribute value.  Failed to create attribute spec </__Master_3/part.xformOp:translate> in layer @anon:000002927518CB00:World3.usd@
2023-02-22 13:02:55 [1,793,786ms] [Warning] [omni.usd] Coding Error: in _ValidateEditPrim at line 1279 of C:\b\w\ca6c508eae419cf8\USD\pxr\usd\usd\stage.cpp -- Cannot create property spec at path </__Master_3/part>; authoring to an instancing master is not allowed.
2023-02-22 13:02:55 [1,793,786ms] [Error] [omni.usd] Runtime Error: in _SetValueImpl at line 6068 of C:\b\w\ca6c508eae419cf8\USD\pxr\usd\usd\stage.cpp -- Cannot set attribute value.  Failed to create attribute spec </__Master_3/part.xformOp:orient> in layer @anon:000002927518CB00:World3.usd@
2023-02-22 13:02:55 [1,793,786ms] [Error] [omni.usd] Runtime Error: in _SetValueImpl at line 6068 of C:\b\w\ca6c508eae419cf8\USD\pxr\usd\usd\stage.cpp -- Cannot set attribute value.  Failed to create attribute spec </__Master_3/part.physics:velocity> in layer @anon:000002927518CB00:World3.usd@
2023-02-22 13:02:55 [1,793,786ms] [Error] [omni.usd] Runtime Error: in _SetValueImpl at line 6068 of C:\b\w\ca6c508eae419cf8\USD\pxr\usd\usd\stage.cpp -- Cannot set attribute value.  Failed to create attribute spec </__Master_3/part.physics:angularVelocity> in layer @anon:000002927518CB00:World3.usd@
2023-02-22 13:02:55 [1,793,806ms] [Warning] [omni.usd] Coding Error: in _ValidateEditPrim at line 1279 of C:\b\w\ca6c508eae419cf8\USD\pxr\usd\usd\stage.cpp -- Cannot create property spec at path </__Master_2/part>; authoring to an instancing master is not allowed.
2023-02-22 13:02:55 [1,793,806ms] [Error] [omni.usd] Runtime Error: in _SetValueImpl at line 6068 of C:\b\w\ca6c508eae419cf8\USD\pxr\usd\usd\stage.cpp -- Cannot set attribute value.  Failed to create attribute spec </__Master_2/part.xformOpOrder> in layer @anon:000002927518CB00:World3.usd@
2023-02-22 13:02:55 [1,793,806ms] [Warning] [omni.usd] Coding Error: in AddXformOp at line 223 of C:\b\w\ca6c508eae419cf8\USD\pxr\usd\usdGeom\xformable.cpp -- Unable to add xform op of type TypeTransform and precision PrecisionDouble on prim at path </__Master_2/part>. opSuffix=, isInverseOp=0
2023-02-22 13:02:55 [1,793,806ms] [Error] [omni.usd] Runtime Error: in _SetValueImpl at line 6068 of C:\b\w\ca6c508eae419cf8\USD\pxr\usd\usd\stage.cpp -- Cannot set attribute value.  Failed to create attribute spec </__Master_2/part.physics:velocity> in layer @anon:000002927518CB00:World3.usd@
Seems that my import of the materials with the for-loop does not work, that’s why there are these errors. I import them with a list directly now, so the error is gone.
Another solution here is to use:
            materials_list.append(str(n.GetPrimPath()))
I did write the prim itself and not the string of the prim path, that’s why the error occured.
