Hi, DaneLLL
The Dmesg result is:
roborock@jetson-nano-slave:~$ dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140 (wujz@advantech) (gcc version 7.5.0 (Ubuntu/Linaro 7.5.0-3ubuntu1~18.04) ) #18 SMP PREEMPT Mon Jun 8 13:16:29 HKT 2020
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] Found tegra_fbmem: 00140000@92cb0000
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[ 0.000000] On node 0 totalpages: 1039872
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519168 pages, LIFO batch:31
[ 0.000000] Normal zone: 8136 pages used for memmap
[ 0.000000] Normal zone: 520704 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc0fefb1000 s61592 r8192 d32616 u102400
[ 0.000000] pcpu-alloc: s61592 r8192 d32616 u102400 alloc=25*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1023544
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 tegra_fbmem=0x140000@0x92cb0000 is_hdmi_initialised=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1 quiet
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 29412(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3568860K/4159488K available (15230K kernel code, 2880K rwdata, 6912K rodata, 8576K init, 611K bss, 115492K reserved, 475136K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f60000 ( 15232 KB)
[ 0.000000] .rodata : 0xffffff8008f60000 - 0xffffff8009630000 ( 6976 KB)
[ 0.000000] .init : 0xffffff8009630000 - 0xffffff8009e90000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e90000 - 0xffffff800a160008 ( 2881 KB)
[ 0.000000] .bss : 0xffffff800a160008 - 0xffffff800a1f8e3c ( 612 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] t210 clock and reset probe
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.001711] Console: colour dummy device 80x25
[ 0.001736] console [tty0] enabled
[ 0.001754] kmemleak: Kernel memory leak detector disabled
[ 0.001771] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=76800)
[ 0.001784] pid_max: default: 32768 minimum: 301
[ 0.002236] Security Framework initialized
[ 0.002462] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.002471] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.003588] ftrace: allocating 47057 entries in 184 pages
[ 0.176212] sched-energy: CPU device node has no sched-energy-costs
[ 0.176291] ASID allocator initialised with 65536 entries
[ 0.216056] tegra-id: chipid=22117.
[ 0.216069] tegra-id: opt_subrevision=0.
[ 0.216086] Tegra Speedo/IDDQ fuse revision 4
[ 0.216092] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.216096] Tegra: CPU Process ID 0, SoC Process ID 0, GPU Process ID 0
[ 0.216103] Tegra: CPU Speedo Value 2025, SoC Speedo Value 1945, GPU Speedo Value 2039
[ 0.216107] Tegra: CPU IDDQ Value 1680, SoC IDDQ Value 1976, GPU IDDQ Value 2275
[ 0.216126] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 0
[ 0.216141] DTS File Name: arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0002-p3449-0000-b00.dts
[ 0.216148] DTB Build time: Jun 9 2020 16:35:03
[ 0.265071] CPU1: Booted secondary processor [411fd071]
[ 0.296979] CPU2: Booted secondary processor [411fd071]
[ 0.328922] CPU3: Booted secondary processor [411fd071]
[ 0.329010] Brought up 4 CPUs
[ 0.329015] SMP: Total of 4 processors activated.
[ 0.329023] CPU features: detected feature: 32-bit EL0 Support
[ 0.329285] CPU: All CPU(s) started at EL2
[ 0.329302] alternatives: patching kernel code
[ 0.337455] devtmpfs: initialized
[ 0.374148] Initilizing CustomIPI irq domain
[ 0.374529] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.374549] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.385234] pinctrl core: initialized pinctrl subsystem
[ 0.385890] OS set in device tree is not L4T.
[ 0.386291] regulator-dummy: no parameters
[ 0.386572] Initializing plugin-manager
[ 0.386678] Plugin module not found
[ 0.386907] node /plugin-manager/fragement@0 match with board >=3448-0002-100
[ 0.387462] node /plugin-manager/fragment@1 match with board >=3448-0002-101
[ 0.387954] node /plugin-manager/fragment@3 match with board >=3448-0002-100
[ 0.388647] node /plugin-manager/fragement@6 match with odm-data enable-tegra-wdt
[ 0.389123] node /plugin-manager/fragement@8 match with odm-data enable-tegra-wdt
[ 0.389778] node /plugin-manager/fragement@10 match with board >=3448-0002-300
[ 0.395180] NET: Registered protocol family 16
[ 0.396501] pstore: using zlib compression
[ 0.396544] console [pstore-1] enabled
[ 0.396550] pstore: Registered ramoops as persistent store backend
[ 0.396555] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.413091] cpuidle: using governor menu
[ 0.417502] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.419138] vdso: 2 pages (1 code @ ffffff8008f67000, 1 data @ ffffff8009e94000)
[ 0.419158] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.421564] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.424157] tegra_powergate_init: DONE
[ 0.424174] DTS File Name: arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0002-p3449-0000-b00.dts
[ 0.424182] DTB Build time: Jun 9 2020 16:35:03
[ 0.426011] Tegra reboot handler registered.
[ 0.430443] iommu: Adding device tegra-carveouts to group 0
[ 0.430581] platform tegra-carveouts: domain=ffffffc0f9bd4318 allocates as[0]=ffffffc0f9bd80a8
[ 0.430935] iommu: Adding device smmu_test to group 1
[ 0.430979] platform smmu_test: domain=ffffffc0f9bd4558 allocates as[0]=ffffffc0f9bd8110
[ 0.431799] mc: mapped MMIO address: 0xffffff800802e000 -> 0x70019000
[ 0.431852] mc: mapped MMIO address: 0xffffff8008065000 -> 0x7001c000
[ 0.431905] mc: mapped MMIO address: 0xffffff8008079000 -> 0x7001d000
[ 0.431914] nv-tegra-mc 70019000.mc: No mssnvlink node
[ 0.431938] mc-err: mcerr ops are set to t21x
[ 0.441328] iommu: Adding device 70090000.xusb to group 2
[ 0.441603] iommu: Adding device 70006000.serial to group 3
[ 0.441673] platform 70006000.serial: domain=ffffffc0f94b0618 allocates as[0]=ffffffc0f9bd8178
[ 0.442091] iommu: Adding device 70006040.serial to group 4
[ 0.442361] iommu: Adding device 70006200.serial to group 5
[ 0.442586] iommu: Adding device sound to group 6
[ 0.442636] platform sound: domain=ffffffc0f94b0b58 allocates as[0]=ffffffc0f9bd81e0
[ 0.443193] iommu: Adding device 7000d400.spi to group 7
[ 0.443441] iommu: Adding device 7000d600.spi to group 8
[ 0.443769] iommu: Adding device 50000000.host1x to group 9
[ 0.444049] iommu: Adding device 54080000.vi to group 10
[ 0.444456] iommu: Adding device 54600000.isp to group 11
[ 0.444721] iommu: Adding device 54680000.isp to group 12
[ 0.445109] iommu: Adding device tegradc.0 to group 13
[ 0.445184] platform tegradc.0: domain=ffffffc0f94bd918 allocates as[0]=ffffffc0f9bd8248
[ 0.446586] platform tegradc.0: IOVA linear map 0x0000000092cb0000(140000)
[ 0.446974] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[ 0.447316] iommu: Adding device tegradc.1 to group 14
[ 0.447364] platform tegradc.1: domain=ffffffc0f94bdb58 allocates as[0]=ffffffc0f9bd82b0
[ 0.448741] platform tegradc.1: IOVA linear map 0x0000000092cb0000(140000)
[ 0.449156] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[ 0.449398] iommu: Adding device 54340000.vic to group 15
[ 0.449607] iommu: Adding device 544c0000.nvenc to group 16
[ 0.449808] iommu: Adding device 54500000.tsec to group 17
[ 0.450010] iommu: Adding device 54100000.tsecb to group 18
[ 0.450214] iommu: Adding device 54480000.nvdec to group 19
[ 0.450405] iommu: Adding device 54380000.nvjpg to group 20
[ 0.451486] iommu: Adding device 546c0000.i2c to group 21
[ 0.451815] iommu: Adding device 57000000.gpu to group 22
