Hi:
We use L4T 24.2.1.
We have written the camera drivers for sony IMX377 and IMX274. the configuration is as follow:
IMX377: 2 lanes, CSI b, VI port 0 (/dev/video0)
IMX274: 2 lanes, CSI a, VI port 1 (/dev/video1)
We use the following gstreamer commands to show the preview of IMX377:
gst-launch-1.0 nvcamerasrc sensor-id=0 fpsRange="60 60" ! 'video/x-raw(memory:NVMM), width=1920, height=1080, format=(string)I420, framerate=60/1' ! nvvidconv ! 'video/x-raw(memory:NVMM), width=640, height=480, format=(string)I420, framerate=60/1' ! nvegltransform ! nveglglessink -e
The above command works fine, and I can see the preview of IMX377 correctly.
However, If I change sensor-id from 0 to 1, system still tries to use IMX377, not IMX274.
And there is no preview.
I turn on the nvcamera-daemon debug messages. They are as follow (when sensor-id=1):
Thread 1 getting next capture
Thread 2 getting next capture
Thread 1 is waiting
Thread 2 is waiting
Thread 3 getting next capture
Thread 3 is waiting
Thread 4 getting next capture
Thread 4 is waiting
Starting services...
getInstance: s_instance(0x7f891a2e80)
doCreateSensor: create SensorType(gyroscope) sensor(0x7f891a2f80)
doCreateSensor: create SensorType(accelerometer) sensor(0x7f891a32c0)
doCreateSensor: create SensorType(magnetometer) sensor(0x7f891a3350)
doCreateSensor: create SensorType(temperature) sensor(0x7f8921f5f0)
doCreateSensor: create SensorType(proximity) sensor(0x7f892229d0)
doCreateSensor: create SensorType(rotation vector) sensor(0x7f89225db0)
doCreateSensor: create SensorType(linear acceleration) sensor(0x7f89229190)
AC plugin not present: dlopen "acplugin.so", acplugin.so: cannot open shared object file: No such file or directory
Services are started
NvPclSetHotplugCallback: ++++++++++++++++++++++
###### Imager: Calibration blob file handling NOT supported in this build ######
NvPclHwGetModuleList: OFParserListModules Succeeded
NvPclHwMatchPartNum: Found calibration Part#:4BA815P2, imx219:"A815P2"
NvPclHwGetModuleList: No module data found
NvPclHwPrintModuleDefinition -- Name: imx377_centerlef_A815P2
NvPclHwPrintModuleDefinition -- Position: 1
NvPclHwPrintModuleDefinition -- CalibrationData Found: 1
NvPclHwPrintCameraSubModule -- HwCamSubModule[0].Name: v4l2_sensor
NvPclHwPrintCameraSubModule -- HwCamSubModule[0].DevName: imx377 2-001a
NvPclHwPrintModuleDefinition -- Name: imx274_centerright_A815P2
NvPclHwPrintModuleDefinition -- Position: 2
NvPclHwPrintCameraSubModule -- HwCamSubModule[0].DevName: imx274 6-001a
NvPclModuleListInitialize: NvPclModule list[0]: imx377_centerlef_A815P2 position1
NvPclModuleListInitialize: NvPclModule list[1]: imx274_centerright_A815P2 position2
NvPclHwScanExternalCameras -- adding video1 to discover list
NvPclHwScanExternalCameras -- adding video0 to discover list
initialize: /dev/video0
initialize: /dev/video1
getHotplugMonitor: Getting hotplug monitor instance
initializeHotplug++
hotPlugfunc ++
addWatch: Watch added wd='1'
setHotplugCallback: Registered new callback client
NvPclSetHotplugCallback: ----------------------
NvPclOpen: ++++++++++++++++++++++
NvPclStateControllerOpen: Found GUID 1 match at index[0]
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f8925b030
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f8924b370
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f8924b400
LoadOverridesFile: looking for override file [/Calib/camera_override.isp] 1/16
CheckOverridesPermissions: cannot stat file [/Calib/camera_override.isp]
LoadOverridesFile: looking for override file [/data/nvcam/settings/camera_overrides.isp] 2/16
CheckOverridesPermissions: cannot stat file [/data/nvcam/settings/camera_overrides.isp]
LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/camera_overrides.isp] 3/16
CheckOverridesPermissions: cannot stat file [/opt/nvidia/nvcam/settings/camera_overrides.isp]
LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/camera_overrides.isp] 4/16
CheckOverridesPermissions: cannot stat file [/var/nvidia/nvcam/settings/camera_overrides.isp]
