On TX2 Gstreamer RTP generate SDP file used by VLC
I want to use gstreamer stream the video to vlc player by h264 and h265.
I have use command
gst-launch-1.0 -v v4l2src device=/dev/video0 ! "video/x-raw, format=(string)UYVY, width=(int)1920, height=(int)1080" ! nvvidconv ! "video/x-raw(memory:NVMM), format=(string)I420, width=(int)1920, height=(int)1080" ! omxh264enc ! rtph264pay mtu=60000 sprop-parameter-sets=1 ! udpsink clients=192.168.1.105:3221 sync=false
stream the video to my client.
the log is "
Setting pipeline to PAUSED ...
Inside NvxLiteH264DecoderLowLatencyInitNvxLiteH264DecoderLowLatencyInit set DPB and MjstreamingInside NvxLiteH265DecoderLowLatencyInitNvxLiteH265DecoderLowLatencyInit set DPB and MjstreamingPipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
/GstPipeline:pipeline0/GstV4l2Src:v4l2src0.GstPad:src: caps = "video/x-raw\,\ format\=\(string\)UYVY\,\ width\=\(int\)1920\,\ height\=\(int\)1080\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ interlace-mode\=\(string\)progressive\,\ colorimetry\=\(string\)2:4:7:1\,\ framerate\=\(fraction\)30/1"
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = "video/x-raw\,\ format\=\(string\)UYVY\,\ width\=\(int\)1920\,\ height\=\(int\)1080\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ interlace-mode\=\(string\)progressive\,\ colorimetry\=\(string\)2:4:7:1\,\ framerate\=\(fraction\)30/1"
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:src: caps = "video/x-raw\(memory:NVMM\)\,\ width\=\(int\)1920\,\ height\=\(int\)1080\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ interlace-mode\=\(string\)progressive\,\ framerate\=\(fraction\)30/1\,\ format\=\(string\)I420"
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:src: caps = "video/x-raw\(memory:NVMM\)\,\ width\=\(int\)1920\,\ height\=\(int\)1080\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ interlace-mode\=\(string\)progressive\,\ framerate\=\(fraction\)30/1\,\ format\=\(string\)I420"
Framerate set to : 30 at NvxVideoEncoderSetParameterNvMMLiteOpen : Block : BlockType = 4
===== MSENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
/GstPipeline:pipeline0/GstOMXH264Enc-omxh264enc:omxh264enc-omxh264enc0.GstPad:sink: caps = "video/x-raw\(memory:NVMM\)\,\ width\=\(int\)1920\,\ height\=\(int\)1080\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ interlace-mode\=\(string\)progressive\,\ framerate\=\(fraction\)30/1\,\ format\=\(string\)I420"
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:sink: caps = "video/x-raw\(memory:NVMM\)\,\ width\=\(int\)1920\,\ height\=\(int\)1080\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ interlace-mode\=\(string\)progressive\,\ framerate\=\(fraction\)30/1\,\ format\=\(string\)I420"
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:sink: caps = "video/x-raw\,\ format\=\(string\)UYVY\,\ width\=\(int\)1920\,\ height\=\(int\)1080\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ interlace-mode\=\(string\)progressive\,\ colorimetry\=\(string\)2:4:7:1\,\ framerate\=\(fraction\)30/1"
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = "video/x-raw\,\ format\=\(string\)UYVY\,\ width\=\(int\)1920\,\ height\=\(int\)1080\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ interlace-mode\=\(string\)progressive\,\ colorimetry\=\(string\)2:4:7:1\,\ framerate\=\(fraction\)30/1"
===== MSENC blits (mode: 1) into tiled surfaces =====
/GstPipeline:pipeline0/GstOMXH264Enc-omxh264enc:omxh264enc-omxh264enc0.GstPad:src: caps = "video/x-h264\,\ alignment\=\(string\)au\,\ stream-format\=\(string\)avc\,\ width\=\(int\)1920\,\ height\=\(int\)1080\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ framerate\=\(fraction\)30/1"
/GstPipeline:pipeline0/GstRtpH264Pay:rtph264pay0.GstPad:sink: caps = "video/x-h264\,\ alignment\=\(string\)au\,\ stream-format\=\(string\)avc\,\ width\=\(int\)1920\,\ height\=\(int\)1080\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ framerate\=\(fraction\)30/1"
/GstPipeline:pipeline0/GstOMXH264Enc-omxh264enc:omxh264enc-omxh264enc0.GstPad:src: caps = "video/x-h264\,\ alignment\=\(string\)au\,\ stream-format\=\(string\)avc\,\ width\=\(int\)1920\,\ height\=\(int\)1080\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ framerate\=\(fraction\)30/1\,\ codec_data\=\(buffer\)014240150301000b6742403495a01e0089f95001000468ce3c80"
/GstPipeline:pipeline0/GstRtpH264Pay:rtph264pay0.GstPad:src: caps = "application/x-rtp\,\ media\=\(string\)video\,\ clock-rate\=\(int\)90000\,\ encoding-name\=\(string\)H264\,\ packetization-mode\=\(string\)1\,\ profile-level-id\=\(string\)424015\,\ sprop-parameter-sets\=\(string\)\"Z0JANJWgHgCJ+VA\\=\\,aM48gA\\=\\=\"\,\ payload\=\(int\)96\,\ ssrc\=\(uint\)2087407382\,\ timestamp-offset\=\(uint\)443249997\,\ seqnum-offset\=\(uint\)31416\,\ a-framerate\=\(string\)30"
/GstPipeline:pipeline0/GstUDPSink:udpsink0.GstPad:sink: caps = "application/x-rtp\,\ media\=\(string\)video\,\ clock-rate\=\(int\)90000\,\ encoding-name\=\(string\)H264\,\ packetization-mode\=\(string\)1\,\ profile-level-id\=\(string\)424015\,\ sprop-parameter-sets\=\(string\)\"Z0JANJWgHgCJ+VA\\=\\,aM48gA\\=\\=\"\,\ payload\=\(int\)96\,\ ssrc\=\(uint\)2087407382\,\ timestamp-offset\=\(uint\)443249997\,\ seqnum-offset\=\(uint\)31416\,\ a-framerate\=\(string\)30"
/GstPipeline:pipeline0/GstRtpH264Pay:rtph264pay0.GstPad:sink: caps = "video/x-h264\,\ alignment\=\(string\)au\,\ stream-format\=\(string\)avc\,\ width\=\(int\)1920\,\ height\=\(int\)1080\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ framerate\=\(fraction\)30/1\,\ codec_data\=\(buffer\)014240150301000b6742403495a01e0089f95001000468ce3c80"
/GstPipeline:pipeline0/GstRtpH264Pay:rtph264pay0: timestamp = 443315786
/GstPipeline:pipeline0/GstRtpH264Pay:rtph264pay0: seqnum = 31416
You can see that although i use the sprop-parameter-sets=1
in rtph264pay, but the gst-log show the GstPipeline:pipeline0/GstUDPSink:udpsink0 is "sprop-parameter-sets=(string)"Z0JANJWgHgCJ+VA\=\,aM48gA\=\=""
And the client want to use VLC player play the video,So it need the sdp file. I tried the https://en.wikipedia.org/wiki/Session_Description_Protocol#Attributes
and the sdp file
v=0
o=- 1208520720 2590316915 IN IP4 127.0.0.1
s= no name
c=IN IP4 127.0.0.1
t=0 0
m=video 3221 RTP/AVP 96
a=rtpmap:96 H264/90000
a=fmtp:96 media=video; clock-rate=90000; encoding-name=H264; sprop-parameter-sets=Z0JANJWgHgCJ+VA=,aM48gA==;
a=control:trackID=1
the vlc command is
"cvlc -vvv h264.sdp "
the log is
VLC media player 2.2.2 Weatherwax (revision 2.2.2-0-g6259d80)
[0000000001ff2098] core libvlc debug: VLC media player - 2.2.2 Weatherwax
[0000000001ff2098] core libvlc debug: Copyright © 1996-2016 the VideoLAN team