[ 0.451863] platform 57000000.gpu: domain=ffffffc0f94cab58 allocates as[0]=ffffffc0f9bd8318
[ 0.451901] platform 57000000.gpu: domain=ffffffc0f94cab58 allocates as[1]=ffffffc0f9bd8380
[ 0.451940] platform 57000000.gpu: domain=ffffffc0f94cab58 allocates as[2]=ffffffc0f9bd83e8
[ 0.451981] platform 57000000.gpu: domain=ffffffc0f94cab58 allocates as[3]=ffffffc0f9bd8450
[ 0.452865] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.452876] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.452887] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.452892] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[ 0.452897] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.505156] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.505165] tegra-pmc: Clear bootloader IO dpd settings
[ 0.505186] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.505248] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.505533] iommu: Adding device 70012000.se to group 23
[ 0.506300] iommu: Adding device 7000c000.i2c to group 24
[ 0.506554] iommu: Adding device 7000c400.i2c to group 25
[ 0.506804] iommu: Adding device 7000c500.i2c to group 26
[ 0.507059] iommu: Adding device 7000c700.i2c to group 27
[ 0.507308] iommu: Adding device 7000d000.i2c to group 28
[ 0.507584] iommu: Adding device 7000d100.i2c to group 29
[ 0.507846] iommu: Adding device sdhci-tegra.3 to group 30
[ 0.507901] platform sdhci-tegra.3: domain=ffffffc0f9562cd8 allocates as[0]=ffffffc0f9bd84b8
[ 0.508324] iommu: Adding device sdhci-tegra.2 to group 31
[ 0.508376] platform sdhci-tegra.2: domain=ffffffc0f9562f18 allocates as[0]=ffffffc0f9bd8520
[ 0.509241] iommu: Adding device 700d0000.xudc to group 32
[ 0.512622] vdd-ac-bat: 5000 mV
[ 0.512971] vdd-5v0-sys: 5000 mV
[ 0.514004] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[ 0.514045] vdd-5v0-hdmi: 5000 mV
[ 0.514440] vdd-1v8-sys: 1800 mV
[ 0.514841] vdd-fan: supplied by vdd-5v0-sys
[ 0.514874] vdd-fan: 5000 mV
[ 0.515293] vdd-usb-vbus: supplied by vdd-5v0-sys
[ 0.515328] vdd-usb-vbus: 5000 mV
[ 0.515835] vdd-usb-vbus2: 5000 mV
[ 0.545848] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.548232] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
[ 0.550150] GPIO line 151 (camera-control-output-low) hogged as output/low
[ 0.550168] GPIO line 152 (camera-control-output-low) hogged as output/low
[ 0.550197] GPIO line 6 (system-suspend-gpio) hogged as output/high
[ 0.550545] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[ 0.558235] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.558582] SCSI subsystem initialized
[ 0.558801] libata version 3.00 loaded.
[ 0.559051] usbcore: registered new interface driver usbfs
[ 0.559098] usbcore: registered new interface driver hub
[ 0.559176] usbcore: registered new device driver usb
[ 0.562914] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ 0.568324] vdd-core: 600 <--> 1162 mV at 1125 mV
[ 0.568446] random: fast init done
[ 0.569304] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[ 0.572939] vdd-ddr-1v1: 1150 mV
[ 0.576939] vdd-pre-reg-1v35: 1350 mV
[ 0.580942] vdd-1v8: 1800 mV
[ 0.584941] avdd-sys-1v2: 1200 mV
[ 0.588938] vdd-pex-1v0: 1050 mV
[ 0.589486] vddio-sdmmc-ap: 1800 <--> 3300 mV at 3300 mV
[ 0.589971] max77620-ldo3: at 3100 mV
[ 0.592942] vdd-rtc: 850 <--> 1100 mV at 1000 mV
[ 0.593457] max77620-ldo5: at 3100 mV
[ 0.596943] vddio-sdmmc3-ap: 1800 <--> 3300 mV at 2800 mV
[ 0.600939] avdd-1v05-pll: 1050 mV
[ 0.604938] avdd-io-hdmi-dp: 1050 mV
[ 0.606094] GPIO line 505 (spmic-default-output-high) hogged as output/high
[ 0.606362] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[ 0.607666] max77620 4-003c: max77620 probe successful
[ 0.610300] media: Linux media interface: v0.10
[ 0.610354] Linux video capture interface: v2.00
[ 0.611196] pps_core: LinuxPPS API ver. 1 registered
[ 0.611202] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.611226] PTP clock support registered
[ 0.614976] tegra_fiq_debugger_init: found FIQ source (IRQ 98)
[ 0.621413] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[ 0.622223] Advanced Linux Sound Architecture Driver Initialized.
[ 0.622883] Bluetooth: Core ver 2.22
[ 0.622932] NET: Registered protocol family 31
[ 0.622935] Bluetooth: HCI device and connection manager initialized
[ 0.622949] Bluetooth: HCI socket layer initialized
[ 0.622957] Bluetooth: L2CAP socket layer initialized
[ 0.622982] Bluetooth: SCO socket layer initialized
[ 0.624806] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.624824] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.624875] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.624890] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.628004] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.629204] vdd-3v3-sys: supplied by vdd-5v0-sys
[ 0.629264] vdd-3v3-sys: 3300 mV
[ 0.629532] vdd-1v8-sys: supplied by vdd-3v3-sys
[ 0.632297] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ 0.632767] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 0.632827] vdd-3v3-sd: 3300 mV
[ 0.633727] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[ 0.633775] avdd-io-edp-1v05: 1050 mV
[ 0.634251] vdd-usb-hub-en: supplied by vdd-1v8-sys
[ 0.634316] vdd-usb-hub-en: 5000 mV
[ 0.635770] camchar: rtcpu character device driver loaded
[ 0.636473] extcon-gpio-states extcon:extcon@1: Cable state:0, cable id:0
[ 0.637835] clocksource: Switched to clocksource arch_sys_counter
[ 0.676611] VFS: Disk quotas dquot_6.6.0
[ 0.676733] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.677192] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.677589] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[ 0.677608] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[ 0.677807] cma: enabled page replacement for spfn=d7000, epfn=f0000
[ 0.677813] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.677863] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 0.677889] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.677895] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[ 0.677906] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[ 0.677915] nvmap_page_pool_init: Total RAM pages: 1010999
[ 0.677921] nvmap_page_pool_init: nvmap page pool size: 126374 pages (493 MB)
[ 0.678026] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.678465] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 0.679412] misc nvmap: created heap vpr base 0x00000000d7000000 size (409600KiB)
[ 0.687551] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.687961] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.688215] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.688423] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.688602] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.688862] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.688867] pre_t19x_iso_plat_init(): max_iso_bw=33280000KB
[ 0.689307] NET: Registered protocol family 2
[ 0.690331] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.690543] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.691042] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.691187] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.691269] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.691678] NET: Registered protocol family 1
[ 0.692405] RPC: Registered named UNIX socket transport module.
[ 0.692412] RPC: Registered udp transport module.
[ 0.692416] RPC: Registered tcp transport module.
[ 0.692420] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.692432] PCI: CLS 0 bytes, default 64
[ 0.692662] Trying to unpack rootfs image as initramfs...