LoadOverridesFile: looking for override file [/data/nvcam/camera_overrides.isp] 5/16
CheckOverridesPermissions: cannot stat file [/data/nvcam/camera_overrides.isp]
LoadOverridesFile: looking for override file [/data/nvcam/settings/imx377_centerlef_A815P2.isp] 6/16
CheckOverridesPermissions: cannot stat file [/data/nvcam/settings/imx377_centerlef_A815P2.isp]
LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/imx377_centerlef_A815P2.isp] 7/16
CheckOverridesPermissions: cannot stat file [/opt/nvidia/nvcam/settings/imx377_centerlef_A815P2.isp]
LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/imx377_centerlef_A815P2.isp] 8/16
CheckOverridesPermissions: cannot stat file [/var/nvidia/nvcam/settings/imx377_centerlef_A815P2.isp]
LoadOverridesFile: looking for override file [(null)] 9/16
LoadOverridesFile: looking for override file [(null)] 10/16
LoadOverridesFile: looking for override file [(null)] 11/16
LoadOverridesFile: looking for override file [(null)] 12/16
LoadOverridesFile: looking for override file [(null)] 13/16
LoadOverridesFile: looking for override file [(null)] 14/16
LoadOverridesFile: looking for override file [(null)] 15/16
LoadOverridesFile: looking for override file [(null)] 16/16
LoadOverridesFile: No override file found.
NvPclCreateDriver: Found NvPcl Driver Hal dev_name match (v4l2_sensor)
NvPclCreateDriver: Found a Driver name match (v4l2_sensor)
NvPclConnectDrivers: hImager was NULL, creating new imager
NvPclInitializeDrivers: v4l2_sensor ++++++++++++++++++
OFDPropertyGetString: could not read property [devnode-bus]
initialize: imx377 2-001a
OFDPropertyGetString: could not read property [use_decibel_gain]
OFDPropertyGetString: could not read property [use_sensor_mode_id]
OFDPropertyCopyToLong: could not read property [has-eeprom]
Control Fuse ID not found
Control OTP Data not found
Control Frame Rate not found
Control Exposure not found
Sensor_FindCustomCIDs: calculated MaxCoarseDiff -500
OFDPropertyGetString: could not read property [type]
Sensor_LoadSubType: Sensor type missing in DT, 510
OFDPropertyCopyToLong: could not read property [mode0.csi_pixel_bit_depth]
OFDPropertyCopyToLong: could not read property [mode0.dynamic_pixel_bit_depth]
OFDPropertyGetString: could not read property [mode0.mode_type]
Sensor_LoadModeModeType: mode 0: Failed to load pixeltype
OFDPropertyGetString: could not read property [mode0.pixel_phase]
Sensor_LoadModePixelPhase: mode 0: Failed to load pixeltype
OFDPropertyGetString: could not read property [mode0.x_start]
OFDPropertyGetString: could not read property [mode0.y_start]
OFDPropertyGetString: could not read property [mode0.x_end]
OFDPropertyGetString: could not read property [mode0.y_end]
OFDPropertyGetString: could not read property [mode0.h_scaling]
OFDPropertyGetString: could not read property [mode0.v_scaling]
OFDPropertyCopyToLong: could not read property [mode1.csi_pixel_bit_depth]
OFDPropertyCopyToLong: could not read property [mode1.dynamic_pixel_bit_depth]
OFDPropertyGetString: could not read property [mode1.mode_type]
Sensor_LoadModeModeType: mode 1: Failed to load pixeltype
OFDPropertyGetString: could not read property [mode1.pixel_phase]
Sensor_LoadModePixelPhase: mode 1: Failed to load pixeltype
OFDPropertyGetString: could not read property [mode1.x_start]
OFDPropertyGetString: could not read property [mode1.y_start]
OFDPropertyGetString: could not read property [mode1.x_end]
OFDPropertyGetString: could not read property [mode1.y_end]
OFDPropertyGetString: could not read property [mode1.h_scaling]
OFDPropertyGetString: could not read property [mode1.v_scaling]
OFDPropertyCopyToLong: could not read property [mode2.csi_pixel_bit_depth]
OFDPropertyCopyToLong: could not read property [mode2.dynamic_pixel_bit_depth]
OFDPropertyGetString: could not read property [mode2.mode_type]
Sensor_LoadModeModeType: mode 2: Failed to load pixeltype
OFDPropertyGetString: could not read property [mode2.pixel_phase]
Sensor_LoadModePixelPhase: mode 2: Failed to load pixeltype