[0000000001ff2098] core libvlc debug: revision 2.2.2-0-g6259d80
[0000000001ff2098] core libvlc debug: configured with ./configure  '--build=x86_64-linux-gnu' '--prefix=/usr' '--includedir=${prefix}/include' '--mandir=${prefix}/share/man' '--infodir=${prefix}/share/info' '--sysconfdir=/etc' '--localstatedir=/var' '--disable-silent-rules' '--libdir=${prefix}/lib/x86_64-linux-gnu' '--libexecdir=${prefix}/lib/x86_64-linux-gnu' '--disable-maintainer-mode' '--disable-dependency-tracking' '--config-cache' '--disable-update-check' '--enable-fast-install' '--docdir=/usr/share/doc/vlc-data' '--libdir=/usr/lib' '--with-binary-version=2.2.2-5ubuntu0.16.04.4' '--enable-a52' '--enable-aa' '--enable-bluray' '--enable-bonjour' '--enable-caca' '--enable-chromaprint' '--enable-dbus' '--enable-dca' '--enable-directfb' '--enable-dvbpsi' '--enable-dvdnav' '--enable-faad' '--enable-flac' '--enable-fluidsynth' '--enable-freerdp' '--enable-freetype' '--enable-fribidi' '--disable-gles1' '--enable-gles2' '--enable-gnutls' '--enable-jack' '--enable-kate' '--enable-libass' '--enable-libmpeg2' '--enable-libxml2' '--enable-lirc' '--enable-live555' '--enable-mad' '--enable-mkv' '--enable-mod' '--enable-mpc' '--enable-mtp' '--enable-mux_ogg' '--enable-ncurses' '--enable-notify' '--enable-ogg' '--enable-opus' '--enable-pulse' '--enable-qt' '--enable-realrtsp' '--enable-samplerate' '--enable-schroedinger' '--enable-sdl' '--enable-sdl-image' '--enable-sftp' '--enable-shine' '--enable-shout' '--enable-skins2' '--enable-speex' '--enable-svg' '--enable-svgdec' '--enable-taglib' '--enable-theora' '--enable-twolame' '--enable-upnp' '--enable-vcdx' '--enable-vdpau' '--enable-vnc' '--enable-vorbis' '--enable-x264' '--enable-x265' '--enable-zvbi' '--with-kde-solid=/usr/share/kde4/apps/solid/actions/' '--disable-decklink' '--disable-dxva2' '--disable-fdkaac' '--disable-gnomevfs' '--disable-goom' '--disable-libtar' '--disable-mfx' '--disable-opencv' '--disable-projectm' '--disable-sndio' '--disable-telx' '--disable-vpx' '--disable-vsxu' '--disable-wasapi' '--enable-alsa' '--enable-atmo' '--enable-dc1394' '--enable-dv1394' '--enable-linsys' '--enable-omxil' '--enable-udev' '--enable-v4l2' '--enable-libva' '--enable-vcd' '--enable-smbclient' '--disable-oss' '--enable-crystalhd' '--enable-mmx' '--enable-sse' '--disable-neon' '--disable-altivec' 'build_alias=x86_64-linux-gnu' 'CFLAGS=-g -O2 -fstack-protector-strong -Wformat -Werror=format-security ' 'LDFLAGS=-Wl,-Bsymbolic-functions -Wl,-z,relro -Wl,--as-needed' 'CPPFLAGS=-Wdate-time -D_FORTIFY_SOURCE=2' 'CXXFLAGS=-g -O2 -fstack-protector-strong -Wformat -Werror=format-security ' 'OBJCFLAGS=-g -O2 -fstack-protector-strong -Wformat -Werror=format-security'
[0000000001ff2098] core libvlc debug: searching plug-in modules
[0000000001ff2098] core libvlc debug: loading plugins cache file /usr/lib/vlc/plugins/plugins.dat
[0000000001ff2098] core libvlc debug: recursively browsing `/usr/lib/vlc/plugins'
[0000000001ff2098] core libvlc debug: saving plugins cache /usr/lib/vlc/plugins/plugins.dat
[0000000001ff2098] core libvlc debug: plug-ins loaded: 465 modules
[0000000001ff2098] core libvlc debug: opening config file (/home/shan/.config/vlc/vlcrc)
[0000000001ff2098] core libvlc debug: translation test: code is "C"
[0000000001ff2098] core libvlc debug: CPU has capabilities MMX MMXEXT SSE SSE2 SSE3 SSSE3 SSE4.1 SSE4.2 AVX AVX FPU
[00000000020c3358] core input debug: Creating an input for 'Media Library'
[00000000020c3358] core input debug: Input is a meta file: disabling unneeded options
[00000000020c3358] core input debug: using timeshift granularity of 50 MiB, in path '/tmp'
[00000000020c3358] core input debug: `file/xspf-open:///home/shan/.local/share/vlc/ml.xspf' gives access `file' demux `xspf-open' path `/home/shan/.local/share/vlc/ml.xspf'
[00000000020c3358] core input debug: creating demux: access='file' demux='xspf-open' location='/home/shan/.local/share/vlc/ml.xspf' file='/home/shan/.local/share/vlc/ml.xspf'
[00000000020c7f68] core demux debug: looking for access_demux module matching "file": 21 candidates
[00000000020c7f68] core demux debug: no access_demux modules matched
[00000000020c3358] core input debug: creating access 'file' location='/home/shan/.local/share/vlc/ml.xspf', path='/home/shan/.local/share/vlc/ml.xspf'
[00000000020c7f68] core access debug: looking for access module matching "file": 25 candidates
[00000000020c7f68] filesystem access debug: opening file `/home/shan/.local/share/vlc/ml.xspf'
[00000000020c7f68] core access debug: using access module "filesystem"
[00000000020ef698] core stream debug: Using stream method for AStream*
[00000000020ef698] core stream debug: starting pre-buffering
[00000000020ef698] core stream debug: received first data after 0 ms
[00000000020ef698] core stream debug: pre-buffering done 296 bytes in 0s - 26278 KiB/s
[00000000020ef8f8] core stream debug: looking for stream_filter module matching "any": 9 candidates
[00000000020ef8f8] core stream debug: no stream_filter modules matched
[00000000020ef8f8] core stream debug: looking for stream_filter module matching "record": 9 candidates
[00000000020ef8f8] core stream debug: using stream_filter module "record"
[00000000020f2898] core demux debug: looking for demux module matching "xspf-open": 66 candidates
[00000000020f2898] xspf demux debug: using XSPF playlist reader
[00000000020f2898] core demux debug: using demux module "playlist"
[00000000020f3298] core demux meta debug: looking for meta reader module matching "any": 2 candidates
[00000000020f3298] lua demux meta debug: Trying Lua scripts in /home/shan/.local/share/vlc/lua/meta/reader
[00000000020f3298] lua demux meta debug: Trying Lua scripts in /usr/lib/vlc/lua/meta/reader
[00000000020f3298] lua demux meta debug: Trying Lua playlist script /usr/lib/vlc/lua/meta/reader/filename.luac
[00000000020f3298] lua demux meta debug: Trying Lua scripts in /usr/share/vlc/lua/meta/reader
[00000000020f3298] core demux meta debug: no meta reader modules matched
[00000000020c3358] core input debug: `file/xspf-open:///home/shan/.local/share/vlc/ml.xspf' successfully opened
[0000000002105e08] core xml reader debug: looking for xml reader module matching "any": 1 candidates
[0000000002105e08] core xml reader debug: using xml reader module "xml"
[00000000020f2898] xspf demux debug: parsed 0 tracks successfully
[00000000020c3358] core input debug: EOF reached
[00000000020f2898] core demux debug: removing module "playlist"
[00000000020ef8f8] core stream debug: removing module "record"
[00000000020c7f68] core access debug: removing module "filesystem"
