When playback a wave file, it will always exit immediately without error and sound by entering following commnad.
root@linux:~# aplay -D plughw:1,2 1kHz.wav -v
Playing WAVE ‘1kHz.wav’ : Signed 16 bit Little Endian, Rate 44100 Hz, Stereo
Plug PCM: Hardware PCM card 1 ‘tegra-snd-t186ref-mobile-rt5640’ device 0 subdevice 0
Its setup is:
stream : PLAYBACK
access : RW_INTERLEAVED
format : S16_LE
subformat : STD
channels : 2
rate : 44100
exact rate : 44100 (44100/1)
msbits : 16
buffer_size : 8192
period_size : 2048
period_time : 46439
tstamp_mode : NONE
tstamp_type : MONOTONIC
period_step : 1
avail_min : 2048
period_event : 0
start_threshold : 8192
stop_threshold : 8192
silence_threshold: 0
silence_size : 0
boundary : 4611686018427387904
appl_ptr : 0
hw_ptr : 0
Sound Cards
root@linux:~# cat /proc/asound/cards
0 [tegrahdaxnx ]: tegra-hda-xnx - tegra-hda-xnx
tegra-hda-xnx at 0x3518000 irq 65
1 [tegrasndt186ref]: tegra-snd-t186r - tegra-snd-t186ref-mobile-rt5640
Audio Widget
amixer -c 1 cset name="I2S3 Mux" "ADMAIF1"
amixer -c 1 cset name="x HP Playback Volume" "0x1e"
amixer -c 1 cset name="x Stereo DAC MIXR DAC R1 Switch" "on"
amixer -c 1 cset name="x Stereo DAC MIXL DAC L1 Switch" "on"
amixer -c 1 cset name="x HP R Playback Switch" "on"
amixer -c 1 cset name="x HP L Playback Switch" "on"
Audio Route
root@linux:~# cat /sys/kernel/debug/tracing/trace
# tracer: nop
# entries-in-buffer/entries-written: 117/117 #P:4
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
amixer-8574 [000] .... 201.791258: snd_soc_dapm_path: *ADMAIF1 RX <- (direct) <- ADMAIF1 Receive
amixer-8574 [000] .... 201.791264: snd_soc_dapm_path: I2S3 Mux <- ARAD1 <- ARAD1 RX
amixer-8574 [000] .... 201.791265: snd_soc_dapm_path: I2S3 Mux <- ADX4-4 <- ADX4-4 RX
amixer-8574 [000] .... 201.791266: snd_soc_dapm_path: I2S3 Mux <- ADX4-3 <- ADX4-3 RX
amixer-8574 [000] .... 201.791267: snd_soc_dapm_path: I2S3 Mux <- ADX4-2 <- ADX4-2 RX
amixer-8574 [000] .... 201.791268: snd_soc_dapm_path: I2S3 Mux <- ADX4-1 <- ADX4-1 RX
amixer-8574 [000] .... 201.791290: snd_soc_dapm_path: I2S3 Mux <- AMX4 <- AMX4 RX
amixer-8574 [000] .... 201.791292: snd_soc_dapm_path: I2S3 Mux <- ADX3-4 <- ADX3-4 RX
amixer-8574 [000] .... 201.791293: snd_soc_dapm_path: I2S3 Mux <- ADX3-3 <- ADX3-3 RX
amixer-8574 [000] .... 201.791294: snd_soc_dapm_path: I2S3 Mux <- ADX3-2 <- ADX3-2 RX
amixer-8574 [000] .... 201.791294: snd_soc_dapm_path: I2S3 Mux <- ADX3-1 <- ADX3-1 RX
