I also found a similar solution yesterday. When I was processing the audio encoding format, I missed the step of /32768.0. Thank you for your reply. The problem has been resolved
Related topics
| Distorted audio stream from python to stream player | 2 | 453 | May 1, 2024 | |
| Noise issue when playing live lipsync using headless mode in unreal | 6 | 880 | January 11, 2024 | |
| Audio2Face headless background play issue | 11 | 1203 | April 28, 2024 | |
| Unreal audio2face live lipsync sound noise problem | 4 | 703 | February 1, 2024 | |
| Audio2Face + Live Link + Pixel Streaming | 34 | 4641 | April 6, 2024 | |
| Issue with data type from the Riva client to Audio2face(2022.2.1) | 1 | 612 | October 17, 2023 | |
| Can Audio2Face input a streamed audio via some port as if PCM or similar instead of using processed WAV files | 1 | 439 | November 14, 2023 | |
| Integrating ElevenLabs API with Audio2Face: Issues with Sample Rate and Buffer Size | 13 | 1886 | February 26, 2024 | |
| Audio2Face Streaming Proto File | 2 | 552 | May 22, 2024 | |
| StreamLiveLink - Slow motion audio in Unreal 5.2 | 8 | 598 | March 12, 2024 |