[00000000020065a8] core playlist debug: creating audio output
[00000000020ef698] core audio output debug: looking for audio output module matching "any": 6 candidates
[00000000020ef698] pulse audio output debug: using library version 8.0.0
[00000000020ef698] pulse audio output debug:  (compiled with version 8.0.0, protocol 30)
[00000000020ef698] pulse audio output debug: connected locally to unix:/run/user/1000/pulse/native as client #93
[00000000020ef698] pulse audio output debug: using protocol 30, server protocol 30
[00000000020ef698] pulse audio output debug: adding sink 0: alsa_output.pci-0000_00_1f.3.analog-stereo (Built-in Audio Analog Stereo)
[00000000020ef698] core audio output debug: using audio output module "pulse"
[00000000020065a8] core playlist debug: keeping audio output
[00000000020065a8] core playlist debug: adding item `h264.sdp' ( file:///home/shan/Desktop/h264.sdp )
[00007fcc4c000958] core input debug: Creating an input for 'h264.sdp'
[0000000002101c18] core interface debug: looking for interface module matching "hotkeys,none": 19 candidates
[0000000002101c18] core interface debug: using interface module "hotkeys"
[00000000021024a8] core interface debug: looking for interface module matching "globalhotkeys,none": 19 candidates
[00000000021024a8] core interface debug: using interface module "xcb_hotkeys"
[0000000002107548] core interface debug: looking for interface module matching "dbus,none": 19 candidates
[0000000002107548] dbus interface debug: listening on dbus as: org.mpris.MediaPlayer2.vlc
[0000000002107548] core interface debug: using interface module "dbus"
[000000000210ada8] core interface debug: looking for interface module matching "dummy": 19 candidates
[0000000002107548] dbus interface debug: Getting All properties
[000000000210ada8] dummy interface: using the dummy interface module...
[000000000210ada8] core interface debug: using interface module "dummy"
[00000000020065a8] core playlist debug: processing request item: null, node: Playlist, skip: 0
[00000000020065a8] core playlist debug: rebuilding array of current - root Playlist
[00000000020065a8] core playlist debug: rebuild done - 1 items, index -1
[00000000020065a8] core playlist debug: starting playback of the new playlist item
[00000000020065a8] core playlist debug: resyncing on h264.sdp
[00000000020065a8] core playlist debug: h264.sdp is at 0
[00000000020065a8] core playlist debug: creating new input thread
[00007fcc480009b8] core input debug: Creating an input for 'h264.sdp'
[00000000020065a8] core playlist debug: requesting art for h264.sdp
[00007fcc480009b8] core input debug: using timeshift granularity of 50 MiB, in path '/tmp'
[00007fcc480009b8] core input debug: `file:///home/shan/Desktop/h264.sdp' gives access `file' demux `' path `/home/shan/Desktop/h264.sdp'
[00007fcc480009b8] core input debug: specified demux `any'
[00007fcc480009b8] core input debug: creating demux: access='file' demux='any' location='/home/shan/Desktop/h264.sdp' file='/home/shan/Desktop/h264.sdp'
[00007fcc3c000e38] core demux debug: looking for access_demux module matching "file": 21 candidates
[00007fcc3c000e38] core demux debug: no access_demux modules matched
[00007fcc480009b8] core input debug: creating access 'file' location='/home/shan/Desktop/h264.sdp', path='/home/shan/Desktop/h264.sdp'
[00007fcc3c000e38] core access debug: looking for access module matching "file": 25 candidates
[00007fcc3c000e38] filesystem access debug: opening file `/home/shan/Desktop/h264.sdp'
[00007fcc3c000e38] core access debug: using access module "filesystem"
[00007fcc3c0011d8] core stream debug: Using stream method for AStream*
[00007fcc3c0011d8] core stream debug: starting pre-buffering
[00007fcc3c0011d8] core stream debug: received first data after 0 ms
[00007fcc3c0011d8] core stream debug: pre-buffering done 259 bytes in 0s - 8159 KiB/s
[00007fcc3cc01518] core stream debug: looking for stream_filter module matching "any": 9 candidates
[00007fcc3cc01518] core stream debug: no stream_filter modules matched
[00007fcc3cc01518] core stream debug: looking for stream_filter module matching "record": 9 candidates
[00007fcc3cc01518] core stream debug: using stream_filter module "record"
[00007fcc3cc01788] core demux debug: looking for demux module matching "any": 66 candidates
[00007fcc40000958] core art finder debug: looking for meta fetcher module matching "any": 1 candidates
[00007fcc40000958] lua art finder debug: Trying Lua scripts in /home/shan/.local/share/vlc/lua/meta/fetcher
[00007fcc40000958] lua art finder debug: Trying Lua scripts in /usr/lib/vlc/lua/meta/fetcher
[00007fcc40000958] lua art finder debug: Trying Lua playlist script /usr/lib/vlc/lua/meta/fetcher/tvrage.luac
[00007fcc3cc01788] live555 demux debug: version 2016.02.09
[00007fcc3cc01788] live555 demux debug: RTP subsession 'video/H264'
[00007fcc480009b8] core input debug: selecting program id=0
[00007fcc3cc01788] live555 demux debug: setup start: 0.000000 stop:0.000000
[00007fcc3cc01788] live555 demux debug: play start: 0.000000 stop:0.000000
[00007fcc3cc01788] core demux debug: using demux module "live555"
[00007fcc480009b8] core input debug: looking for a subtitle file in /home/shan/Desktop/
[00007fcc3cc204f8] core decoder debug: looking for decoder module matching "any": 44 candidates
[00007fcc40000958] lua art finder debug: skipping script (unmatched scope) /usr/lib/vlc/lua/meta/fetcher/tvrage.luac
[00007fcc40000958] lua art finder debug: Trying Lua scripts in /usr/share/vlc/lua/meta/fetcher
[00007fcc40000958] core art finder debug: no meta fetcher modules matched
[0000000001ff2098] core libvlc debug: searching art for h264.sdp
[00007fcc40000958] core art finder debug: looking for art finder module matching "any": 2 candidates
[00007fcc40000958] lua art finder debug: Trying Lua scripts in /home/shan/.local/share/vlc/lua/meta/art
[00007fcc40000958] lua art finder debug: Trying Lua scripts in /usr/lib/vlc/lua/meta/art
[00007fcc40000958] lua art finder debug: Trying Lua playlist script /usr/lib/vlc/lua/meta/art/00_musicbrainz.luac
[00000000020065a8] core playlist debug: meta ok for (null), need to fetch art
[00007fcc34000958] core art finder debug: looking for meta fetcher module matching "any": 1 candidates
[00007fcc40000958] lua art finder debug: skipping script (unmatched scope) /usr/lib/vlc/lua/meta/art/00_musicbrainz.luac
[00007fcc40000958] lua art finder debug: Trying Lua playlist script /usr/lib/vlc/lua/meta/art/01_googleimage.luac
[00007fcc34000958] lua art finder debug: Trying Lua scripts in /home/shan/.local/share/vlc/lua/meta/fetcher
[00007fcc34000958] lua art finder debug: Trying Lua scripts in /usr/lib/vlc/lua/meta/fetcher