OFDPropertyGetString: could not read property [mode2.x_start]
OFDPropertyGetString: could not read property [mode2.y_start]
OFDPropertyGetString: could not read property [mode2.x_end]
OFDPropertyGetString: could not read property [mode2.y_end]
OFDPropertyGetString: could not read property [mode2.h_scaling]
OFDPropertyGetString: could not read property [mode2.v_scaling]
OFDPropertyCopyToLong: could not read property [mode3.csi_pixel_bit_depth]
OFDPropertyCopyToLong: could not read property [mode3.dynamic_pixel_bit_depth]
OFDPropertyGetString: could not read property [mode3.mode_type]
Sensor_LoadModeModeType: mode 3: Failed to load pixeltype
OFDPropertyGetString: could not read property [mode3.pixel_phase]
Sensor_LoadModePixelPhase: mode 3: Failed to load pixeltype
OFDPropertyGetString: could not read property [mode3.x_start]
OFDPropertyGetString: could not read property [mode3.y_start]
OFDPropertyGetString: could not read property [mode3.x_end]
OFDPropertyGetString: could not read property [mode3.y_end]
OFDPropertyGetString: could not read property [mode3.h_scaling]
OFDPropertyGetString: could not read property [mode3.v_scaling]
OFDPropertyCopyToLong: could not read property [mode4.csi_pixel_bit_depth]
OFDPropertyCopyToLong: could not read property [mode4.dynamic_pixel_bit_depth]
OFDPropertyGetString: could not read property [mode4.mode_type]
Sensor_LoadModeModeType: mode 4: Failed to load pixeltype
OFDPropertyGetString: could not read property [mode4.pixel_phase]
Sensor_LoadModePixelPhase: mode 4: Failed to load pixeltype
OFDPropertyGetString: could not read property [mode4.x_start]
OFDPropertyGetString: could not read property [mode4.y_start]
OFDPropertyGetString: could not read property [mode4.x_end]
OFDPropertyGetString: could not read property [mode4.y_end]
OFDPropertyGetString: could not read property [mode4.h_scaling]
OFDPropertyGetString: could not read property [mode4.v_scaling]
OFDPropertyCopyToLong: could not read property [mode5.csi_pixel_bit_depth]
OFDPropertyCopyToLong: could not read property [mode5.dynamic_pixel_bit_depth]
OFDPropertyGetString: could not read property [mode5.mode_type]
Sensor_LoadModeModeType: mode 5: Failed to load pixeltype
OFDPropertyGetString: could not read property [mode5.pixel_phase]
Sensor_LoadModePixelPhase: mode 5: Failed to load pixeltype
OFDPropertyGetString: could not read property [mode5.x_start]
OFDPropertyGetString: could not read property [mode5.y_start]
OFDPropertyGetString: could not read property [mode5.x_end]
OFDPropertyGetString: could not read property [mode5.y_end]
OFDPropertyGetString: could not read property [mode5.h_scaling]
OFDPropertyGetString: could not read property [mode5.v_scaling]
NvPclDriver_V4L2_Sensor_Initialize: Loaded Driver: 6 Modes Available--------------
NvPclInitializeDrivers: v4l2_sensor ------------------
NvPclOpen: ----------------------
populateStaticProperties
NvPclStateControllerOpen: Found GUID 2 match at index[1]
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f8925c590
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f8925c620
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f8925c6b0
LoadOverridesFile: looking for override file [/data/nvcam/settings/imx274_centerright_A815P2.isp] 6/16
CheckOverridesPermissions: cannot stat file [/data/nvcam/settings/imx274_centerright_A815P2.isp]
LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/imx274_centerright_A815P2.isp] 7/16
CheckOverridesPermissions: cannot stat file [/opt/nvidia/nvcam/settings/imx274_centerright_A815P2.isp]
LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/imx274_centerright_A815P2.isp] 8/16
CheckOverridesPermissions: cannot stat file [/var/nvidia/nvcam/settings/imx274_centerright_A815P2.isp]
initialize: imx274 6-001a
NvPclDriver_V4L2_Sensor_Initialize: Loaded Driver: 5 Modes Available--------------
sourceRegistry[1] assigned
ispRegistry[0] assigned
Using Source GUID 2
NvPclPowerOn: +++++++++++
NvPclPowerOn: -----------
Using ISP A
No library found, disabling AC plugin.
