Docker GPU acceleration on Jetson AGX for Ubuntu-18.04 image
I’m trying to get GPU acceleration working for a docker image running on the Jetson AGX developer kit, running the latest JetPack 4.1.1 release.
I decided to build an Ubuntu-18.04 docker image to minimize the differences with the host Jetson AGX root filesystem.
libGL.so is present in cd /usr/lib/aarch64-linux-gnu/ for Ubuntu-18.04. I also compared the filesizes of the contents of all the libGL* files in the docker image and the host Jetson AGX rootfilesystem and the file sizes match. I have also applied all the binaries from the JetPack 4.1.1. driver package for Jetson AGX.
However, when I try to run glxgears, I get the following error:
$ LIBGL_DEBUG=verbose glxgears
X Error of failed request:  BadValue (integer parameter out of range for operation)
  Major opcode of failed request:  154 (GLX)
  Minor opcode of failed request:  3 (X_GLXCreateContext)
  Value in failed request:  0x0
  Serial number of failed request:  31
  Current serial number in output stream:  32
I’m running the docker container using the following script and adding a bunch of devices for GPU control. Perhaps I’m missing something here:
#!/bin/sh
HOST_IP=`hostname -I | awk '{print $1}'`
REPOSITORY='jetson-agx/opengl'
TAG='bionic'
# setup pulseaudio cookie
if [ x"$(pax11publish -d)" = x ]; then
    start-pulseaudio-x11;
    echo `pax11publish -d | grep --color=never -Po '(?<=^Cookie: ).*'`
fi
# run container
xhost +local:root
docker run -it \
  --device /dev/nvhost-as-gpu \
  --device /dev/nvhost-ctrl \
  --device /dev/nvhost-ctrl-gpu \
  --device /dev/nvhost-ctxsw-gpu \
  --device /dev/nvhost-dbg-gpu \
  --device /dev/nvhost-gpu \
  --device /dev/nvhost-prof-gpu \
  --device /dev/nvhost-sched-gpu \
  --device /dev/nvhost-tsg-gpu \
  --device /dev/nvmap \
  --device /dev/snd \
  -e DISPLAY \
  -e PULSE_SERVER=tcp:$HOST_IP:4713 \
  -e PULSE_COOKIE_DATA=`pax11publish -d | grep --color=never -Po '(?<=^Cookie: ).*'` \
  -e QT_GRAPHICSSYSTEM=native \
  -e QT_X11_NO_MITSHM=1 \
  -v /dev/shm:/dev/shm \
  -v /etc/localtime:/etc/localtime:ro \
  -v /tmp/.X11-unix:/tmp/.X11-unix \
  -v /var/run/dbus/system_bus_socket:/var/run/dbus/system_bus_socket:ro \
  -v ${XDG_RUNTIME_DIR}/pulse/native:/run/user/1000/pulse/native \
  -v ~/mount/backup:/backup \
  -v ~/mount/data:/data \
  -v ~/mount/project:/project \
  -v ~/mount/tool:/tool \
  --rm \
  --name jetson-agx-opengl-${TAG} \
  ${REPOSITORY}:${TAG}
xhost -local:root
I found out that the docker container cannot access the GPU when running ./deviceQuery with user namespace remapping enabled.
If I disable docker user namespace remapping, CUDA-10.0 on Ubuntu-18.04 works. You should ensure that mesa-utils is also included in the image, so that for Ubuntu-18.04 it pulls in libglvnd0 as a dependency for deviceQuery to work.
glxgears still doesn’t run however.
Has anyone been able to get Docker OpenGL GPU apps working on Jetson AGX?
You will need to enable the GPU access:
--device="/dev/nvhost-ctrl \
          /dev/nvmap \
          /dev/nvhost-gpu \
          /dev/nvhost-as-gpu"
Here is a tutorial from the community for your reference:
https://github.com/Technica-Corporation/Tegra-Docker#device-parameters
Hi AastaLLL,
I went though your instructions once again and I noticed that I was missing the --net=host parameter in my docker run command. After I added that, glxgears works.
$ LIBGL_DEBUG=verbose glxinfo
name of display: :1
display: :1  screen: 0
direct rendering: Yes
server glx vendor string: NVIDIA Corporation
server glx version string: 1.4
Here are the files for building a dockerimage for Jetson AGX using JetPack-4.1.1 and Ubuntu-18.04.
This Dockerfile includes several build tools because I’m using it as a base nvidia/opengl image for ROS development.