[00007fcc40000958] lua art finder debug: skipping script (unmatched scope) /usr/lib/vlc/lua/meta/art/01_googleimage.luac
[00007fcc40000958] lua art finder debug: Trying Lua playlist script /usr/lib/vlc/lua/meta/art/02_frenchtv.luac
[00007fcc34000958] lua art finder debug: Trying Lua playlist script /usr/lib/vlc/lua/meta/fetcher/tvrage.luac
[00007fcc40000958] lua art finder debug: skipping script (unmatched scope) /usr/lib/vlc/lua/meta/art/02_frenchtv.luac
[00007fcc40000958] lua art finder debug: Trying Lua playlist script /usr/lib/vlc/lua/meta/art/03_lastfm.luac
[00007fcc34000958] lua art finder debug: skipping script (unmatched scope) /usr/lib/vlc/lua/meta/fetcher/tvrage.luac
[00007fcc34000958] lua art finder debug: Trying Lua scripts in /usr/share/vlc/lua/meta/fetcher
[00007fcc34000958] core art finder debug: no meta fetcher modules matched
[00000000020065a8] core playlist debug: searching art for h264.sdp
[00007fcc34000958] core art finder debug: looking for art finder module matching "any": 2 candidates
[00007fcc40000958] lua art finder debug: skipping script (unmatched scope) /usr/lib/vlc/lua/meta/art/03_lastfm.luac
[00007fcc40000958] lua art finder debug: Trying Lua scripts in /usr/share/vlc/lua/meta/art
[00007fcc40000958] core art finder debug: no art finder modules matched
[00007fcc34000958] lua art finder debug: Trying Lua scripts in /home/shan/.local/share/vlc/lua/meta/art
[00007fcc34000958] lua art finder debug: Trying Lua scripts in /usr/lib/vlc/lua/meta/art
[00007fcc34000958] lua art finder debug: Trying Lua playlist script /usr/lib/vlc/lua/meta/art/00_musicbrainz.luac
[00007fcc3cc204f8] avcodec decoder debug: CPU flags: 0x0107d3db
[00007fcc3cc204f8] avcodec decoder debug: trying to use direct rendering
[00007fcc3cc204f8] avcodec decoder debug: allowing 4 thread(s) for decoding
[00007fcc3cc204f8] avcodec decoder debug: avcodec codec (H264 - MPEG-4 AVC (part 10)) started
[00007fcc3cc204f8] avcodec decoder debug: using frame thread mode with 4 threads
[00007fcc3cc204f8] core decoder debug: using decoder module "avcodec"
[00007fcc3cdb7878] core packetizer debug: looking for packetizer module matching "any": 23 candidates
[00007fcc3cdb7878] packetizer_h264 packetizer debug: found NAL_SPS (sps_id=0)
[00007fcc3cdb7878] packetizer_h264 packetizer debug: found NAL_PPS (pps_id=0 sps_id=0)
[00007fcc3cdb7878] core packetizer debug: using packetizer module "packetizer_h264"
[00007fcc3cdbe198] core demux meta debug: looking for meta reader module matching "any": 2 candidates
[00007fcc40000958] core art finder debug: using meta fetcher module "lua"
[00007fcc40000958] core art finder debug: removing module "lua"
[00007fcc3cdbe198] lua demux meta debug: Trying Lua scripts in /home/shan/.local/share/vlc/lua/meta/reader
[00007fcc3cdbe198] lua demux meta debug: Trying Lua scripts in /usr/lib/vlc/lua/meta/reader
[00007fcc3cdbe198] lua demux meta debug: Trying Lua playlist script /usr/lib/vlc/lua/meta/reader/filename.luac
[00007fcc34000958] lua art finder debug: skipping script (unmatched scope) /usr/lib/vlc/lua/meta/art/00_musicbrainz.luac
[00007fcc34000958] lua art finder debug: Trying Lua playlist script /usr/lib/vlc/lua/meta/art/01_googleimage.luac
[00007fcc3cdbe198] lua demux meta debug: Trying Lua scripts in /usr/share/vlc/lua/meta/reader
[00007fcc3cdbe198] core demux meta debug: no meta reader modules matched
[00007fcc480009b8] core input debug: `file:///home/shan/Desktop/h264.sdp' successfully opened
[00007fcc34000958] lua art finder debug: skipping script (unmatched scope) /usr/lib/vlc/lua/meta/art/01_googleimage.luac
[00007fcc34000958] lua art finder debug: Trying Lua playlist script /usr/lib/vlc/lua/meta/art/02_frenchtv.luac
[00007fcc34000958] lua art finder debug: skipping script (unmatched scope) /usr/lib/vlc/lua/meta/art/02_frenchtv.luac
[00007fcc34000958] lua art finder debug: Trying Lua playlist script /usr/lib/vlc/lua/meta/art/03_lastfm.luac
[00007fcc34000958] lua art finder debug: skipping script (unmatched scope) /usr/lib/vlc/lua/meta/art/03_lastfm.luac
[00007fcc34000958] lua art finder debug: Trying Lua scripts in /usr/share/vlc/lua/meta/art
[00007fcc34000958] core art finder debug: no art finder modules matched
[0000000001ff2098] core libvlc debug: art not found for h264.sdp
[00007fcc34000958] core art finder debug: using meta fetcher module "lua"
[00007fcc34000958] core art finder debug: removing module "lua"
[00000000020065a8] core playlist debug: art not found for h264.sdp
[00007fcc3cc01788] live555 demux error: no data received in 10s, aborting
[00007fcc480009b8] core input debug: EOF reached
[00000000020065a8] core playlist debug: finished input
[00007fcc3cc204f8] core decoder debug: removing module "avcodec"
[00007fcc3cc204f8] avcodec decoder debug: ffmpeg codec (H264 - MPEG-4 AVC (part 10)) stopped
[00007fcc3cc204f8] core decoder debug: killing decoder fourcc `h264', 0 PES in FIFO
[00007fcc3cdb7878] core packetizer debug: removing module "packetizer_h264"
[00007fcc3cc01788] core demux debug: removing module "live555"
[00007fcc3cc01518] core stream debug: removing module "record"
[00007fcc3c000e38] core access debug: removing module "filesystem"
[00007fcc480009b8] core input debug: Program doesn't contain anymore ES
[00000000020065a8] core playlist debug: dead input
[00000000020065a8] core playlist debug: changing item without a request (current 0/1)
[00000000020065a8] core playlist debug: nothing to play
^C[0000000001ff2098] core libvlc debug: removing all interfaces
[0000000001ff2098] core libvlc debug: exiting
[000000000210ada8] core interface debug: removing module "dummy"
[0000000002107548] core interface debug: removing module "dbus"
[00000000021024a8] core interface debug: removing module "xcb_hotkeys"
[0000000002101c18] core interface debug: removing module "hotkeys"
[00000000020065a8] core playlist debug: destroying
[00000000020065a8] core playlist debug: deactivating the playlist
[00000000020ef698] core audio output debug: removing module "pulse"
[0000000002108508] core playlist export debug: saving Media Library to file /home/shan/.local/share/vlc/ml.xspf.tmp25504
[0000000002108508] core playlist export debug: looking for playlist export module matching "export-xspf": 4 candidates
[0000000002108508] core playlist export debug: using playlist export module "export"
[0000000002108508] core playlist export debug: removing module "export"
And the "no data received in 10s,aborting " is red in console
To be honest, I have tried lots of ways,like make "udpsink clients=192.168.1.105:3221 sync=true and other type of the sdp file, nothing can make that happen.