[ 0.926197] Freeing initrd memory: 5356K
[ 0.936159] host1x 50000000.host1x: initialized
[ 0.938067] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.941195] audit: initializing netlink subsys (disabled)
[ 0.941265] audit: type=2000 audit(0.791:1): initialized
[ 0.942078] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.952002] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.953468] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.954317] 9p: Installing v9fs 9p2000 file system support
[ 0.957540] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.957690] io scheduler noop registered
[ 0.958021] io scheduler cfq registered (default)
[ 0.960699] gic 702f9000.agic: GIC IRQ controller registered
[ 0.963505] iommu: Adding device 702ef000.adsp to group 33
[ 0.969546] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
[ 0.969680] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[ 0.970283] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x61e740d
[ 0.970291] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[ 0.971923] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 0.972019] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 0.972119] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 0.972297] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 0.972392] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 0.972475] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 0.972563] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 0.972648] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 0.972743] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 0.972828] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 0.979015] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 0.980793] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 0.982847] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[ 0.984141] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[ 0.984493] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[ 0.985736] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.985980] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[ 0.986172] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[ 0.986424] Adding domain tsec-pd to PM domain host1x-pd
[ 0.989535] tsec 54500000.tsec: initialized
[ 0.991089] tsec 54100000.tsecb: initialized
[ 0.991803] Adding domain nvdec-pd to PM domain host1x-pd
[ 0.995306] nvdec 54480000.nvdec: initialized
[ 0.996386] Adding domain vic03-pd to PM domain host1x-pd
[ 0.996569] Adding domain msenc-pd to PM domain host1x-pd
[ 0.996723] Adding domain nvjpg-pd to PM domain host1x-pd
[ 1.000681] falcon 54340000.vic: initialized
[ 1.001960] falcon 544c0000.nvenc: initialized
[ 1.003328] falcon 54380000.nvjpg: initialized
[ 1.008100] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ 1.008224] display board info: id 0x0, fab 0x0
[ 1.008286] generic_infoframe_type: 0x87
[ 1.008427] tegradc tegradc.0: DT parsed successfully
[ 1.008475] tegradc tegradc.0: Display dc.ffffff800ab80000 registered with id=0
[ 1.009029] tegradc tegradc.0: Bootloader disp_param detected. Detected mode: 640x480 (on 0x0mm) pclk=25173906
[ 1.011926] tegradc tegradc.0: probed
[ 1.016094] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 1.020427] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 10 channels
[ 1.021234] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 1.021575] kfuse 7000fc00.kfuse: initialized
[ 1.022988] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[ 1.023992] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.025388] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 1.025403] vdd-cpu: 708 <--> 1322 mV at 708 mV
[ 1.025913] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 1.027235] vdd-gpu: applied init 1000000uV constraint
[ 1.027245] vdd-gpu: 708 <--> 1323 mV at 997 mV
[ 1.027647] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 1.032117] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.032270] No Device Node present for smmu client: serial8250 !!
[ 1.032280] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.032336] iommu: Adding device serial8250 to group 35
[ 1.035105] console [ttyS0] disabled
[ 1.035181] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[ 1.035272] console [ttyS0] enabled
[ 1.036206] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 1.036567] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 1.037543] [drm] Initialized
[ 1.039384] Console: switching to colour frame buffer device 80x30
[ 1.039423] tegradc tegradc.0: fb registered
[ 1.049200] tegradc tegradc.0: DC initialized, skipping tegra_dc_program_mode.
[ 1.049255] tegradc tegradc.0: hdmi: tmds rate:25174K prod-setting:prod_c_hdmi_0m_54m
[ 1.049773] tegradc tegradc.0: hdmi: get RGB quant from REG programmed by BL.
[ 1.049786] tegradc tegradc.0: hdmi: BL set VIC 0
[ 1.049793] tegradc tegradc.0: hdmi: get YCC quant from REG programmed by BL.
[ 1.050008] brd: module loaded
[ 1.050297] tegra-i2c 7000c700.i2c: no acknowledge from address 0x50
[ 1.050521] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 1.050526] Extcon AUX1(HDMI) enable
[ 1.051642] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 1.051730] tegradc tegradc.1: No lt-data, using default setting
[ 1.051763] tegradc tegradc.1: No hpd-gpio in DT
[ 1.051798] tegradc tegradc.1: DT parsed successfully
[ 1.051849] tegradc tegradc.1: Display dc.ffffff800d500000 registered with id=1
[ 1.053466] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.056047] loop: module loaded
[ 1.056144] tegra_profiler: version: 1.134, samples/io: 47/26
[ 1.056256] tegra_profiler: auth: init
[ 1.057368] THERMAL EST: found 2 subdevs
[ 1.057373] THERMAL EST num_resources: 0
[ 1.057378] [THERMAL EST subdev 0]
[ 1.057385] [THERMAL EST subdev 1]
[ 1.057920] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 1.057923] THERMAL EST: thz register success.
[ 1.058066] THERMAL EST: end of probe, return err: 0
[ 1.059299] hisi_sas: driver version v1.6
[ 1.061861] edid invalid
[ 1.065080] libphy: Fixed MDIO Bus: probed
[ 1.065702] tun: Universal TUN/TAP device driver, 1.6
[ 1.065706] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.066828] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.066835] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.066888] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.066892] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.066946] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.066949] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.066996] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 1.067000] Copyright(c) 1999 - 2017 Intel Corporation.
[ 1.068051] PPP generic driver version 2.4.2
[ 1.069991] PPP BSD Compression module registered
[ 1.069998] PPP Deflate Compression module registered
[ 1.070040] PPP MPPE Compression module registered
[ 1.070048] NET: Registered protocol family 24
[ 1.070123] usbcore: registered new interface driver r8152
[ 1.070165] usbcore: registered new interface driver asix
[ 1.070217] usbcore: registered new interface driver ax88179_178a
[ 1.070253] usbcore: registered new interface driver cdc_ether
[ 1.070292] usbcore: registered new interface driver net1080
[ 1.070330] usbcore: registered new interface driver cdc_subset
[ 1.070365] usbcore: registered new interface driver zaurus
[ 1.070409] usbcore: registered new interface driver simcom_wwan
[ 1.070471] usbcore: registered new interface driver cdc_ncm
[ 1.090268] tegradc tegradc.0: nominal-pclk:25174825 parent:25173906 div:1.0 pclk:25173906 24923052~27440532
[ 1.090610] VFIO - User Level meta-driver version: 0.3
[ 1.091571] tegradc tegradc.1: probed
[ 1.093114] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.093182] ehci-pci: EHCI PCI platform driver
[ 1.093251] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.093265] ohci-pci: OHCI PCI platform driver
[ 1.093315] ohci-platform: OHCI generic platform driver
[ 1.099229] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 1.099942] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 1.101314] tegra-xusb 70090000.xusb: extcon 0: ffffffc0f9422400 id
[ 1.104844] usbcore: registered new interface driver uas
[ 1.104943] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 1.105036] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.105080] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[ 1.105968] usbcore: registered new interface driver usb-storage
[ 1.106086] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[ 1.106177] usbcore: registered new interface driver usbserial
[ 1.106183] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 1.106253] usbcore: registered new interface driver option
[ 1.106295] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.106644] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.106654] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.106660] usb usb1: Product: xHCI Host Controller
[ 1.106666] usb usb1: Manufacturer: Linux 4.9.140 xhci-hcd
[ 1.106670] usb usb1: SerialNumber: 70090000.xusb
[ 1.108107] hub 1-0:1.0: USB hub found
[ 1.108171] hub 1-0:1.0: 5 ports detected
[ 1.109380] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.109397] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[ 1.109507] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.109609] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.109616] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.109621] usb usb2: Product: xHCI Host Controller
[ 1.109625] usb usb2: Manufacturer: Linux 4.9.140 xhci-hcd
[ 1.109629] usb usb2: SerialNumber: 70090000.xusb
[ 1.110353] hub 2-0:1.0: USB hub found
[ 1.110390] hub 2-0:1.0: 4 ports detected
[ 1.111592] tegra-xudc-new 700d0000.xudc: device count: 1
[ 1.113188] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 1.113205] tegra-xudc-new 700d0000.xudc: vbus state: 0
[ 1.113241] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 1.113503] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 1.114391] mousedev: PS/2 mouse device common for all mice
[ 1.114500] usbcore: registered new interface driver xpad
[ 1.114789] cyttsp5_i2c_adapter 0-0024: cyttsp5_init: INIT CYTTSP RST gpio=194 and IRQ gpio=224 r=0
[ 1.115129] tegra-i2c 7000c000.i2c: no acknowledge from address 0x24