amixer-8574 [000] .... 201.791295: snd_soc_dapm_path: I2S3 Mux <- AMX3 <- AMX3 RX
amixer-8574 [000] .... 201.791296: snd_soc_dapm_path: I2S3 Mux <- ASRC1-6 <- ASRC1-6 RX
amixer-8574 [000] .... 201.791297: snd_soc_dapm_path: I2S3 Mux <- ASRC1-5 <- ASRC1-5 RX
amixer-8574 [000] .... 201.791298: snd_soc_dapm_path: I2S3 Mux <- ASRC1-4 <- ASRC1-4 RX
amixer-8574 [000] .... 201.791299: snd_soc_dapm_path: I2S3 Mux <- ASRC1-3 <- ASRC1-3 RX
amixer-8574 [000] .... 201.791300: snd_soc_dapm_path: I2S3 Mux <- ASRC1-2 <- ASRC1-2 RX
amixer-8574 [000] .... 201.791301: snd_soc_dapm_path: I2S3 Mux <- ASRC1-1 <- ASRC1-1 RX
amixer-8574 [000] .... 201.791302: snd_soc_dapm_path: I2S3 Mux <- I2S6 <- I2S6 RX
amixer-8574 [000] .... 201.791302: snd_soc_dapm_path: I2S3 Mux <- DMIC4 <- DMIC4 RX
amixer-8574 [000] .... 201.791303: snd_soc_dapm_path: I2S3 Mux <- ADMAIF20 <- ADMAIF20 RX
amixer-8574 [000] .... 201.791304: snd_soc_dapm_path: I2S3 Mux <- ADMAIF19 <- ADMAIF19 RX
amixer-8574 [000] .... 201.791305: snd_soc_dapm_path: I2S3 Mux <- ADMAIF18 <- ADMAIF18 RX
amixer-8574 [000] .... 201.791306: snd_soc_dapm_path: I2S3 Mux <- ADMAIF17 <- ADMAIF17 RX
amixer-8574 [000] .... 201.791307: snd_soc_dapm_path: I2S3 Mux <- ADMAIF16 <- ADMAIF16 RX
amixer-8574 [000] .... 201.791308: snd_soc_dapm_path: I2S3 Mux <- ADMAIF15 <- ADMAIF15 RX
amixer-8574 [000] .... 201.791308: snd_soc_dapm_path: I2S3 Mux <- ADMAIF14 <- ADMAIF14 RX
amixer-8574 [000] .... 201.791309: snd_soc_dapm_path: I2S3 Mux <- ADMAIF13 <- ADMAIF13 RX
amixer-8574 [000] .... 201.791310: snd_soc_dapm_path: I2S3 Mux <- ADMAIF12 <- ADMAIF12 RX
amixer-8574 [000] .... 201.791311: snd_soc_dapm_path: I2S3 Mux <- ADMAIF11 <- ADMAIF11 RX
amixer-8574 [000] .... 201.791312: snd_soc_dapm_path: I2S3 Mux <- ADX2-4 <- ADX2-4 RX
amixer-8574 [000] .... 201.791312: snd_soc_dapm_path: I2S3 Mux <- ADX2-3 <- ADX2-3 RX
amixer-8574 [000] .... 201.791313: snd_soc_dapm_path: I2S3 Mux <- ADX2-2 <- ADX2-2 RX
amixer-8574 [000] .... 201.791314: snd_soc_dapm_path: I2S3 Mux <- ADX2-1 <- ADX2-1 RX
amixer-8574 [000] .... 201.791315: snd_soc_dapm_path: I2S3 Mux <- AMX2 <- AMX2 RX
amixer-8574 [000] .... 201.791316: snd_soc_dapm_path: I2S3 Mux <- ADX1-4 <- ADX1-4 RX
amixer-8574 [000] .... 201.791317: snd_soc_dapm_path: I2S3 Mux <- ADX1-3 <- ADX1-3 RX
amixer-8574 [000] .... 201.791317: snd_soc_dapm_path: I2S3 Mux <- ADX1-2 <- ADX1-2 RX
amixer-8574 [000] .... 201.791318: snd_soc_dapm_path: I2S3 Mux <- ADX1-1 <- ADX1-1 RX