I’m mapping the /usr/local/cuda/lib64 folder, in this version of the Dockerfile, to the docker container. I plan on creating another nvidia/cudagl image later on, so I can have better control over the version of CUDA libraries included in the docker image to have better control when using specific versions of deep learning library frameworks.
The only issue I have with the current solution is that this doesn’t work with Docker user namespace remapping enabled.
build.sh
#!/bin/sh
BUILD_DATE=$(date -u +'%Y-%m-%d-%H:%M:%S')
CODE_NAME='bionic'
JETPACK_VERSION='4.4.1'
USER='developer'
USER_ID='1000'
TAG="jetpack-$JETPACK_VERSION-$CODE_NAME"
# use tar to dereference the symbolic links from the current directory,
# and then pipe them all to the docker build - command
tar -czh . | docker build - \
  --build-arg REPOSITORY=arm64v8/ubuntu \
  --build-arg TAG=$CODE_NAME \
  --build-arg BUILD_VERSION=$JETPACK_VERSION \
  --build-arg BUILD_DATE=$BUILD_DATE \
  --build-arg USER=$USER \
  --build-arg UID=$USER_ID \
  --tag=jetson-agx/opengl:$TAG
Dockerfile
# jetson-agx/opengl:jetpack-$BUILD_VERSION-bionic
ARG REPOSITORY
ARG TAG
FROM ${REPOSITORY}:${TAG}
LABEL maintainer "Elvis Dowson"
# args
ARG BUILD_VERSION
ARG USER
ARG UID
# setup environment variables
ENV container docker
ENV NVIDIA_DRIVER_CAPABILITIES ${NVIDIA_DRIVER_CAPABILITIES},display
# set the locale
ENV LC_ALL=C.UTF-8 \
    LANG=C.UTF-8 \
    LANGUAGE=C.UTF-8
# install packages
RUN apt-get update \
    && apt-get install -q -y \
    dirmngr \
    gnupg2 \
    lsb-release \
    && rm -rf /var/lib/apt/lists/*
# setup sources.list
RUN echo "deb-src http://us.archive.ubuntu.com/ubuntu/ $(lsb_release -cs) main restricted \n\
deb-src http://us.archive.ubuntu.com/ubuntu/ $(lsb_release -cs)-updates main restricted \n\
deb-src http://us.archive.ubuntu.com/ubuntu/ $(lsb_release -cs)-backports main restricted universe multiverse \n\
deb-src http://security.ubuntu.com/ubuntu $(lsb_release -cs)-security main restricted" \
    > /etc/apt/sources.list.d/official-source-repositories.list
# install build tools
    && DEBIAN_FRONTEND=noninteractive TERM=linux apt-get install --no-install-recommends -q -y \
    apt-transport-https \
    apt-utils \
    bash-completion \
    build-essential \
    ca-certificates \
    clang \
    clang-format \
    cmake \
    cmake-curses-gui \
    curl \
    gconf2 \
    gconf-service \
    gdb \
    git-core \
    git-gui \
    gvfs-bin \
    inetutils-ping \
    llvm \
    llvm-dev \
    nano \
    net-tools \
    pkg-config \
    shared-mime-info \
    software-properties-common \
    sudo \
    tzdata \
    unzip \
    wget \
    && apt-get autoremove -y \
# download and install nvidia jetson xavier driver package
RUN if [ "$BUILD_VERSION" = "3.3"   ]; then \
      echo "downloading jetpack-$BUILD_VERSION" ; \
      wget -qO- https://developer.download.nvidia.com/devzone/devcenter/mobile/jetpack_l4t/3.3/lw.xd42/JetPackL4T_33_b39/Tegra186_Linux_R28.2.1_aarch64.tbz2 | \
      tar -xvj -C /tmp/ ; \
      cd /tmp/Linux_for_Tegra ; \
    elif [ "$BUILD_VERSION" = "4.4.1" ]; then \
	  wget -qO- https://developer.download.nvidia.com/devzone/devcenter/mobile/jetpack_l4t/4.1.1/xddsn.im/JetPackL4T_4.1.1_b57/Jetson_Linux_R31.1.0_aarch64.tbz2 | \
      # fix error in tar command when extracting configuration files, by overwriting existing configuration files \
      sed -i -e 's@tar xpfm ${LDK_NV_TEGRA_DIR}/config.tbz2@tar --overwrite -xpmf ${LDK_NV_TEGRA_DIR}/config.tbz2@g' apply_binaries.sh ; \
    else \
      echo "error: please specify jetpack version in build.sh" \
      exit 1 ;\
    fi \
    && ./apply_binaries.sh -r / \
    # fix erroneous entry in /etc/ld.so.conf.d/nvidia-tegra.conf \