I can use the gstreamer command show the stream
gst-launch-1.0 udpsrc port=3221 caps="application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264,sprop-parameter-sets=(string)\"Z0JAMpWgHgCJ+VA\=\,aM48gA\=\=\", payload=(int)96" ! rtph264depay ! decodebin ! autovideosink sync=false
And the H265 is gst command is
gst-launch-1.0 -v v4l2src device=/dev/video1 ! "video/x-raw, format=(string)UYVY, width=(int)1920, height=(int)1080" ! nvvidconv ! "video/x-raw(memory:NVMM), format=(string)I420, width=(int)1920, height=(int)1080,framerate=30/1" ! omxh265enc ! rtph265pay mtu=60000 config-interval=1 sprop-parameter-sets=1 ! udpsink host=192.168.1.105 port=3221 sync=false
The log is
Framerate set to : 30 at NvxVideoEncoderSetParameterNvMMLiteOpen : Block : BlockType = 8
===== MSENC =====
NvMMLiteBlockCreate : Block : BlockType = 8
/GstPipeline:pipeline0/GstOMXH265Enc-omxh265enc:omxh265enc-omxh265enc0.GstPad:sink: caps = "video/x-raw\(memory:NVMM\)\,\ width\=\(int\)1920\,\ height\=\(int\)1080\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ interlace-mode\=\(string\)progressive\,\ framerate\=\(fraction\)30/1\,\ format\=\(string\)I420"
===== NVENC blits (mode: 1) into block linear surfaces =====
/GstPipeline:pipeline0/GstOMXH265Enc-omxh265enc:omxh265enc-omxh265enc0.GstPad:src: caps = "video/x-h265\,\ alignment\=\(string\)au\,\ stream-format\=\(string\)byte-stream\,\ width\=\(int\)1920\,\ height\=\(int\)1080\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ framerate\=\(fraction\)30/1"
/GstPipeline:pipeline0/GstRtpH265Pay:rtph265pay0.GstPad:sink: caps = "video/x-h265\,\ alignment\=\(string\)au\,\ stream-format\=\(string\)byte-stream\,\ width\=\(int\)1920\,\ height\=\(int\)1080\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ framerate\=\(fraction\)30/1"
/GstPipeline:pipeline0/GstRtpH265Pay:rtph265pay0.GstPad:src: caps = "application/x-rtp\,\ media\=\(string\)video\,\ payload\=\(int\)96\,\ clock-rate\=\(int\)90000\,\ encoding-name\=\(string\)H265\,\ ssrc\=\(uint\)564168312\,\ timestamp-offset\=\(uint\)4111680835\,\ seqnum-offset\=\(uint\)12708\,\ a-framerate\=\(string\)30"
/GstPipeline:pipeline0/GstUDPSink:udpsink0.GstPad:sink: caps = "application/x-rtp\,\ media\=\(string\)video\,\ payload\=\(int\)96\,\ clock-rate\=\(int\)90000\,\ encoding-name\=\(string\)H265\,\ ssrc\=\(uint\)564168312\,\ timestamp-offset\=\(uint\)4111680835\,\ seqnum-offset\=\(uint\)12708\,\ a-framerate\=\(string\)30"
/GstPipeline:pipeline0/GstRtpH265Pay:rtph265pay0.GstPad:src: caps = "application/x-rtp\,\ media\=\(string\)video\,\ clock-rate\=\(int\)90000\,\ encoding-name\=\(string\)H265\,\ sprop-parameter-sets\=\(string\)1\,\ payload\=\(int\)96\,\ seqnum-offset\=\(uint\)12708\,\ timestamp-offset\=\(uint\)4111680835\,\ ssrc\=\(uint\)564168312\,\ a-framerate\=\(string\)30"
/GstPipeline:pipeline0/GstUDPSink:udpsink0.GstPad:sink: caps = "application/x-rtp\,\ media\=\(string\)video\,\ clock-rate\=\(int\)90000\,\ encoding-name\=\(string\)H265\,\ sprop-parameter-sets\=\(string\)1\,\ payload\=\(int\)96\,\ seqnum-offset\=\(uint\)12708\,\ timestamp-offset\=\(uint\)4111680835\,\ ssrc\=\(uint\)564168312\,\ a-framerate\=\(string\)30"
/GstPipeline:pipeline0/GstRtpH265Pay:rtph265pay0: timestamp = 4111747341
/GstPipeline:pipeline0/GstRtpH265Pay:rtph265pay0: seqnum = 12708
Question 1
As you can see from the log the sprop-parameter-sets=(string)1\ have been set as i do, but the h264 gst command does not…Why ?