NvPclSettingsUpdate: Sending Updated Settings through PCL
NvPclSettingsApply: Applying last settings through PCL
NvPclDriver_V4L2_Sensor_Write:+++++++++++++++++++++++
Sensor_WriteMode: Target mode Id(1): Resolution 1932x1102
setActiveBufferMemory: 2
setActivePixelFormat: 808535890
INPUT: Width 4104 Height 3062 pixelformat RG10
INPUT: Width 1932 Height 1102 pixelformat RG10
Sensor_WriteFrameRate: INPUT frameLength:2307, frameRate:60.000000
Sensor_WriteGain: INPUT gainCtrl:100 analogGain:1.000000
Sensor_WriteExposure: INPUT coarseTime:2807, expTime:0.020273
NvPclDriver_UpdateOutputSettings: OUTPUT frameLength:2307, frameRate:60.018005
NvPclDriver_UpdateOutputSettings: OUTPUT analogGain:1.000000
NvPclDriver_UpdateOutputSettings: OUTPUT coarseTime:2807, expTime:0.020273
NvPclDriver_V4L2_Sensor_Write:-----------------------
NvPclSettingsApply: Reading PCL settings
InstructionList:
+ GraphSettings
| SensorMode: 1932x1102 BayerS16RGGB 60.0fps
| output 0: 1920x1080 BL Y8 420
| downscaleForPostProcessing
+ Instruction List
+ 0: CCDataSetupStage
| EstimatedIspOutLatencyFrames: 5
| NumConcurrentCaptures: 1
| UnprocessedYuvBufferMask: 0
+ 1: ACSynchronizeStage
+ 2: AeAfApplyStage
+ 3: AcPluginStage
| operation: opApplyPreCapture
+ 4: AcMergeStage
+ 5: TempBufferAcquireStage
| Buffer Index: 2
| BufferRequirements: 1920x1096 BL Y8 420
+ 6: TempBufferAcquireStage
| Buffer Index: 3
| BufferRequirements: 1932x1 Pitch NonColor8
+ 7: SensorISPCaptureStage
| Source GUID: 2
| Output A Buffer: 2
| SensorMetadata Buffer: 3
+ 8: StatsBufferAcquireStage
| Buffer Index: 1
| BufferRequirements: 640x366 Pitch Y8 420
+ 9: BlitStage
| Input Buffer: 2
| Output Buffer: 1
| Filter: Nearest
| Transform: None
| Src Rect: Not used
| Dst Rect: Not used
+ 10: StatsUpdateStage
| Outut Meta Buffer: 3
+ 11: BufferReturnStage
| Output A Buffer: 3
+ 12: AcPluginStage
| operation: opAnalyzePostCapture
+ 13: AfAnalysisStage
+ 14: BlitStage
| Input Buffer: 2
| Output Buffer: 0
| Filter: Smart
| Transform: None
| Src Rect: [0, 0, 1920, 1096]
| Dst Rect: Not used
+ 15: MonitorStage
+ 16: ExifStage
+ 17: MakerNoteStage
+ 18: BufferReturnStage
| Output A Buffer: 0
+ 19: MetadataReturnStage
+ 20: BufferReturnStage
| Output A Buffer: 2
Created fiber 0x7f400008c0 for CC 101
Thread 1 is working on CC 101
CC 101 completed step 0 in fiber 0x7f400008c0
CC 101 processing step 1 in fiber 0x7f400008c0
FiberScheduler: cc 101, fiber 0x7f400008c0 in progress...
