Is it possible to livestream Omni Isaac Gym through WebRTC client?
If yes, where can I find tutorial to set this up?
If no, will it be available in the future? I am on MacOS, so I cannot install the Omniverse Streaming Client. What solutions are available to me to livestream in this case. I am running Isaac Gym on the server in a container.
I have, but there is no information about Omni Isaac Gym.
My issue is still unresolved, any help is appreciated.
Can you clarify further about your request?
the document I linked has information about how to connect streaming client with container, and you mentioned that you have Isaac gym running in the container.
In Omni Isaac Gym, there is a way to turn livestream on as explained in this section: GitHub - NVIDIA-Omniverse/OmniIsaacGymEnvs: Reinforcement Learning Environments for Omniverse Isaac Gym
Following the README, if I run PYTHON_PATH scripts/rlgames_train.py task=Ant headless=True enable_livestream=True
, it starts Isaac Sim and then it waits. I suppose it is waiting for the livestream client to start the simulation.
However, I could not find any option to livestream using WebRTC in the config, so I suppose that the Omniverse Streaming Client is the only option available?
Is there a solution to connect with WebRTC?
I have found this related issue on the Omni Isaac Gym repo, however, the answer is quiet vague…
Thank you for your help.
hi were you able to live steam over public internet any kit application using a turnserver (coturn). even though it streams on local host and same network , i have so far been unable to get it working outside the network using coturn .