[ 1.115243] tegra-i2c 7000c000.i2c: no acknowledge from address 0x24
[ 1.115279] cyttsp5_i2c_adapter 0-0024: cyttsp5_get_hid_descriptor_: failed to get HID descriptor length and version, rc=-121
[ 1.126700] cyttsp5_i2c_adapter 0-0024: cyttsp5_startup_: Error on getting HID descriptor r=-121
[ 1.126782] tegra-i2c 7000c000.i2c: no acknowledge from address 0x24
[ 1.135521] tegradc tegradc.1: fb registered
[ 1.138747] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 1.138754] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 1.138764] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 1.138780] tegradc tegradc.1: blank - powerdown
[ 1.138804] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[ 1.138809] Extcon DP: HPD disabled
[ 1.138813] hpd: hpd_switch 0
[ 1.138818] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 1.138826] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 1.138833] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 1.194592] tegradc tegradc.0: hdmi: edid read failed
[ 1.199750] tegradc tegradc.0: hdmi: using fallback edid
[ 1.199855] tegradc tegradc.0: blank - powerdown
[ 1.210052] usb usb1: usb_suspend_both: status 0
[ 1.229850] cyttsp5_i2c_adapter 0-0024: cyttsp5_xres: RESET CYTTSP gpio=194 r=0
[ 1.245395] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 1.245398] Extcon AUX1(HDMI) disable
[ 1.275719] tegradc tegradc.0: unblank
[ 1.319792] tegradc tegradc.0: nominal-pclk:74250000 parent:74250000 div:1.0 pclk:74250000 73507500~80932500
[ 1.319871] tegradc tegradc.0: hdmi: tmds rate:74250K prod-setting:prod_c_hdmi_54m_75m
[ 1.320934] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 1.320948] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 1.327580] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 1.327583] Extcon AUX1(HDMI) enable
[ 1.328052] tegradc tegradc.0: sync windows ret = 250
[ 1.333185] extcon-disp-state extcon:disp-state: cable 40 state 1
[ 1.333188] Extcon HDMI: HPD enabled
[ 1.333215] tegradc tegradc.0: hdmi: plugged
[ 1.426194] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 1.830448] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.233862] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.235882] tegra-pcie 1003000.pcie: link 0 down, ignoring
[ 2.341946] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[ 2.341959] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 2.341965] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 2.341971] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 2.341978] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.342019] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[ 2.342131] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.342413] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.342580] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
[ 2.342610] pci 0000:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 2.342645] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit pref]
[ 2.342670] pci 0000:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit pref]
[ 2.342818] pci 0000:01:00.0: supports D1 D2
[ 2.342824] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.353896] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 2.353948] pci 0000:00:02.0: BAR 15: assigned [mem 0x20000000-0x200fffff 64bit pref]
[ 2.353955] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.353966] pci 0000:01:00.0: BAR 4: assigned [mem 0x20000000-0x20003fff 64bit pref]
[ 2.353989] pci 0000:01:00.0: BAR 2: assigned [mem 0x20004000-0x20004fff 64bit pref]
[ 2.354008] pci 0000:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 2.354019] pci 0000:00:02.0: PCI bridge to [bus 01]
[ 2.354026] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 2.354036] pci 0000:00:02.0: bridge window [mem 0x20000000-0x200fffff 64bit pref]
[ 2.354390] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 2.354395] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.354424] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[ 2.354567] aer 0000:00:02.0:pcie002: service driver aer loaded
[ 2.354801] r8168 0000:01:00.0: enabling device (0000 -> 0003)
[ 2.354828] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 2.376094] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[ 2.376309] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 00:04:4b:e9:c9:cc from device tree
[ 2.376945] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 2.376976] r8168 Copyright (C) 2017 Realtek NIC software team <nicfae@realtek.com>
This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[ 5.270364] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ 5.270370] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ 5.374100] usb usb2: usb_suspend_both: status 0
[ 6.257853] cyttsp5_i2c_adapter 0-0024: cyttsp5_reset_and_wait: reset timed out
[ 6.265271] cyttsp5_i2c_adapter 0-0024: cyttsp5_startup_: Error on h/w reset r=-62
[ 6.273004] tegra-i2c 7000c000.i2c: no acknowledge from address 0x24
[ 6.373840] cyttsp5_i2c_adapter 0-0024: cyttsp5_xres: RESET CYTTSP gpio=194 r=0
[ 8.049847] tegra-xusb 70090000.xusb: entering ELPG
[ 8.051079] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 1, speed 0
[ 8.051291] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 2, speed 0
[ 8.052916] tegra-xusb 70090000.xusb: entering ELPG done
[ 11.377843] cyttsp5_i2c_adapter 0-0024: cyttsp5_reset_and_wait: reset timed out
[ 11.385228] cyttsp5_i2c_adapter 0-0024: cyttsp5_startup_: Error on h/w reset r=-62
[ 11.392941] tegra-i2c 7000c000.i2c: no acknowledge from address 0x24
[ 11.493838] cyttsp5_i2c_adapter 0-0024: cyttsp5_xres: RESET CYTTSP gpio=194 r=0
[ 16.497840] cyttsp5_i2c_adapter 0-0024: cyttsp5_reset_and_wait: reset timed out
[ 16.505223] cyttsp5_i2c_adapter 0-0024: cyttsp5_startup_: Error on h/w reset r=-62
[ 16.512945] tegra-i2c 7000c000.i2c: no acknowledge from address 0x24
[ 16.512976] cyttsp5_i2c_adapter 0-0024: cyttsp5_hid_exec_cmd_: Fail cyttsp5_adap_transfer
[ 16.521233] cyttsp5_i2c_adapter 0-0024: cyttsp5_hid_cmd_set_power_: Failed to set power to state:1
[ 16.530271] cyttsp5_i2c_adapter 0-0024: cyttsp5_core_rt_suspend: Error on sleep
[ 16.537646] cyttsp5_i2c_adapter 0-0024: cyttsp5_probe: Fail initial startup r=-19
[ 16.545339] cyttsp5_i2c_adapter 0-0024: cyttsp5_init: INIT CYTTSP RST gpio=194 and IRQ gpio=224 r=0
[ 16.545345] cyttsp5_i2c_adapter 0-0024: cyttsp5_probe failed.
[ 16.551307] cyttsp5_debug_init: Parade TTSP Debug Driver (Built TTDA.03.08.874312) rc=0
[ 16.551315] cyttsp5_loader_init: Parade TTSP FW Loader Driver (Built TTDA.03.08.874312) rc=0
[ 16.551323] cyttsp5_device_access_init: Parade TTSP Device Access Driver (Built TTDA.03.08.874312) rc=0
[ 16.679129] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 16.681697] rtc rtc1: alarm rtc device
[ 16.681714] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 16.681744] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 16.682499] i2c /dev entries driver
[ 16.684608] i2c i2c-6: Added multiplexed i2c bus 7
[ 16.685143] i2c i2c-6: Added multiplexed i2c bus 8
[ 16.685151] i2c-mux-gpio cam_i2cmux: 2 port mux on Tegra I2C adapter adapter
[ 16.685964] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 16.688595] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 16.688603] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 16.689086] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 16.689104] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 16.689115] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 16.689249] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 16.689261] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 16.689269] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 16.689412] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 16.689423] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 16.689429] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 16.689604] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 16.690471] tegra_aotag tegra-aotag: Registering sensor 0
[ 16.690529] tegra_aotag tegra-aotag: Invalid temp readout
[ 16.690554] tegra_aotag tegra-aotag: Invalid temp readout
[ 16.690572] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 16.690582] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 16.691641] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 16.691663] tegra_dfll_action dfll-cdev-cap: Tegra DFLL 'cap cooling device' registered
[ 16.691906] tegra_aotag tegra-aotag: Invalid temp readout
[ 16.691937] tegra_dfll_action dfll-cdev-floor: Tegra DFLL 'floor cooling device' registered
[ 16.692452] parse_throttle_dt_data: Num cap clks = 6
[ 16.692461] parse_throttle_dt_data: clk=cclk_g type=2
[ 16.692476] parse_throttle_dt_data: clk=gpu type=4
[ 16.692506] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 16.692529] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 16.692555] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 16.692559] parse_throttle_dt_data: clk=emc type=3
[ 16.693078] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 16.693222] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 16.693433] tegra_throttle_probe: probe successful. #cdevs=4
[ 16.694354] FAN dev name: pwm-fan
[ 16.694411] FAN:gpio request success.
[ 16.694486] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 16.694798] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 16.694984] pwm_fan_driver pwm-fan: fan tach request irq success
[ 16.694995] pwm_fan_driver pwm-fan: tach period: 1000
[ 16.695089] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 16.695096] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 16.695101] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 16.695107] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 16.695112] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 16.695117] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 16.695121] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 16.695126] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 16.695131] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 16.695136] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 16.695864] tegra-wdt 60005100.watchdog: Tegra WDT enabled on probe. Timeout = 120 seconds.
