Xzz
April 14, 2023, 2:28am
1
We use es8316 as board sound card.
I asked a question before ,and it works fine now.
Hi, atalambedu
Thank u for support!
Heartfelt thanks!
But I find a question:
when I use command to play music ,left and right channel all normal:
aplay -D hw:es8316tegra,0 1.wav
when I play music in the “Video” or other APP in the desktop,
only Left channel can play sound.
what is the matter with it?
Have a few questions.
Are you playing the same file through Video app and aplay?
Are you make same mixer settings in both the cases?
Also, provide o/p of following commands when playback is going on via app and via aplay
cat /proc/asound/card1/pcm0c/sub0/hw_params
cat /proc/asound/card1/pcm0c/sub0/sw_params
Do attach the wav fie for inspecting
Xzz
April 14, 2023, 7:52am
5
Here is the music file
https://global.discourse-cdn.com/nvidia/original/3X/c/2/c261f74d6117a386fd62984650d783a33e9331fe.wav
Yes, the same file.
I didn’t have “mixer change” operation when I try both test.
atalambedu:
When playback is going on via app and via aplay ,Both two command result are “closed”.
Apologies, there was a typo earlier. Require o/p of below comands
cat /proc/asound/card1/pcm0p/sub0/hw_params
cat /proc/asound/card1/pcm0p/sub0/sw_params
Oh you mean mixer settings are part of 00-tegra.conf?
If so, during aplay and app playback, share o/p of amixer -c 1 contents
Xzz
April 14, 2023, 11:03am
7
Hi, atalambedu,
yes,I have config the mixer in the tergra.config
00-tegra.conf (6.3 KB)
when I paly music with aplay:
root@tegra-ubuntu:/home/linux/Music# s
access: RW_INTERLEAVEDe/linux/Music# cat /proc/asound/card1/pcm0p/sub0/hw_params
format: S16_LE
subformat: STD
channels: 2
rate: 44100 (44100/1)
period_size: 2048
buffer_size: 8192 s
tstamp_mode: NONE:/home/linux/Music# cat /proc/asound/card1/pcm0p/sub0/sw_params
period_step: 1
avail_min: 2048
start_threshold: 8192
stop_threshold: 8192
silence_threshold: 0
silence_size: 0
boundary: 4611686018427387904
when I play music with video:
access: MMAP_INTERLEAVEDlinux/Music# cat /proc/asound/card1/pcm0p/sub0/hw_params
format: S16_LE
subformat: STD
channels: 1
period_size: 8192
buffer_size: 16384 s
tstamp_mode: ENABLEhome/linux/Music# cat /proc/asound/card1/pcm0p/sub0/sw_params
period_step: 1
avail_min: 14621
start_threshold: 18446744073709551615
stop_threshold: 4611686018427387904
silence_size: 0
I found the parameters are different between both.
And here is my result of command.
settings.txt (293.1 KB)
amixer -c 1 contents > contents.txt
Thanks for the data. I see that the waveform is stereo
Looks like the app is asking for mono playback which is why the drivers are set for mono playback as indicated by the hw_params. Could you try playback with some other app like youtube so that we can rule out if its an app specific issue
Xzz
April 15, 2023, 1:32am
9
I try “Chromlum Web Browser” APP and play music online,
but only Left channel can play sound.
linux@tegra-ubuntu:~/Music$ cat /proc/asound/card1/pcm0p/sub0/hw_params
format: S16_LE
subformat: STD
channels: 1
period_size: 8192
buffer_size: 16384
linux@tegra-ubuntu:~/Music$ cat /proc/asound/card1/pcm0p/sub0/sw_params
tstamp_mode: ENABLE
period_step: 1
avail_min: 15802
silence_size: 0
Looks like some userspace config is forcing the playback to be mono and that needs to be corrected.
Could you share /etc/pulse/default.pa at your end and output of pacmd list-sinks.
You could remap the sink to behave as stereo instead of mono by playing with pulseaudio config.