amixer-8574 [000] .... 201.791319: snd_soc_dapm_path: I2S3 Mux <- AMX1 <- AMX1 RX
amixer-8574 [000] .... 201.791320: snd_soc_dapm_path: I2S3 Mux <- DMIC3 <- DMIC3 RX
amixer-8574 [000] .... 201.791321: snd_soc_dapm_path: I2S3 Mux <- DMIC2 <- DMIC2 RX
amixer-8574 [000] .... 201.791321: snd_soc_dapm_path: I2S3 Mux <- DMIC1 <- DMIC1 RX
amixer-8574 [000] .... 201.791322: snd_soc_dapm_path: I2S3 Mux <- IQC2-2 <- IQC2-2 RX
amixer-8574 [000] .... 201.791323: snd_soc_dapm_path: I2S3 Mux <- IQC2-1 <- IQC2-1 RX
amixer-8574 [000] .... 201.791324: snd_soc_dapm_path: I2S3 Mux <- IQC1-2 <- IQC1-2 RX
amixer-8574 [000] .... 201.791325: snd_soc_dapm_path: I2S3 Mux <- IQC1-1 <- IQC1-1 RX
amixer-8574 [000] .... 201.791339: snd_soc_dapm_path: I2S3 Mux <- MVC2 <- MVC2 RX
amixer-8574 [000] .... 201.791340: snd_soc_dapm_path: I2S3 Mux <- MVC1 <- MVC1 RX
amixer-8574 [000] .... 201.791341: snd_soc_dapm_path: I2S3 Mux <- OPE1 <- OPE1 RX
amixer-8574 [000] .... 201.791342: snd_soc_dapm_path: I2S3 Mux <- AFC6 <- AFC6 RX
amixer-8574 [000] .... 201.791343: snd_soc_dapm_path: I2S3 Mux <- AFC5 <- AFC5 RX
amixer-8574 [000] .... 201.791343: snd_soc_dapm_path: I2S3 Mux <- AFC4 <- AFC4 RX
amixer-8574 [000] .... 201.791344: snd_soc_dapm_path: I2S3 Mux <- AFC3 <- AFC3 RX
amixer-8574 [000] .... 201.791345: snd_soc_dapm_path: I2S3 Mux <- AFC2 <- AFC2 RX
amixer-8574 [000] .... 201.791346: snd_soc_dapm_path: I2S3 Mux <- AFC1 <- AFC1 RX
amixer-8574 [000] .... 201.791347: snd_soc_dapm_path: I2S3 Mux <- MIXER1-5 <- MIXER1-5 RX
amixer-8574 [000] .... 201.791348: snd_soc_dapm_path: I2S3 Mux <- MIXER1-4 <- MIXER1-4 RX
amixer-8574 [000] .... 201.791349: snd_soc_dapm_path: I2S3 Mux <- MIXER1-3 <- MIXER1-3 RX
amixer-8574 [000] .... 201.791349: snd_soc_dapm_path: I2S3 Mux <- MIXER1-2 <- MIXER1-2 RX
amixer-8574 [000] .... 201.791350: snd_soc_dapm_path: I2S3 Mux <- MIXER1-1 <- MIXER1-1 RX
amixer-8574 [000] .... 201.791351: snd_soc_dapm_path: I2S3 Mux <- SFC4 <- SFC4 RX
amixer-8574 [000] .... 201.791352: snd_soc_dapm_path: I2S3 Mux <- SFC3 <- SFC3 RX
amixer-8574 [000] .... 201.791354: snd_soc_dapm_path: I2S3 Mux <- SFC2 <- SFC2 RX
amixer-8574 [000] .... 201.791355: snd_soc_dapm_path: I2S3 Mux <- SFC1 <- SFC1 RX
amixer-8574 [000] .... 201.791355: snd_soc_dapm_path: I2S3 Mux <- I2S5 <- I2S5 RX
amixer-8574 [000] .... 201.791356: snd_soc_dapm_path: I2S3 Mux <- I2S4 <- I2S4 RX