[ 16.696208] tegra-wdt 60005100.watchdog: initialized (timeout = 120 sec, nowayout = 1)
[ 16.697254] device-mapper: uevent: version 1.0.3
[ 16.697776] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 16.703495] tegra210-cpufreq cpufreq: probe()...completed
[ 16.704286] sdhci: Secure Digital Host Controller Interface driver
[ 16.704288] sdhci: Copyright(c) Pierre Ossman
[ 16.704290] sdhci-pltfm: SDHCI platform and OF driver helper
[ 16.704674] sdhci-tegra sdhci-tegra.3: Client registration for eMC Successful
[ 16.709392] sdhci-tegra sdhci-tegra.2: Client registration for eMC Successful
[ 16.714042] tegra-se 70012000.se: tegra_se_probe: complete
[ 16.714586] hidraw: raw HID events driver (C) Jiri Kosina
[ 16.715729] usbcore: registered new interface driver usbhid
[ 16.715731] usbhid: USB HID core driver
[ 16.717891] tegra21x_actmon 6000c800.actmon: in actmon_register()...
[ 16.718060] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 16.719772] nvpmodel: initialized successfully
[ 16.720721] usbcore: registered new interface driver snd-usb-audio
[ 16.720776] No Device Node present for smmu client: snd-soc-dummy !!
[ 16.720782] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 16.720801] iommu: Adding device snd-soc-dummy to group 36
[ 16.732598] OPE platform probe
[ 16.732684] OPE platform probe successful
[ 16.732710] OPE platform probe
[ 16.732792] OPE platform probe successful
[ 16.742207] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[ 16.745875] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA 64-bit with 64 bit addr
[ 16.757677] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 16.757804] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 16.757848] mmc1: SDHCI controller on sdhci-tegra.2 [sdhci-tegra.2] using ADMA 64-bit with 64 bit addr
[ 16.758001] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 16.758123] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 16.758243] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 16.758366] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 16.758487] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 16.758606] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 16.758727] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 16.758856] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 16.771132] u32 classifier
[ 16.771135] Actions configured
[ 16.771207] Initializing XFRM netlink socket
[ 16.771942] NET: Registered protocol family 10
[ 16.772682] NET: Registered protocol family 17
[ 16.772694] NET: Registered protocol family 15
[ 16.772769] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 16.772817] Bluetooth: RFCOMM socket layer initialized
[ 16.772829] Bluetooth: RFCOMM ver 1.11
[ 16.772834] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 16.772839] Bluetooth: HIDP socket layer initialized
[ 16.772859] 9pnet: Installing 9P2000 support
[ 16.772895] Key type dns_resolver registered
[ 16.773302] Registered cp15_barrier emulation handler
[ 16.773309] Registered setend emulation handler
[ 16.774430] registered taskstats version 1
[ 16.775032] Adding domain ve2-pd to PM domain host1x-pd
[ 16.775274] Adding domain ve-pd to PM domain host1x-pd
[ 16.777373] isp 54600000.isp: initialized
[ 16.778316] isp 54680000.isp: initialized
[ 16.788532] last reset is due to power on reset
[ 16.788537] KERNEL: PMC reset status reg: 0x0
[ 16.788616] BL: PMC reset status reg: 0x0
[ 16.788618] BL: PMIC poweroff Event Recorder: 0x40
[ 16.790326] clk_cbus_recalc_rate: no gbus parent
[ 16.790332] clk_cbus_round_rate: no gbus parent
[ 16.790334] clk_cbus_round_rate: no gbus parent
[ 16.790343] clk_cbus_recalc_rate: no gbus parent
[ 16.790444] clk_cbus_recalc_rate: no gbus parent
[ 16.790448] clk_cbus_round_rate: no gbus parent
[ 16.790450] clk_cbus_round_rate: no gbus parent
[ 16.790455] clk_cbus_recalc_rate: no gbus parent
[ 16.791166] tegra_dvfs: GPU-cap: registered
[ 16.791227] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[ 16.791230] tegra dvfs: vdd-core: nominal 1125mV, offset 600000uV, step 12500uV, scaling enabled
[ 16.791232] tegra dvfs: vdd-gpu: nominal 1068mV, offset 708000uV, step 10000uV, scaling enabled
[ 16.793441] tegra_dvfs: vdd-gpu-vts: registered
[ 16.794161] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS 'floor cooling device' registered
[ 16.794748] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS 'cap cooling device' registered
[ 16.795283] input: gpio-keys as /devices/gpio-keys/input/input1
[ 16.797551] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 16.801920] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[ 16.802133] mmcblk0boot0: mmc0:0001 DG4016 partition 1 4.00 MiB
[ 16.806367] mmcblk0boot1: mmc0:0001 DG4016 partition 2 4.00 MiB
[ 16.811082] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB
[ 16.814194] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17
[ 16.826508] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 01:00:30 UTC (946688430)
[ 16.827525] vi 54080000.vi: vi_probe: ++
[ 16.830487] vi 54080000.vi: initialized
[ 16.832473] vi 54080000.vi: subdev nvcsi--2 bound
[ 16.832575] vi 54080000.vi: subdev nvcsi--1 bound
[ 16.832791] mmcblk mmc0:0001: Card claimed for testing.
[ 16.834135] Disable partitions left on by BL
[ 16.834139] disb
[ 16.834189] bwmgr: missing cdev-type property
[ 16.834286] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 16.834292] DRAM derating cdev registered.
[ 16.835333] vdd-fan: disabling
[ 16.835337] vdd-usb-vbus: disabling
[ 16.835340] vdd-usb-vbus2: disabling
[ 16.835349] vddio-sdmmc-ap: disabling
[ 16.835432] vdd-3v3-sd: disabling
[ 16.835437] avdd-io-edp-1v05: disabling
[ 16.835440] vdd-usb-hub-en: disabling
[ 16.835521] ALSA device list:
[ 16.835524] #0: tegra-hda at 0x70038000 irq 82
[ 16.835526] #1: tegra-snd-t210ref-mobile-rt565x
[ 16.838770] Freeing unused kernel memory: 8576K
[ 16.859908] Root device found: mmcblk0p1
[ 16.860954] Found dev node: /dev/mmcblk0p1
[ 17.421569] EXT4-fs (mmcblk0p1): 8 orphan inodes deleted
[ 17.421573] EXT4-fs (mmcblk0p1): recovery complete
[ 17.436780] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 17.437574] Rootfs mounted over mmcblk0p1
[ 17.448831] Switching from initrd to actual rootfs
[ 17.521991] systemd[1]: System time before build time, advancing clock.
[ 17.543367] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 17.554811] cgroup: cgroup2: unknown option "nsdelegate"
[ 17.567556] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 17.568312] systemd[1]: Detected architecture arm64.
[ 17.591813] systemd[1]: Set hostname to <jetson-nano-slave>.
[ 17.654639] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 17.654649] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 17.668119] systemd[1]: network-online.target: Wants dependency dropin /etc/systemd/system/network-online.target.wants/networking.service.wujz is not a symlink, ignoring.
[ 17.748533] random: systemd: uninitialized urandom read (16 bytes read)
[ 17.748564] systemd[1]: Reached target Swap.
[ 17.748921] random: systemd: uninitialized urandom read (16 bytes read)
[ 17.750708] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 17.750769] random: systemd: uninitialized urandom read (16 bytes read)
[ 17.752335] systemd[1]: Created slice System Slice.
[ 17.752541] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 17.802271] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 18.074085] systemd-journald[1996]: Received request to flush runtime journal from PID 1
[ 18.216222] random: crng init done
[ 18.216228] random: 7 urandom warning(s) missed due to ratelimiting
[ 18.451194] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 18.697928] using random self ethernet address
[ 18.697931] using random host ethernet address
[ 19.707845] eth0: 0xffffff800a72b000, 00:04:4b:e9:c9:cc, IRQ 404
[ 19.895662] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 20.223816] knl-->request gpio ok, gpio = 66, val = 1
[ 20.223829] knl-->request gpio ok, gpio = 62, val = 1
[ 20.223838] knl-->request gpio ok, gpio = 17, val = 1
[ 20.223846] knl-->request gpio ok, gpio = 16, val = 1
[ 20.223854] knl-->request gpio ok, gpio = 18, val = 0
[ 20.223862] knl-->request gpio ok, gpio = 19, val = 0
[ 20.924584] tegra-xusb 70090000.xusb: exiting ELPG
[ 20.924954] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 20.928374] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 20.928658] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 0
[ 20.928681] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 1
[ 20.928700] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 2
[ 20.929303] tegra-xusb 70090000.xusb: exiting ELPG done
[ 21.153883] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 21.154284] usb 1-2: Device not responding to setup address.