the H265.sdp is
v=0
o=- 0 0 IN IP4 192.168.1.105
s=No Name c=IN IP4 192.168.1.105
t=0 0
a=rtpmap:96 H265/90000;sprop-parameter-sets=1;
the vlc log is
[0000000001b3b098] core libvlc debug: VLC media player - 2.2.2 Weatherwax
[0000000001b3b098] core libvlc debug: Copyright © 1996-2016 the VideoLAN team
[0000000001b3b098] core libvlc debug: revision 2.2.2-0-g6259d80
[0000000001b3b098] core libvlc debug: configured with ./configure  '--build=x86_64-linux-gnu' '--prefix=/usr' '--includedir=${prefix}/include' '--mandir=${prefix}/share/man' '--infodir=${prefix}/share/info' '--sysconfdir=/etc' '--localstatedir=/var' '--disable-silent-rules' '--libdir=${prefix}/lib/x86_64-linux-gnu' '--libexecdir=${prefix}/lib/x86_64-linux-gnu' '--disable-maintainer-mode' '--disable-dependency-tracking' '--config-cache' '--disable-update-check' '--enable-fast-install' '--docdir=/usr/share/doc/vlc-data' '--libdir=/usr/lib' '--with-binary-version=2.2.2-5ubuntu0.16.04.4' '--enable-a52' '--enable-aa' '--enable-bluray' '--enable-bonjour' '--enable-caca' '--enable-chromaprint' '--enable-dbus' '--enable-dca' '--enable-directfb' '--enable-dvbpsi' '--enable-dvdnav' '--enable-faad' '--enable-flac' '--enable-fluidsynth' '--enable-freerdp' '--enable-freetype' '--enable-fribidi' '--disable-gles1' '--enable-gles2' '--enable-gnutls' '--enable-jack' '--enable-kate' '--enable-libass' '--enable-libmpeg2' '--enable-libxml2' '--enable-lirc' '--enable-live555' '--enable-mad' '--enable-mkv' '--enable-mod' '--enable-mpc' '--enable-mtp' '--enable-mux_ogg' '--enable-ncurses' '--enable-notify' '--enable-ogg' '--enable-opus' '--enable-pulse' '--enable-qt' '--enable-realrtsp' '--enable-samplerate' '--enable-schroedinger' '--enable-sdl' '--enable-sdl-image' '--enable-sftp' '--enable-shine' '--enable-shout' '--enable-skins2' '--enable-speex' '--enable-svg' '--enable-svgdec' '--enable-taglib' '--enable-theora' '--enable-twolame' '--enable-upnp' '--enable-vcdx' '--enable-vdpau' '--enable-vnc' '--enable-vorbis' '--enable-x264' '--enable-x265' '--enable-zvbi' '--with-kde-solid=/usr/share/kde4/apps/solid/actions/' '--disable-decklink' '--disable-dxva2' '--disable-fdkaac' '--disable-gnomevfs' '--disable-goom' '--disable-libtar' '--disable-mfx' '--disable-opencv' '--disable-projectm' '--disable-sndio' '--disable-telx' '--disable-vpx' '--disable-vsxu' '--disable-wasapi' '--enable-alsa' '--enable-atmo' '--enable-dc1394' '--enable-dv1394' '--enable-linsys' '--enable-omxil' '--enable-udev' '--enable-v4l2' '--enable-libva' '--enable-vcd' '--enable-smbclient' '--disable-oss' '--enable-crystalhd' '--enable-mmx' '--enable-sse' '--disable-neon' '--disable-altivec' 'build_alias=x86_64-linux-gnu' 'CFLAGS=-g -O2 -fstack-protector-strong -Wformat -Werror=format-security ' 'LDFLAGS=-Wl,-Bsymbolic-functions -Wl,-z,relro -Wl,--as-needed' 'CPPFLAGS=-Wdate-time -D_FORTIFY_SOURCE=2' 'CXXFLAGS=-g -O2 -fstack-protector-strong -Wformat -Werror=format-security ' 'OBJCFLAGS=-g -O2 -fstack-protector-strong -Wformat -Werror=format-security'
[0000000001b3b098] core libvlc debug: searching plug-in modules
[0000000001b3b098] core libvlc debug: loading plugins cache file /usr/lib/vlc/plugins/plugins.dat
[0000000001b3b098] core libvlc debug: recursively browsing `/usr/lib/vlc/plugins'
[0000000001b3b098] core libvlc debug: saving plugins cache /usr/lib/vlc/plugins/plugins.dat
[0000000001b3b098] core libvlc debug: plug-ins loaded: 465 modules
[0000000001b3b098] core libvlc debug: opening config file (/home/shan/.config/vlc/vlcrc)
[0000000001b3b098] core libvlc debug: translation test: code is "C"
[0000000001b3b098] core libvlc debug: CPU has capabilities MMX MMXEXT SSE SSE2 SSE3 SSSE3 SSE4.1 SSE4.2 AVX AVX FPU
[0000000001c0c358] core input debug: Creating an input for 'Media Library'
[0000000001c0c358] core input debug: Input is a meta file: disabling unneeded options
[0000000001c0c358] core input debug: using timeshift granularity of 50 MiB, in path '/tmp'
[0000000001c0c358] core input debug: `file/xspf-open:///home/shan/.local/share/vlc/ml.xspf' gives access `file' demux `xspf-open' path `/home/shan/.local/share/vlc/ml.xspf'
[0000000001c0c358] core input debug: creating demux: access='file' demux='xspf-open' location='/home/shan/.local/share/vlc/ml.xspf' file='/home/shan/.local/share/vlc/ml.xspf'
[0000000001c10f68] core demux debug: looking for access_demux module matching "file": 21 candidates
[0000000001c10f68] core demux debug: no access_demux modules matched
[0000000001c0c358] core input debug: creating access 'file' location='/home/shan/.local/share/vlc/ml.xspf', path='/home/shan/.local/share/vlc/ml.xspf'
[0000000001c10f68] core access debug: looking for access module matching "file": 25 candidates
[0000000001c10f68] filesystem access debug: opening file `/home/shan/.local/share/vlc/ml.xspf'
[0000000001c10f68] core access debug: using access module "filesystem"
[0000000001c38698] core stream debug: Using stream method for AStream*
[0000000001c38698] core stream debug: starting pre-buffering
[0000000001c38698] core stream debug: received first data after 0 ms
[0000000001c38698] core stream debug: pre-buffering done 296 bytes in 0s - 26278 KiB/s
[0000000001c388f8] core stream debug: looking for stream_filter module matching "any": 9 candidates
[0000000001c388f8] core stream debug: no stream_filter modules matched
[0000000001c388f8] core stream debug: looking for stream_filter module matching "record": 9 candidates
[0000000001c388f8] core stream debug: using stream_filter module "record"
[0000000001c3b898] core demux debug: looking for demux module matching "xspf-open": 66 candidates
[0000000001c3b898] xspf demux debug: using XSPF playlist reader
[0000000001c3b898] core demux debug: using demux module "playlist"
[0000000001c3c298] core demux meta debug: looking for meta reader module matching "any": 2 candidates
[0000000001c3c298] lua demux meta debug: Trying Lua scripts in /home/shan/.local/share/vlc/lua/meta/reader
[0000000001c3c298] lua demux meta debug: Trying Lua scripts in /usr/lib/vlc/lua/meta/reader
[0000000001c3c298] lua demux meta debug: Trying Lua playlist script /usr/lib/vlc/lua/meta/reader/filename.luac
[0000000001c3c298] lua demux meta debug: Trying Lua scripts in /usr/share/vlc/lua/meta/reader
[0000000001c3c298] core demux meta debug: no meta reader modules matched
[0000000001c0c358] core input debug: `file/xspf-open:///home/shan/.local/share/vlc/ml.xspf' successfully opened
[0000000001c4ee08] core xml reader debug: looking for xml reader module matching "any": 1 candidates
[0000000001c4ee08] core xml reader debug: using xml reader module "xml"
[0000000001c3b898] xspf demux debug: parsed 0 tracks successfully
[0000000001c0c358] core input debug: EOF reached
[0000000001c3b898] core demux debug: removing module "playlist"
[0000000001c388f8] core stream debug: removing module "record"
[0000000001c10f68] core access debug: removing module "filesystem"
[0000000001b4f5a8] core playlist debug: creating audio output
[0000000001c38698] core audio output debug: looking for audio output module matching "any": 6 candidates
[0000000001c38698] pulse audio output debug: using library version 8.0.0
[0000000001c38698] pulse audio output debug:  (compiled with version 8.0.0, protocol 30)
[0000000001c38698] pulse audio output debug: connected locally to unix:/run/user/1000/pulse/native as client #95
[0000000001c38698] pulse audio output debug: using protocol 30, server protocol 30
[0000000001c38698] pulse audio output debug: adding sink 0: alsa_output.pci-0000_00_1f.3.analog-stereo (Built-in Audio Analog Stereo)
[0000000001c38698] core audio output debug: using audio output module "pulse"
[0000000001b4f5a8] core playlist debug: keeping audio output
[0000000001b4f5a8] core playlist debug: adding item `H265.sdp' ( file:///home/shan/Desktop/H265.sdp )
[00007f99b4000958] core input debug: Creating an input for 'H265.sdp'
[0000000001c4ac18] core interface debug: looking for interface module matching "hotkeys,none": 19 candidates
[0000000001c4ac18] core interface debug: using interface module "hotkeys"
[0000000001c4b4a8] core interface debug: looking for interface module matching "globalhotkeys,none": 19 candidates
[0000000001c4b4a8] core interface debug: using interface module "xcb_hotkeys"
[0000000001c50548] core interface debug: looking for interface module matching "dbus,none": 19 candidates
[0000000001c50548] dbus interface debug: listening on dbus as: org.mpris.MediaPlayer2.vlc
[0000000001c50548] core interface debug: using interface module "dbus"
[0000000001c53da8] core interface debug: looking for interface module matching "dummy": 19 candidates
[0000000001c50548] dbus interface debug: Getting All properties
[0000000001c53da8] dummy interface: using the dummy interface module...