Thread 1 is waiting
Thread 2 is waiting
cc 101(0) runCount=0 runIspOut=0, latest ccId=0
FiberScheduler: cc 101, fiber 0x7f400008c0 succeeded async operation
Thread 3 is working on CC 101
CC 101 processing step 2 in fiber 0x7f400008c0
NV AE and AfApply algorithms are active.
Thread 4 is waiting
Thread 3 is waiting
CC 101 processing step 3 in fiber 0x7f400008c0
Thread 1 is waiting
Thread 2 is working on CC 101
CC 101 processing step 4 in fiber 0x7f400008c0
Thread 4 is waiting
Created fiber 0x7f40000d00 for CC 102
Thread 3 is working on CC 102
CC 102 completed step 0 in fiber 0x7f40000d00
CC 102 processing step 1 in fiber 0x7f40000d00
FiberScheduler: cc 102, fiber 0x7f40000d00 in progress...
Thread 3 is waiting
Thread 1 is waiting
cc 102(1) runCount=1 runIspOut=0, latest ccId=0
FiberScheduler: cc 102, fiber 0x7f40000d00 succeeded async operation
Thread 4 is working on CC 102
CC 102 processing step 2 in fiber 0x7f40000d00
Thread 4 is waiting
Thread 3 is waiting
Thread 2 is waiting
Thread 1 is waiting
CC 102 processing step 3 in fiber 0x7f40000d00
CC 102 processing step 4 in fiber 0x7f40000d00
Thread 4 is waiting
CC 101 completed step 5 in fiber 0x7f400008c0
CC 101 completed step 6 in fiber 0x7f400008c0
CC 101 processing step 7 in fiber 0x7f400008c0
Thread 4 is waiting
Thread 4 is waiting
Thread 2 is waiting
Thread 1 is waiting
Thread 3 is waiting
PowerServiceUtils:calculateReqClock: entered
PowerServiceHw:addRequest: table size: before: 0, after:1
request table for VI 0:
req[0]: guID=2, stageID=SensorIspCapture
req[0]: inW=1932, inH=1102, inBpp = 10, fps=60
req[0]: outW=0, outH=0, outBpp=0
req[0]: clock=288000000, pixelRate=288000000, timeout=450
req[0]: isoBw=0, timeout=450
req[0]: non_isoBw=0, timeout=450
request table for CSI 0:
req[0]: clock=0, pixelRate=288000000, timeout=450
PowerServiceHw:setClock: PowerServiceHw[1]: requested_clock_Hz=288000000
request table for ISP 0:
req[0]: inW=1932, inH=1102, inBpp = 10, fps=60FiberScheduler: cc 102, fiber 0x7f40000d00 succeeded async operation
req[0]: outW=1920, outH=1096, outBpp=12
req[0]: isoBw=432000, timeout=450
PowerServiceHw:setClock: PowerServiceHw[2]: requested_clock_Hz=288000000
CC 102 completed step 5 in fiber 0x7f40000d00
CC 102 completed step 6 in fiber 0x7f40000d00
CC 102 processing step 7 in fiber 0x7f40000d00
Thread 4 is waiting
Thread 2 is waiting
PowerServiceHwIsp:setLaBw: m_bwVal_Iso=432000 and m_bwVal_NonIso=0
PowerServiceCore:setCameraBw: totalIsoBw=432000
Sensor_WriteExposure: INPUT coarseTime:2302, expTime:0.016632
NvPclDriver_UpdateOutputSettings: OUTPUT coarseTime:2302, expTime:0.016626
SCF: Error Timeout: (propagating from src/services/capture/CaptureServiceEvent.cpp, function wait(), line 59)
Error: Camera HwEvents wait, this may indicate a hardware timeout occured,abort current/incoming cc