amixer-8574 [000] .... 201.791357: snd_soc_dapm_path: I2S3 Mux <- I2S3 <- I2S3 RX
amixer-8574 [000] .... 201.791358: snd_soc_dapm_path: I2S3 Mux <- I2S2 <- I2S2 RX
amixer-8574 [000] .... 201.791359: snd_soc_dapm_path: I2S3 Mux <- I2S1 <- I2S1 RX
amixer-8574 [000] .... 201.791359: snd_soc_dapm_path: I2S3 Mux <- ADMAIF10 <- ADMAIF10 RX
amixer-8574 [000] .... 201.791360: snd_soc_dapm_path: I2S3 Mux <- ADMAIF9 <- ADMAIF9 RX
amixer-8574 [000] .... 201.791361: snd_soc_dapm_path: I2S3 Mux <- ADMAIF8 <- ADMAIF8 RX
amixer-8574 [000] .... 201.791362: snd_soc_dapm_path: I2S3 Mux <- ADMAIF7 <- ADMAIF7 RX
amixer-8574 [000] .... 201.791363: snd_soc_dapm_path: I2S3 Mux <- ADMAIF6 <- ADMAIF6 RX
amixer-8574 [000] .... 201.791364: snd_soc_dapm_path: I2S3 Mux <- ADMAIF5 <- ADMAIF5 RX
amixer-8574 [000] .... 201.791365: snd_soc_dapm_path: I2S3 Mux <- ADMAIF4 <- ADMAIF4 RX
amixer-8574 [000] .... 201.791365: snd_soc_dapm_path: I2S3 Mux <- ADMAIF3 <- ADMAIF3 RX
amixer-8574 [000] .... 201.791366: snd_soc_dapm_path: I2S3 Mux <- ADMAIF2 <- ADMAIF2 RX
amixer-8574 [000] .... 201.791367: snd_soc_dapm_path: *I2S3 Mux <- ADMAIF1 <- ADMAIF1 RX
amixer-8575 [002] .... 207.267569: snd_soc_dapm_path: *x DAC MIXR <- INF1 Switch <- x IF1 DAC R
amixer-8575 [002] .... 207.267575: snd_soc_dapm_path: *x IF1 DAC R <- (direct) <- x IF1 DAC
amixer-8575 [002] .... 207.267577: snd_soc_dapm_path: *x IF1 DAC <- (direct) <- x DAI1 RX Mux
amixer-8575 [002] .... 207.267579: snd_soc_dapm_path: x DAI1 RX Mux <- 1:2|2:2 <- x AIF2RX
amixer-8575 [002] .... 207.267580: snd_soc_dapm_path: x DAI1 RX Mux <- 1:2|2:1 <- x AIF2RX
amixer-8575 [002] .... 207.267581: snd_soc_dapm_path: x DAI1 RX Mux <- 1:1|2:1 <- x AIF1RX
amixer-8575 [002] .... 207.267582: snd_soc_dapm_path: *x DAI1 RX Mux <- 1:1|2:2 <- x AIF1RX
amixer-8575 [002] .... 207.267584: snd_soc_dapm_path: *x AIF1RX <- (direct) <- x AIF1 Playback
amixer-8575 [002] .... 207.267585: snd_soc_dapm_path: *x AIF1 Playback <- (direct) <- I2S3 DAP Transmit-x AIF1 Playback
amixer-8575 [002] .... 207.267587: snd_soc_dapm_path: *I2S3 DAP Transmit-x AIF1 Playback <- (direct) <- I2S3 DAP Transmit
amixer-8575 [002] .... 207.267588: snd_soc_dapm_path: *I2S3 DAP Transmit <- (direct) <- I2S3 DAP TX
amixer-8575 [002] .... 207.267590: snd_soc_dapm_path: *I2S3 DAP TX <- (direct) <- I2S3 CIF RX
amixer-8575 [002] .... 207.267591: snd_soc_dapm_path: *I2S3 CIF RX <- (direct) <- I2S3 CIF Receive