[0000000001c53da8] core interface debug: using interface module "dummy"
[0000000001b4f5a8] core playlist debug: processing request item: null, node: Playlist, skip: 0
[0000000001b4f5a8] core playlist debug: rebuilding array of current - root Playlist
[0000000001b4f5a8] core playlist debug: rebuild done - 1 items, index -1
[0000000001b4f5a8] core playlist debug: starting playback of the new playlist item
[0000000001b4f5a8] core playlist debug: resyncing on H265.sdp
[0000000001b4f5a8] core playlist debug: H265.sdp is at 0
[0000000001b4f5a8] core playlist debug: creating new input thread
[00007f99b00009b8] core input debug: Creating an input for 'H265.sdp'
[0000000001b4f5a8] core playlist debug: requesting art for H265.sdp
[00007f99b00009b8] core input debug: using timeshift granularity of 50 MiB, in path '/tmp'
[00007f99b00009b8] core input debug: `file:///home/shan/Desktop/H265.sdp' gives access `file' demux `' path `/home/shan/Desktop/H265.sdp'
[00007f99b00009b8] core input debug: specified demux `any'
[00007f99b00009b8] core input debug: creating demux: access='file' demux='any' location='/home/shan/Desktop/H265.sdp' file='/home/shan/Desktop/H265.sdp'
[00007f99a4000e38] core demux debug: looking for access_demux module matching "file": 21 candidates
[00007f99a4000e38] core demux debug: no access_demux modules matched
[00007f99b00009b8] core input debug: creating access 'file' location='/home/shan/Desktop/H265.sdp', path='/home/shan/Desktop/H265.sdp'
[00007f99a4000e38] core access debug: looking for access module matching "file": 25 candidates
[00007f99a4000e38] filesystem access debug: opening file `/home/shan/Desktop/H265.sdp'
[00007f99a4000e38] core access debug: using access module "filesystem"
[00007f99a40011d8] core stream debug: Using stream method for AStream*
[00007f99a40011d8] core stream debug: starting pre-buffering
[00007f99a40011d8] core stream debug: received first data after 0 ms
[00007f99a40011d8] core stream debug: pre-buffering done 147 bytes in 0s - 17944 KiB/s
[00007f99a4c01518] core stream debug: looking for stream_filter module matching "any": 9 candidates
[00007f99a4c01518] core stream debug: no stream_filter modules matched
[00007f99a4c01518] core stream debug: looking for stream_filter module matching "record": 9 candidates
[00007f99a4c01518] core stream debug: using stream_filter module "record"
[00007f99a4c01788] core demux debug: looking for demux module matching "any": 66 candidates
[00007f999c000958] core art finder debug: looking for meta fetcher module matching "any": 1 candidates
[00007f99a4c01788] live555 demux debug: version 2016.02.09
[00007f99a4c01788] live555 demux debug: RTP subsession 'video/H265'
[00007f99b00009b8] core input debug: selecting program id=0
[00007f99a4c01788] live555 demux debug: setup start: 0.000000 stop:0.000000
[00007f99a4c01788] live555 demux debug: play start: 0.000000 stop:0.000000
[00007f99a4c01788] core demux debug: using demux module "live555"
[00007f99b00009b8] core input debug: looking for a subtitle file in /home/shan/Desktop/
[00007f99a4c1dd18] core decoder debug: looking for decoder module matching "any": 44 candidates
[00007f999c000958] lua art finder debug: Trying Lua scripts in /home/shan/.local/share/vlc/lua/meta/fetcher
[00007f999c000958] lua art finder debug: Trying Lua scripts in /usr/lib/vlc/lua/meta/fetcher
[00007f999c000958] lua art finder debug: Trying Lua playlist script /usr/lib/vlc/lua/meta/fetcher/tvrage.luac
[00007f999c000958] lua art finder debug: skipping script (unmatched scope) /usr/lib/vlc/lua/meta/fetcher/tvrage.luac
[00007f999c000958] lua art finder debug: Trying Lua scripts in /usr/share/vlc/lua/meta/fetcher
[00007f999c000958] core art finder debug: no meta fetcher modules matched
[0000000001b3b098] core libvlc debug: searching art for H265.sdp
[00007f999c000958] core art finder debug: looking for art finder module matching "any": 2 candidates
[00007f999c000958] lua art finder debug: Trying Lua scripts in /home/shan/.local/share/vlc/lua/meta/art
[00007f999c000958] lua art finder debug: Trying Lua scripts in /usr/lib/vlc/lua/meta/art
[00007f999c000958] lua art finder debug: Trying Lua playlist script /usr/lib/vlc/lua/meta/art/00_musicbrainz.luac
[0000000001b4f5a8] core playlist debug: meta ok for (null), need to fetch art
[00007f99b4004068] core art finder debug: looking for meta fetcher module matching "any": 1 candidates
[00007f999c000958] lua art finder debug: skipping script (unmatched scope) /usr/lib/vlc/lua/meta/art/00_musicbrainz.luac
[00007f999c000958] lua art finder debug: Trying Lua playlist script /usr/lib/vlc/lua/meta/art/01_googleimage.luac
[00007f99b4004068] lua art finder debug: Trying Lua scripts in /home/shan/.local/share/vlc/lua/meta/fetcher
[00007f99b4004068] lua art finder debug: Trying Lua scripts in /usr/lib/vlc/lua/meta/fetcher
[00007f99b4004068] lua art finder debug: Trying Lua playlist script /usr/lib/vlc/lua/meta/fetcher/tvrage.luac
[00007f999c000958] lua art finder debug: skipping script (unmatched scope) /usr/lib/vlc/lua/meta/art/01_googleimage.luac
[00007f999c000958] lua art finder debug: Trying Lua playlist script /usr/lib/vlc/lua/meta/art/02_frenchtv.luac
[00007f99b4004068] lua art finder debug: skipping script (unmatched scope) /usr/lib/vlc/lua/meta/fetcher/tvrage.luac
[00007f99b4004068] lua art finder debug: Trying Lua scripts in /usr/share/vlc/lua/meta/fetcher
[00007f99b4004068] core art finder debug: no meta fetcher modules matched
[0000000001b4f5a8] core playlist debug: searching art for H265.sdp
[00007f99b4c2c3d8] core art finder debug: looking for art finder module matching "any": 2 candidates
[00007f999c000958] lua art finder debug: skipping script (unmatched scope) /usr/lib/vlc/lua/meta/art/02_frenchtv.luac
[00007f999c000958] lua art finder debug: Trying Lua playlist script /usr/lib/vlc/lua/meta/art/03_lastfm.luac
[00007f99a4c1dd18] avcodec decoder debug: CPU flags: 0x0107d3db
