i have a Jetson Xavier AGX and wanted to install AutowareAuto by using the pre installed docker from Jetpack 4.4.
i could install the AutowareAuto ADE
i could start with ade start and ade enter
source /opt/AutowareAuto/setup.bash → ok
then running → rviz2 -d /home/${USER}/ autowareclass2020/code/src/01_DevelopmentEnvironment/aw_class2020.rviz creates following error. same when i run ros2 run rviz2 rviz2
Error
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to ‘/tmp/runtime-aixavier24’
libEGL warning: DRI2: failed to authenticate
libGL error: No matching fbConfigs or visuals found
libGL error: failed to load driver: swrast
[ERROR] [rviz2]: Failed to create an OpenGL context. BadValue (integer parameter out of range for operation)
[ERROR] [rviz2]: RenderingAPIException: Unable to create a suitable GLXContext in GLXContext::GLXContext at /tmp/binarydeb/ros-dashing-rviz-ogre-vendor-6.1.6/obj-aarch64-linux-gnu/ogre-master-ca665a6-prefix/src/ogre-master-ca665a6/RenderSystems/GLSupport/src/GLX/OgreGLXContext.cpp (line 60) …
to verify that it is an ROS2 Problem i was running ros2 run rviz2 rviz2 and get the same error. I have the same installation but for ( ade+x86_64) on an Ubuntu 18.04 intel machine and its working well.
Yesterday night after some research i found following article, but could not test it now