PulseAudio/Examples - ArchWiki has the pulse audio to config the playback to be mono in place of stereo while you want stereo instead of mono. Please explore the reference to come up with desired setting and see if this helps
Xzz
April 17, 2023, 8:44am
11
atalambedu:
Thank you for reply, this is my default.pa
default.pa (5.2 KB)
L will try it soon.
Xzz
April 18, 2023, 12:07pm
12
can u give me some suggestion?
I have try something told by this link but it seems not effective.
Please note that userspace level support does not come under our scope as its generic to all ubuntu systems and not specifc to Jetson. However, I will see if i can offer any suggestion.
Could you share the remapping change the you tried in pulse audio config and also o/p of command “pacmd list-sinks”
Xzz
April 19, 2023, 8:07am
14
when I run commadn “pacmd list-sinks” :
root@tegra-ubuntu:~# pacmd list-sinks
No PulseAudio daemon running, or not running as session daemon.
What’s more , I use L4T 32.7.3 SDK, and rootfs is nvidia sample system,
I didin’t change anything , have your other clients encountered the same situation?
So looks like pulseaudio is not being used at all. Not sure what is causing the issue. Issue is not at kernel level as aplay is fine, it understands the wav header and initiates stereo playback. So issue is above kernel level and I expect it to be some userspace setting.
While you explore the usersapce issue, I could help provide a workaround. Use below commands as a WAR to get stereo playback and see if it helps
amixer -c 1 cset name="I2S<i> Playback Mono To Stereo" "Copy"
amixer -c 1 cset name="I2S<i> Playback Audio Channels" 2
Replace <i> with relevant number used
Xzz
April 21, 2023, 8:36am
16
Hi, atalabedu,
I try these command,
amixer -c es8316tegra cset name="I2S5 Playback Mono To Stereo" "Copy"
amixer -c es8316tegra cset name="I2S5 Playback Audio Channels" 2
but failed
amixer: Cannot find the given element from control hw:1
HI,
Are you using JP 4.x version then you may have to use below instead. Above info was for JP 5.x version
amixer -c 1 cset name="I2S<i> Playback Mono To Stereo Conv" "COPY"
amixer -c 1 cset name="I2S<i> Channels" 2
Reference: https://docs.nvidia.com/jetson/archives/l4t-archived/l4t-3271/index.html#page/Tegra%20Linux%20Driver%20Package%20Development%20Guide/asoc_driver.19.2.html#wwpID0E0UHB0HA
Xzz
April 21, 2023, 9:08am
18
I’m using JP 4.6.3.
And this command failed again with the same error:
amixer -c es8316tegra cset name="I2S5 Playback Mono To Stereo Conv" "COPY"
This command ok
root@tegra-ubuntu:/# amixer -c es8316tegra cset name="I2S5 Channels" 2
numid=922,iface=MIXER,name='I2S5 Channels'
; type=INTEGER,access=rw------,values=1,min=0,max=16,step=0
: values=2
But only left channel can play sound.
Apologies as I dont have older setup (JP 4.x). I referred the documentation for the possible values for mixer settings. In documentation, the values seem to be case insensitive
Try amixer -c es8316tegra cset name=“I2S5 Playback Mono To Stereo Conv” “Copy” instead.
If this does not help, please share o/p of amixer -c 1 contents
Xzz
April 21, 2023, 9:40am
20
Hi,atalambedu,
I check my contents and find this:
numid=925,iface=MIXER,name='I2S5 Capture mono to stereo conv'
numid=924,iface=MIXER,name='I2S5 Capture stereo to mono conv'
numid=927,iface=MIXER,name='I2S5 Playback mono to stereo conv'
numid=926,iface=MIXER,name='I2S5 Playback stereo to mono conv'
So I try this and two channel can play sound at the same time now.
root@tegra-ubuntu:/#amixer -c es8316tegra cset name="I2S5 Playback mono to stereo conv" "COPY"
; type=ENUMERATED,access=rw------,values=1,items=3
; Item #0 'None'
; Item #1 'ZERO'
; Item #2 'COPY'
: values=2
Thank for you help!
Let me know if no other issues on this post.
Xzz
April 21, 2023, 9:48am
22
There is no other issues on this post.
Extremely thank you!