[ 21.366225] usb 1-2: Device not responding to setup address.
[ 21.577871] usb 1-2: device not accepting address 2, error -71
[ 21.701910] usb 1-2: new high-speed USB device number 3 using tegra-xusb
[ 21.702285] usb 1-2: Device not responding to setup address.
[ 21.914257] usb 1-2: Device not responding to setup address.
[ 22.125869] usb 1-2: device not accepting address 3, error -71
[ 22.131882] usb usb1-port2: attempt power cycle
[ 22.966369] r8168: eth0: link up
[ 22.966408] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 22.981968] usb 1-2: new high-speed USB device number 4 using tegra-xusb
[ 23.106042] usb 1-2: device descriptor read/64, error -71
[ 23.175535] zram: Added device: zram0
[ 23.176056] zram: Added device: zram1
[ 23.181375] zram: Added device: zram2
[ 23.184052] zram: Added device: zram3
[ 23.248371] zram0: detected capacity change from 0 to 519417856
[ 23.317802] Adding 507240k swap on /dev/zram0. Priority:5 extents:1 across:507240k SS
[ 23.329202] zram1: detected capacity change from 0 to 519417856
[ 23.338661] usb 1-2: device descriptor read/64, error -71
[ 23.361376] Adding 507240k swap on /dev/zram1. Priority:5 extents:1 across:507240k SS
[ 23.371487] zram2: detected capacity change from 0 to 519417856
[ 23.417544] Adding 507240k swap on /dev/zram2. Priority:5 extents:1 across:507240k SS
[ 23.444262] zram3: detected capacity change from 0 to 519417856
[ 23.471331] Adding 507240k swap on /dev/zram3. Priority:5 extents:1 across:507240k SS
[ 23.573870] usb 1-2: new high-speed USB device number 5 using tegra-xusb
[ 23.694056] usb 1-2: device descriptor read/64, error -71
[ 23.926068] usb 1-2: device descriptor read/64, error -71
[ 24.037963] usb usb1-port2: unable to enumerate USB device
[ 24.309844] usb 1-2: new high-speed USB device number 6 using tegra-xusb
[ 24.310227] usb 1-2: Device not responding to setup address.
[ 24.522271] usb 1-2: Device not responding to setup address.
[ 24.733900] usb 1-2: device not accepting address 6, error -71
[ 24.857860] usb 1-2: new high-speed USB device number 7 using tegra-xusb
[ 24.858243] usb 1-2: Device not responding to setup address.
[ 25.070328] usb 1-2: Device not responding to setup address.
[ 25.281888] usb 1-2: device not accepting address 7, error -71
[ 25.288834] usb usb1-port2: attempt power cycle
[ 26.137843] usb 1-2: new high-speed USB device number 8 using tegra-xusb
[ 26.258049] usb 1-2: device descriptor read/64, error -71
[ 26.494148] usb 1-2: device descriptor read/64, error -71
[ 26.725865] usb 1-2: new high-speed USB device number 9 using tegra-xusb
[ 26.850032] usb 1-2: device descriptor read/64, error -71
[ 27.086074] usb 1-2: device descriptor read/64, error -71
[ 27.198091] usb usb1-port2: unable to enumerate USB device
[ 27.203840] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 2
[ 27.286415] tegradc tegradc.0: blank - powerdown
[ 27.337978] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 27.337980] Extcon AUX1(HDMI) disable
[ 27.358530] tegradc tegradc.0: unblank
[ 27.374337] tegradc tegradc.0: nominal-pclk:74250000 parent:74250000 div:1.0 pclk:74250000 73507500~80932500
[ 27.374437] tegradc tegradc.0: hdmi: tmds rate:74250K prod-setting:prod_c_hdmi_54m_75m
[ 27.375528] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 27.375537] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 27.379026] tegra_i2c_handle_xfer_error: 11 callbacks suppressed
[ 27.379031] tegra-i2c 7000c700.i2c: no acknowledge from address 0x50
[ 27.382287] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 27.382290] Extcon AUX1(HDMI) enable
[ 27.397626] tegradc tegradc.0: unblank
[ 27.398360] tegradc tegradc.1: blank - powerdown
[ 27.470302] usb 1-3: new high-speed USB device number 10 using tegra-xusb
[ 27.470710] usb 1-3: Device not responding to setup address.
[ 27.682312] usb 1-3: Device not responding to setup address.
[ 27.893902] usb 1-3: device not accepting address 10, error -71
[ 28.017982] usb 1-3: new high-speed USB device number 11 using tegra-xusb
[ 28.018401] usb 1-3: Device not responding to setup address.
[ 28.230256] usb 1-3: Device not responding to setup address.
[ 28.445891] usb 1-3: device not accepting address 11, error -71
[ 28.452108] usb usb1-port3: attempt power cycle
[ 29.301953] usb 1-3: new high-speed USB device number 12 using tegra-xusb
[ 29.422133] usb 1-3: device descriptor read/64, error -71
[ 29.658079] usb 1-3: device descriptor read/64, error -71
[ 29.893875] usb 1-3: new high-speed USB device number 13 using tegra-xusb
[ 30.018126] usb 1-3: device descriptor read/64, error -71
[ 30.250229] usb 1-3: device descriptor read/64, error -71
[ 30.366057] usb usb1-port3: unable to enumerate USB device
[ 30.645879] usb 1-2: new high-speed USB device number 14 using tegra-xusb
[ 30.646292] usb 1-2: Device not responding to setup address.
[ 30.858405] usb 1-2: Device not responding to setup address.
[ 31.069990] usb 1-2: device not accepting address 14, error -71
[ 31.193893] usb 1-2: new high-speed USB device number 15 using tegra-xusb
[ 31.194359] usb 1-2: Device not responding to setup address.
[ 31.406377] usb 1-2: Device not responding to setup address.
[ 31.617900] usb 1-2: device not accepting address 15, error -71
[ 31.624078] usb usb1-port2: attempt power cycle
[ 32.006201] fuse init (API version 7.26)
[ 32.025250] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 32.025262] Bluetooth: BNEP socket layer initialized
[ 32.477866] usb 1-2: new high-speed USB device number 16 using tegra-xusb
[ 32.598584] usb 1-2: device descriptor read/64, error -71
[ 32.830049] usb 1-2: device descriptor read/64, error -71
[ 32.944215] tegradc tegradc.0: unblank
[ 32.944225] tegradc tegradc.1: blank - powerdown
[ 33.062499] usb 1-2: new high-speed USB device number 17 using tegra-xusb
[ 33.182021] usb 1-2: device descriptor read/64, error -71
[ 33.414105] usb 1-2: device descriptor read/64, error -71
[ 33.525925] usb usb1-port2: unable to enumerate USB device
[ 33.793866] usb 1-3: new high-speed USB device number 18 using tegra-xusb
[ 33.794286] usb 1-3: Device not responding to setup address.
[ 34.006247] usb 1-3: Device not responding to setup address.
[ 34.219345] usb 1-3: device not accepting address 18, error -71
[ 34.345938] usb 1-3: new high-speed USB device number 19 using tegra-xusb
[ 34.346354] usb 1-3: Device not responding to setup address.
[ 34.558261] usb 1-3: Device not responding to setup address.
[ 34.769867] usb 1-3: device not accepting address 19, error -71
[ 34.776026] usb usb1-port3: attempt power cycle
[ 37.141857] usb 1-2: new high-speed USB device number 21 using tegra-xusb
[ 37.142251] usb 1-2: Device not responding to setup address.
[ 37.354244] usb 1-2: Device not responding to setup address.
[ 37.569871] usb 1-2: device not accepting address 21, error -71
[ 37.693896] usb 1-2: new high-speed USB device number 22 using tegra-xusb
[ 37.694288] usb 1-2: Device not responding to setup address.