amixer-8575 [002] .... 207.267592: snd_soc_dapm_path: *I2S3 CIF Receive <- (direct) <- I2S3 Transmit-I2S3 CIF Receive
amixer-8575 [002] .... 207.267594: snd_soc_dapm_path: *I2S3 Transmit-I2S3 CIF Receive <- (direct) <- I2S3 Transmit
amixer-8575 [002] .... 207.267614: snd_soc_dapm_path: *I2S3 Transmit <- (direct) <- I2S3 TX
amixer-8575 [002] .... 207.267616: snd_soc_dapm_path: *I2S3 TX <- (direct) <- I2S3 Mux
amixer-8575 [002] .... 207.267618: snd_soc_dapm_path: x DAC MIXR <- Stereo ADC Switch <- x Stereo ADC MIXR
amixer-8575 [002] .... 207.267619: snd_soc_dapm_path: *x Stereo DAC MIXR <- DAC R1 Switch <- x DAC MIXR
amixer-8575 [002] .... 207.267620: snd_soc_dapm_path: x Stereo DAC MIXR <- ANC Switch <- x ANC
amixer-8575 [002] .... 207.267621: snd_soc_dapm_path: x Stereo DAC MIXR <- DAC R2 Switch <- x DAC R2 Mux
amixer-8576 [003] .... 212.628506: snd_soc_dapm_path: *x DAC MIXL <- INF1 Switch <- x IF1 DAC L
amixer-8576 [003] .... 212.628512: snd_soc_dapm_path: *x IF1 DAC L <- (direct) <- x IF1 DAC
amixer-8576 [003] .... 212.628514: snd_soc_dapm_path: x DAC MIXL <- Stereo ADC Switch <- x Stereo ADC MIXL
amixer-8576 [003] .... 212.628516: snd_soc_dapm_path: *x Stereo DAC MIXL <- DAC L1 Switch <- x DAC MIXL
amixer-8576 [003] .... 212.628517: snd_soc_dapm_path: x Stereo DAC MIXL <- ANC Switch <- x ANC
amixer-8576 [003] .... 212.628518: snd_soc_dapm_path: x Stereo DAC MIXL <- DAC L2 Switch <- x DAC L2 Mux
amixer-8578 [000] .... 224.371380: snd_soc_dapm_path: *x HP Amp -> Switch -> x HP R Playback
amixer-8578 [000] .... 224.371386: snd_soc_dapm_path: *x HP R Playback -> (direct) -> x HPOR
amixer-8578 [000] .... 224.371388: snd_soc_dapm_path: *x HPOR -> (direct) -> x Headphone
amixer-8578 [000] .... 224.371390: snd_soc_dapm_path: x HPOR -> HPOR Switch -> x RECMIXR
amixer-8578 [000] .... 224.371391: snd_soc_dapm_path: x HP Amp -> Switch -> x HP L Playback
amixer-8579 [002] .... 231.052104: snd_soc_dapm_path: *x HP Amp -> Switch -> x HP R Playback
amixer-8579 [002] .... 231.052110: snd_soc_dapm_path: *x HP Amp -> Switch -> x HP L Playback
amixer-8579 [002] .... 231.052111: snd_soc_dapm_path: *x HP L Playback -> (direct) -> x HPOL
amixer-8579 [002] .... 231.052113: snd_soc_dapm_path: *x HPOL -> (direct) -> x Headphone
amixer-8579 [002] .... 231.052115: snd_soc_dapm_path: x HPOL -> HPOL Switch -> x RECMIXL
Using I2S3
Device Tree
device_tree.txt (2.0 KB)
Schematic
rt5640_schematic.pdf (64.3 KB)
AUD_MCLK (GPIO09) - 11.3M