Created fiber 0x7f40000f20 for CC 103
Thread 1 is working on CC 103
Fiber 0x7f40000f20 is aborting in CC 2
launchCC abort cc 104
FiberScheduler: cc 103, fiber 0x7f40000f20 aborted
Error: waitCsiFrameStart timeout guid 2
Sensor_WriteGain: INPUT gainCtrl:201 analogGain:2.004169
Error: waitCsiFrameStart Something went wrong with waiting on frame start
Created fiber 0x7f897ec160 for CC 104
Thread 3 is working on CC 104
Fiber 0x7f897ec160 is aborting in CC 3
FiberScheduler: cc 104, fiber 0x7f897ec160 aborted
SCF: Error Timeout: (propagating from src/api/Session.cpp, function capture(), line 731)
NvPclDriver_UpdateOutputSettings: OUTPUT analogGain:2.003906
launchCC abort cc 105
Thread 4 is working on CC 105
Fiber 0x7f897e82c0 is aborting in CC 3
FiberScheduler: cc 105, fiber 0x7f897e82c0 aborted
Created fiber 0x7f897e82c0 for CC 105
launchCC abort cc 106
Thread 2 is working on CC 106
Fiber 0x7f897f0b10 is aborting in CC 3
FiberScheduler: cc 106, fiber 0x7f897f0b10 aborted
Created fiber 0x7f897f0b10 for CC 106
launchCC abort cc 107
Created fiber 0x7f897f1ba0 for CC 107
launchCC abort cc 108
Created fiber 0x7f897f2c30 for CC 108
launchCC abort cc 109
Created fiber 0x7f897f3cc0 for CC 109
launchCC abort cc 110
Created fiber 0x7f897f4d50 for CC 110
FiberScheduler: cc 101, fiber 0x7f400008c0 aborted in async operation
FiberScheduler: fiber 0x7f897ec160 exiting
disposing CC 104
Thread 3 is working on CC 107
Fiber 0x7f897f1ba0 is aborting in CC 3
FiberScheduler: cc 107, fiber 0x7f897f1ba0 aborted
FiberScheduler: fiber 0x7f897f1ba0 exiting
disposing CC 107
Thread 3 is working on CC 108
Fiber 0x7f897f2c30 is aborting in CC 3
FiberScheduler: cc 108, fiber 0x7f897f2c30 aborted
FiberScheduler: fiber 0x7f897f2c30 exiting
disposing CC 108
Thread 3 is working on CC 109
Fiber 0x7f897f3cc0 is aborting in CC 3
FiberScheduler: cc 109, fiber 0x7f897f3cc0 aborted
FiberScheduler: fiber 0x7f897e82c0 exiting
disposing CC 105
Thread 4 is working on CC 110
Fiber 0x7f897f4d50 is aborting in CC 3
FiberScheduler: cc 110, fiber 0x7f897f4d50 aborted
FiberScheduler: fiber 0x7f897f4d50 exiting
Thread 4 is waiting
FiberScheduler: fiber 0x7f897f0b10 exiting
disposing CC 106
Thread 2 is waiting
FiberScheduler: fiber 0x7f400008c0 exiting
FiberScheduler: cc 102, fiber 0x7f40000d00 aborted in async operation
FiberScheduler: fiber 0x7f40000d00 exiting
disposing CC 102
I also use v4l2-ctl to capture raw frame from IMX274 (/dev/video1) by the following command:
./v4l2-ctl --verbose --set-fmt-video=width=1920,height=1080,pixelformat=RG10 --stream-mmap --set-ctrl bypass_mode=0 --stream-count=10 -d /dev/video1 --stream-to=z_1920x1080.raw
The above command works correctly. It just turns on IMX274, captures frames, then turns off IMX274 without touching IMX377.
Can anyone help me with this issue ?