[ 37.907233] usb 1-2: Device not responding to setup address.
[ 38.117881] usb 1-2: device not accepting address 22, error -71
[ 38.124140] usb usb1-port2: attempt power cycle
[ 38.977861] usb 1-2: new high-speed USB device number 23 using tegra-xusb
[ 39.098053] usb 1-2: device descriptor read/64, error -71
[ 39.330114] usb 1-2: device descriptor read/64, error -71
[ 39.565918] usb 1-2: new high-speed USB device number 24 using tegra-xusb
[ 39.686086] usb 1-2: device descriptor read/64, error -71
[ 39.918141] usb 1-2: device descriptor read/64, error -71
[ 40.030096] usb usb1-port2: unable to enumerate USB device
[ 42.042079] usb usb1: usb_suspend_both: status 0
[ 42.042100] tegra-xusb 70090000.xusb: entering ELPG
[ 42.043356] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 1, speed 0
[ 42.043603] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 2, speed 0
[ 42.045246] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 42.045268] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 2
[ 42.045353] tegra-xusb 70090000.xusb: entering ELPG done
[ 42.055086] tegra-xusb 70090000.xusb: exiting ELPG
[ 42.058883] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 42.059169] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 0
[ 42.059205] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 1
[ 42.059247] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 2
[ 42.059868] tegra-xusb 70090000.xusb: exiting ELPG done
[ 42.060144] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 42.289903] usb 1-2: new high-speed USB device number 25 using tegra-xusb
[ 42.290392] usb 1-2: Device not responding to setup address.
[ 42.502472] usb 1-2: Device not responding to setup address.
[ 42.714010] usb 1-2: device not accepting address 25, error -71
[ 42.838027] usb 1-2: new high-speed USB device number 26 using tegra-xusb
[ 42.838516] usb 1-2: Device not responding to setup address.
[ 43.050502] usb 1-2: Device not responding to setup address.
[ 43.261902] usb 1-2: device not accepting address 26, error -71
[ 43.268021] usb usb1-port2: attempt power cycle
[ 44.118030] usb 1-2: new high-speed USB device number 27 using tegra-xusb
[ 44.238286] usb 1-2: device descriptor read/64, error -71
[ 44.474292] usb 1-2: device descriptor read/64, error -71
[ 44.706016] usb 1-2: new high-speed USB device number 28 using tegra-xusb
[ 44.826127] usb 1-2: device descriptor read/64, error -71
[ 45.066146] usb 1-2: device descriptor read/64, error -71
[ 45.182492] usb usb1-port2: unable to enumerate USB device
[ 47.190187] usb usb1: usb_suspend_both: status 0
[ 47.190242] tegra-xusb 70090000.xusb: entering ELPG
[ 47.191614] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 1, speed 0
[ 47.192002] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 2, speed 0
[ 47.194435] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 47.194719] tegra-xusb 70090000.xusb: entering ELPG done
[ 47.203443] tegra-xusb 70090000.xusb: exiting ELPG
[ 47.208219] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 47.208618] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 0
[ 47.208716] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 1
[ 47.208811] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 2
[ 47.209541] tegra-xusb 70090000.xusb: exiting ELPG done
[ 47.210450] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 47.438105] usb 1-2: new high-speed USB device number 29 using tegra-xusb
[ 47.438720] usb 1-2: Device not responding to setup address.
[ 47.650691] usb 1-2: Device not responding to setup address.
[ 47.861986] usb 1-2: device not accepting address 29, error -71
[ 47.986031] usb 1-2: new high-speed USB device number 30 using tegra-xusb
[ 47.986546] usb 1-2: Device not responding to setup address.
[ 48.198685] usb 1-2: Device not responding to setup address.
[ 48.409999] usb 1-2: device not accepting address 30, error -71
[ 48.416241] usb usb1-port2: attempt power cycle
[ 49.266110] usb 1-2: new high-speed USB device number 31 using tegra-xusb
[ 49.386608] usb 1-2: device descriptor read/64, error -71
[ 49.618456] usb 1-2: device descriptor read/64, error -71
[ 49.850210] usb 1-2: new high-speed USB device number 32 using tegra-xusb
[ 49.970712] usb 1-2: device descriptor read/64, error -71
[ 50.202698] usb 1-2: device descriptor read/64, error -71
[ 50.314528] usb usb1-port2: unable to enumerate USB device
[ 50.582123] usb 1-2: new high-speed USB device number 33 using tegra-xusb
[ 50.582716] usb 1-2: Device not responding to setup address.
[ 50.794565] usb 1-2: Device not responding to setup address.
[ 51.005948] usb 1-2: device not accepting address 33, error -71
[ 51.134005] usb 1-2: new high-speed USB device number 34 using tegra-xusb
[ 51.134513] usb 1-2: Device not responding to setup address.
[ 51.346367] usb 1-2: Device not responding to setup address.
[ 51.557996] usb 1-2: device not accepting address 34, error -71
[ 51.564351] usb usb1-port2: attempt power cycle
[ 52.414189] usb 1-2: new high-speed USB device number 35 using tegra-xusb
[ 52.534594] usb 1-2: device descriptor read/64, error -71
[ 52.766680] usb 1-2: device descriptor read/64, error -71
[ 52.997967] usb 1-2: new high-speed USB device number 36 using tegra-xusb
[ 53.118332] usb 1-2: device descriptor read/64, error -71
[ 53.350472] usb 1-2: device descriptor read/64, error -71
[ 53.462186] usb usb1-port2: unable to enumerate USB device
[ 53.730199] usb 1-2: new high-speed USB device number 37 using tegra-xusb
[ 53.730903] usb 1-2: Device not responding to setup address.
[ 53.942698] usb 1-2: Device not responding to setup address.
[ 54.153977] usb 1-2: device not accepting address 37, error -71
[ 54.277993] usb 1-2: new high-speed USB device number 38 using tegra-xusb
[ 54.278671] usb 1-2: Device not responding to setup address.
[ 54.490714] usb 1-2: Device not responding to setup address.