[00007f99a4c1dd18] avcodec decoder debug: trying to use direct rendering
[00007f99a4c1dd18] avcodec decoder debug: allowing 4 thread(s) for decoding
[00007f99b4c2c3d8] lua art finder debug: Trying Lua scripts in /home/shan/.local/share/vlc/lua/meta/art
[00007f99b4c2c3d8] lua art finder debug: Trying Lua scripts in /usr/lib/vlc/lua/meta/art
[00007f99b4c2c3d8] lua art finder debug: Trying Lua playlist script /usr/lib/vlc/lua/meta/art/00_musicbrainz.luac
[00007f99a4c1dd18] avcodec decoder debug: avcodec codec (MPEG-H Part2/HEVC (H.265)) started
[00007f99a4c1dd18] avcodec decoder debug: using frame thread mode with 4 threads
[00007f99a4c1dd18] core decoder debug: using decoder module "avcodec"
[00007f99a4c99348] core packetizer debug: looking for packetizer module matching "any": 23 candidates
[00007f99a4c99348] core packetizer debug: using packetizer module "packetizer_hevc"
[00007f99a4c9b2a8] core demux meta debug: looking for meta reader module matching "any": 2 candidates
[00007f999c000958] lua art finder debug: skipping script (unmatched scope) /usr/lib/vlc/lua/meta/art/03_lastfm.luac
[00007f999c000958] lua art finder debug: Trying Lua scripts in /usr/share/vlc/lua/meta/art
[00007f999c000958] core art finder debug: no art finder modules matched
[00007f99b4c2c3d8] lua art finder debug: skipping script (unmatched scope) /usr/lib/vlc/lua/meta/art/00_musicbrainz.luac
[00007f99b4c2c3d8] lua art finder debug: Trying Lua playlist script /usr/lib/vlc/lua/meta/art/01_googleimage.luac
[00007f99a4c9b2a8] lua demux meta debug: Trying Lua scripts in /home/shan/.local/share/vlc/lua/meta/reader
[00007f99a4c9b2a8] lua demux meta debug: Trying Lua scripts in /usr/lib/vlc/lua/meta/reader
[00007f99a4c9b2a8] lua demux meta debug: Trying Lua playlist script /usr/lib/vlc/lua/meta/reader/filename.luac
[00007f99a4c9b2a8] lua demux meta debug: Trying Lua scripts in /usr/share/vlc/lua/meta/reader
[00007f99a4c9b2a8] core demux meta debug: no meta reader modules matched
[00007f99b00009b8] core input debug: `file:///home/shan/Desktop/H265.sdp' successfully opened
[00007f999c000958] core art finder debug: using meta fetcher module "lua"
[00007f999c000958] core art finder debug: removing module "lua"
[00007f99b4c2c3d8] lua art finder debug: skipping script (unmatched scope) /usr/lib/vlc/lua/meta/art/01_googleimage.luac
[00007f99b4c2c3d8] lua art finder debug: Trying Lua playlist script /usr/lib/vlc/lua/meta/art/02_frenchtv.luac
[00007f99b4c2c3d8] lua art finder debug: skipping script (unmatched scope) /usr/lib/vlc/lua/meta/art/02_frenchtv.luac
[00007f99b4c2c3d8] lua art finder debug: Trying Lua playlist script /usr/lib/vlc/lua/meta/art/03_lastfm.luac
[00007f99b4c2c3d8] lua art finder debug: skipping script (unmatched scope) /usr/lib/vlc/lua/meta/art/03_lastfm.luac
[00007f99b4c2c3d8] lua art finder debug: Trying Lua scripts in /usr/share/vlc/lua/meta/art
[00007f99b4c2c3d8] core art finder debug: no art finder modules matched
[00007f99b4c2c3d8] core art finder debug: looking for meta fetcher module matching "any": 1 candidates
[00007f99b4c2c3d8] lua art finder debug: Trying Lua scripts in /home/shan/.local/share/vlc/lua/meta/fetcher
[00007f99b4c2c3d8] lua art finder debug: Trying Lua scripts in /usr/lib/vlc/lua/meta/fetcher
[00007f99b4c2c3d8] lua art finder debug: Trying Lua playlist script /usr/lib/vlc/lua/meta/fetcher/tvrage.luac
[00007f99b4c2c3d8] core art finder debug: using meta fetcher module "lua"
[00007f99b4c2c3d8] core art finder debug: removing module "lua"
[0000000001b3b098] core libvlc debug: art not found for H265.sdp
[0000000001b4f5a8] core playlist debug: art not found for H265.sdp
[00007f99a4c01788] live555 demux error: no data received in 10s, aborting
[00007f99b00009b8] core input debug: EOF reached
[0000000001b4f5a8] core playlist debug: finished input
[00007f99a4c1dd18] core decoder debug: removing module "avcodec"
[00007f99a4c1dd18] avcodec decoder debug: ffmpeg codec (MPEG-H Part2/HEVC (H.265)) stopped
[00007f99a4c1dd18] core decoder debug: killing decoder fourcc `hevc', 0 PES in FIFO
[00007f99a4c99348] core packetizer debug: removing module "packetizer_hevc"
[00007f99a4c01788] core demux debug: removing module "live555"
[00007f99a4c01518] core stream debug: removing module "record"
[00007f99a4000e38] core access debug: removing module "filesystem"
[00007f99b00009b8] core input debug: Program doesn't contain anymore ES
[0000000001b4f5a8] core playlist debug: dead input
[0000000001b4f5a8] core playlist debug: changing item without a request (current 0/1)
[0000000001b4f5a8] core playlist debug: nothing to play
the “no data received in 10s,aborting” is red in console ,too.
Question 2
I need use vlc show the stream, where the sdp file is wrong? or how can I solve the problem?
Question 3
Is there some way i can use gstreamer stream the camera on TX2 to vlc? Maybe don’t use the rtph265pay plugin.
Hi ericksonlushan,
We have rtsp of TX@ to PC VLC player:
[url]https://devtalk.nvidia.com/default/topic/1018689/jetson-tx2/vlc-playing-gstreamer-flow/post/5187270/#5187270[/url]
udp of TX2 to TX2:
[url]https://devtalk.nvidia.com/default/topic/1027423/jetson-tx2/gstreamer-issue-on-tx2/post/5225972/#5225972[/url]
These are all gstreamer frameworks and we suggest you go to http://gstreamer-devel.966125.n4.nabble.com/
Hi DaneLLL, I can use rtsp to PC VLC . But i can’t use RTP over UDP to VLC player.
And i don’t understand the code in https://devtalk.nvidia.com/default/topic/1027423/jetson-tx2/gstreamer-issue-on-tx2/post/5225972/#5225972. Why you put the h264parse plugin again after omxh264enc plugin.
$ gst-launch-1.0 videotestsrc ! nvvidconv ! omxh264enc ! 'video/x-h264,stream-format=byte-stream' ! h264parse ! rtph264pay ! udpsink host=127.0.0.1 port=5000
Thanks a lot. :)
Hi ericksonlushan,
Mabe it is not working networking - VLC UDP network stream does not work in Windows, but does in Linux - Super User
Please go to https://forum.videolan.org/ to get assisitance
