Isaac Sim Version
☑ 4.5.0
☑ 4.2.0
☑ 4.1.0
Operating System
☑ Ubuntu 22.04
GPU Information
- Model: RTX 3060, 4090
- Driver Version: 535.183.01
Topic Description
Detailed Description
I have been trying to use the bundle-related functionalities in OmniGraph within Isaac Sim & Omniverse for the past few days, but I have encountered some issues.
- When using any bundle-related functionality, there is no output, and I cannot see any response in the console.
- Normally, OmniGraph node input/output ports appear in the Properties panel, but strangely, for bundle-related inputs and outputs, they do not appear at all.
- The documentation mentions bundle-related features, but there are no examples available, either in the documentation or on GitHub.
I would like to confirm whether this feature is currently supported. If so, could you provide any guidance or working examples?
Steps to Reproduce
- Create an OmniGraph node that includes bundle-related functionality.
- Connect the input and output ports.
- Try to observe the output or view properties in the Properties panel.
Error Messages
N/A – No errors appear, but there is no output either.
Screenshots or Videos
Additional Information
What I’ve Tried
- Checked the Properties panel for visible ports (none appeared for bundle-related inputs/outputs).
- Searched the documentation and GitHub repositories for relevant examples (none found).
- Tested different versions of Isaac Sim (same issue in all versions).
Related Issues
- No directly related issues found in the forum or documentation.
Additional Context
I am unsure whether this feature is still under development or if I am missing some necessary setup steps. Any clarification or example usage would be greatly appreciated.