[ 54.702158] usb 1-2: device not accepting address 38, error -71
[ 54.708404] usb usb1-port2: attempt power cycle
[ 58.994180] usb usb1: usb_suspend_both: status 0
[ 58.994238] tegra-xusb 70090000.xusb: entering ELPG
[ 58.995609] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 1, speed 0
[ 58.995997] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 2, speed 0
[ 58.998086] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 58.998317] tegra-xusb 70090000.xusb: entering ELPG done
[ 59.007454] tegra-xusb 70090000.xusb: exiting ELPG
[ 59.012416] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 59.012814] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 0
[ 59.012912] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 1
[ 59.013006] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 2
[ 59.013735] tegra-xusb 70090000.xusb: exiting ELPG done
[ 61.014105] tegra-xusb 70090000.xusb: entering ELPG
[ 61.015427] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 1, speed 0
[ 61.015773] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 2, speed 0
[ 61.017767] tegra-xusb 70090000.xusb: entering ELPG done
[ 61.027074] tegra-xusb 70090000.xusb: exiting ELPG
[ 61.031137] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 61.031467] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 0
[ 61.031534] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 1
[ 61.031599] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 2
[ 61.032259] tegra-xusb 70090000.xusb: exiting ELPG done
[ 63.034592] tegra-xusb 70090000.xusb: entering ELPG
[ 63.036171] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 1, speed 0
[ 63.036983] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 2, speed 0
[ 63.042133] tegra-xusb 70090000.xusb: entering ELPG done
[ 63.047896] tegra-xusb 70090000.xusb: exiting ELPG
[ 63.054289] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 63.054836] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 0
[ 63.055028] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 1
[ 63.055214] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 2
[ 63.056034] tegra-xusb 70090000.xusb: exiting ELPG done
[ 65.058196] tegra-xusb 70090000.xusb: entering ELPG
[ 65.059642] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 1, speed 0
[ 65.060340] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 2, speed 0
[ 65.063710] tegra-xusb 70090000.xusb: entering ELPG done
[ 65.071547] tegra-xusb 70090000.xusb: exiting ELPG
[ 65.076186] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 65.076660] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 0
[ 65.076758] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 1
[ 65.076852] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 2
[ 65.077580] tegra-xusb 70090000.xusb: exiting ELPG done
[ 67.077988] tegra-xusb 70090000.xusb: entering ELPG
[ 67.079313] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 1, speed 0
[ 67.079625] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 2, speed 0
[ 67.081634] tegra-xusb 70090000.xusb: entering ELPG done
[ 67.091078] tegra-xusb 70090000.xusb: exiting ELPG
[ 67.095221] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 67.095552] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 0
[ 67.095619] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 1
[ 67.095685] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 2
[ 67.096371] tegra-xusb 70090000.xusb: exiting ELPG done
[ 69.098183] tegra-xusb 70090000.xusb: entering ELPG
[ 69.099576] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 1, speed 0
[ 69.099887] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 2, speed 0
[ 69.102029] tegra-xusb 70090000.xusb: entering ELPG done
[ 69.111185] tegra-xusb 70090000.xusb: exiting ELPG
[ 69.114997] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 69.115325] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 0
[ 69.115391] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 1
[ 69.115456] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 2
[ 69.116115] tegra-xusb 70090000.xusb: exiting ELPG done
[ 71.118499] tegra-xusb 70090000.xusb: entering ELPG
[ 71.120029] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 1, speed 0
[ 71.120617] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 2, speed 0
[ 71.125278] tegra-xusb 70090000.xusb: entering ELPG done
[ 71.132018] tegra-xusb 70090000.xusb: exiting ELPG
[ 71.138636] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 71.139152] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 0
[ 71.139343] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 1
[ 71.139529] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 2
[ 71.140387] tegra-xusb 70090000.xusb: exiting ELPG done
[ 73.142098] tegra-xusb 70090000.xusb: entering ELPG
[ 73.143455] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 1, speed 0
[ 73.143792] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 2, speed 0
[ 73.145740] tegra-xusb 70090000.xusb: entering ELPG done
[ 73.155214] tegra-xusb 70090000.xusb: exiting ELPG
[ 73.159424] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 73.159769] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 0
[ 73.159836] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 1
[ 73.159902] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 2
[ 73.160598] tegra-xusb 70090000.xusb: exiting ELPG done
[ 75.162192] tegra-xusb 70090000.xusb: entering ELPG
[ 75.163562] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 1, speed 0
[ 75.163947] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 2, speed 0
[ 75.166547] tegra-xusb 70090000.xusb: entering ELPG done
[ 75.175329] tegra-xusb 70090000.xusb: exiting ELPG
[ 75.180379] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 75.180716] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 0
[ 75.180798] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 1
[ 75.180869] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 2
[ 75.181577] tegra-xusb 70090000.xusb: exiting ELPG done
[ 77.182301] tegra-xusb 70090000.xusb: entering ELPG
[ 77.183749] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 1, speed 0
[ 77.184128] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 2, speed 0
[ 77.187403] tegra-xusb 70090000.xusb: entering ELPG done
[ 77.195245] tegra-xusb 70090000.xusb: exiting ELPG
[ 77.199584] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 77.199924] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 0
[ 77.199994] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 1
[ 77.200060] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 2
[ 77.200748] tegra-xusb 70090000.xusb: exiting ELPG done
[ 79.204517] tegra-xusb 70090000.xusb: entering ELPG
[ 79.206165] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 1, speed 0
[ 79.206613] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 2, speed 0
[ 79.209012] tegra-xusb 70090000.xusb: entering ELPG done
[ 79.217456] tegra-xusb 70090000.xusb: exiting ELPG
[ 79.222002] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 79.222337] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 0
[ 79.222417] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 1
[ 79.222488] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 2
[ 79.223163] tegra-xusb 70090000.xusb: exiting ELPG done
[ 82.034151] tegra-xusb 70090000.xusb: entering ELPG
[ 82.035481] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 1, speed 0
[ 82.035792] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 2, speed 0
[ 82.037754] tegra-xusb 70090000.xusb: entering ELPG done
[ 82.047232] tegra-xusb 70090000.xusb: exiting ELPG
[ 82.051368] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 82.051696] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 0
[ 82.051763] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 1
[ 82.051829] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 2
[ 82.052528] tegra-xusb 70090000.xusb: exiting ELPG done
[ 84.054497] tegra-xusb 70090000.xusb: entering ELPG
[ 84.056029] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 1, speed 0
[ 84.056615] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 2, speed 0
[ 84.060392] tegra-xusb 70090000.xusb: entering ELPG done
[ 84.068022] tegra-xusb 70090000.xusb: exiting ELPG
[ 84.074483] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 84.074987] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 0
[ 84.075177] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 1
[ 84.075364] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 2
[ 84.076284] tegra-xusb 70090000.xusb: exiting ELPG done
[ 86.078025] tegra-xusb 70090000.xusb: entering ELPG
[ 86.079399] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 1, speed 0
[ 86.079784] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 2, speed 0
[ 86.082100] tegra-xusb 70090000.xusb: entering ELPG done
[ 86.091170] tegra-xusb 70090000.xusb: exiting ELPG
[ 86.095885] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 86.096247] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 0
[ 86.096344] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 1
[ 86.096438] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 2
[ 86.097164] tegra-xusb 70090000.xusb: exiting ELPG done
[ 88.098183] tegra-xusb 70090000.xusb: entering ELPG
[ 88.099557] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 1, speed 0
[ 88.099943] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 2, speed 0
[ 88.102561] tegra-xusb 70090000.xusb: entering ELPG done
[ 88.111394] tegra-xusb 70090000.xusb: exiting ELPG
[ 88.116109] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 88.116451] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 0
[ 88.116527] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 1
[ 88.116596] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 2
[ 88.117314] tegra-xusb 70090000.xusb: exiting ELPG done
[ 90.117955] tegra-xusb 70090000.xusb: entering ELPG
[ 90.119195] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 1, speed 0
[ 90.119409] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 2, speed 0
[ 90.121028] tegra-xusb 70090000.xusb: entering ELPG done
[ 90.130845] tegra-xusb 70090000.xusb: exiting ELPG
[ 90.133892] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 90.134175] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 0
[ 90.134203] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 1
[ 90.134228] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 2
[ 90.134840] tegra-xusb 70090000.xusb: exiting ELPG done
[ 92.138482] tegra-xusb 70090000.xusb: entering ELPG
[ 92.140019] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 1, speed 0
[ 92.140606] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 2, speed 0
[ 92.145331] tegra-xusb 70090000.xusb: entering ELPG done
[ 92.151671] tegra-xusb 70090000.xusb: exiting ELPG
[ 92.158385] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 92.158943] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 0
[ 92.159134] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 1
[ 92.159319] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 2
[ 92.160237] tegra-xusb 70090000.xusb: exiting ELPG done
[ 94.162108] tegra-xusb 70090000.xusb: entering ELPG
[ 94.163647] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 1, speed 0
[ 94.164130] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 2, speed 0
[ 94.167328] tegra-xusb 70090000.xusb: entering ELPG done
[ 94.175192] tegra-xusb 70090000.xusb: exiting ELPG
[ 94.180524] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 94.180908] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 0
[ 94.181030] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 1
[ 94.181126] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 2
[ 94.182093] tegra-xusb 70090000.xusb: exiting ELPG done
[ 96.185901] tegra-xusb 70090000.xusb: entering ELPG
[ 96.187120] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 1, speed 0
[ 96.187310] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 2, speed 0
[ 96.188875] tegra-xusb 70090000.xusb: entering ELPG done
[ 96.198735] tegra-xusb 70090000.xusb: exiting ELPG
[ 96.201888] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 96.202162] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 0
[ 96.202183] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 1
[ 96.202202] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 2
[ 96.202811] tegra-xusb 70090000.xusb: exiting ELPG done
[ 98.205865] tegra-xusb 70090000.xusb: entering ELPG
[ 98.207707] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 1, speed 0
[ 98.207924] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 2, speed 0
[ 98.209807] tegra-xusb 70090000.xusb: entering ELPG done
[ 98.219306] tegra-xusb 70090000.xusb: exiting ELPG
[ 98.222979] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 98.223248] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 0
[ 98.223273] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 1
[ 98.223296] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 2
[ 98.223913] tegra-xusb 70090000.xusb: exiting ELPG done