    && echo "/usr/lib/aarch64-linux-gnu/tegra" > /etc/ld.so.conf.d/nvidia-tegra.conf \
    # add missing /usr/lib/aarch64-linux-gnu/tegra/ld.so.conf \
    && echo "/usr/lib/aarch64-linux-gnu/tegra" > /usr/lib/aarch64-linux-gnu/tegra/ld.so.conf \
    && update-alternatives --install /etc/ld.so.conf.d/aarch64-linux-gnu_GL.conf aarch64-linux-gnu_gl_conf /usr/lib/aarch64-linux-gnu/tegra/ld.so.conf 1000 \
    # fix erroneous entry in /usr/lib/aarch64-linux-gnu/tegra-egl/ld.so.conf \
    && echo "/usr/lib/aarch64-linux-gnu/tegra-egl" > /usr/lib/aarch64-linux-gnu/tegra-egl/ld.so.conf \
    && update-alternatives --install /etc/ld.so.conf.d/aarch64-linux-gnu_EGL.conf aarch64-linux-gnu_egl_conf /usr/lib/aarch64-linux-gnu/tegra-egl/ld.so.conf 1000 \
    && rm -Rf /tmp/Linux_for_Tegra
# install packages
    mesa-utils \
# create user
ENV HOME /home/$USER
RUN adduser $USER --uid $UID --disabled-password --gecos "" \
    && usermod -aG audio,video $USER \
    && echo "$USER ALL=(ALL) NOPASSWD: ALL" >> /etc/sudoers
# switch to non-root user
USER $USER
# labels
LABEL org.label-schema.schema-version="1.0"
LABEL org.label-schema.name="jetson-agx/opengl:jetpack-$BUILD_VERSION-bionic"
LABEL org.label-schema.description="NVIDIA Jetson AGX JetPack-$BUILD_VERSION OpenGL - Ubuntu-18.04."
LABEL org.label-schema.version=$BUILD_VERSION
LABEL org.label-schema.docker.cmd="xhost +local:root \
docker run -it \
  --device /dev/snd \
  --net=host \
  -e DISPLAY \
  -v /usr/local/cuda/lib64:/usr/local/cuda/lib64 \
  --rm \
  --name jetson-agx-opengl-jetpack-$BUILD_VERSION-bionic \
  jetson-agx/opengl:jetpack-$BUILD_VERSION-bionic \
xhost -local:root"
# set the working directory
WORKDIR $HOME
# update .bashrc
RUN echo \
'export LD_LIBRARY_PATH=/usr/local/cuda/lib64:/usr/lib/aarch64-linux-gnu/tegra:/usr/lib/aarch64-linux-gnu/tegra-egl:/usr/lib/aarch64-linux-gnu:/usr/local/lib:$LD_LIBRARY_PATH\n\
export NO_AT_BRIDGE=1\n\
export PATH=/usr/local/cuda/bin:$PATH\n\
export PS1="${debian_chroot:+($debian_chroot)}\u:\W\$ "' \
    >> $HOME/.bashrc
CMD ["bash"]
run-standalone.sh
#!/bin/sh
CODE_NAME='bionic'
fi
# run container
xhost +local:root
docker run -it \
  --device /dev/snd \
  --net=host \
  -e DISPLAY \
  --rm \
xhost -local:root
Just came across this; thanks for putting this info out there. Is there a quick test you can propose that would verify that containers created from this image using this run script function as expected? I tried running glxgears and I received an error:
developer:~$ glxgears
  Serial number of failed request:  27
  Current serial number in output stream:  28
You mention that you are using this for ros development, which interests me as well. Do you have an example Dockerfile that extends the one you have already provided to allow running rviz in a container and viewing the gui on the host?
Edit: just saw the comments above about glxgears. I will add the --net=host option and retry
You’d need to use the --net=host option to get it to work.
This video shows a screen recording captured directly from an NVIDIA Jetson AGX Xavier, with ros running from within a docker container, with the AGX as the host.
You should be able to simply add the required ROS packages to your base OpenGL dockerfile and run rviz from a container session.
If you want to run docker container on the Jetson and get 3D accelerated desktop or window to appear on another desktop machine, take a look at these instructions here:
Read the section on setting up and using VirtualGL and TurboVNC.
Thank you for your response, though it still isn’t working as expected. Here are the files, for reference:
build.sh
#!/bin/sh
CODE_NAME='bionic'
USER='developer'
USER_ID='1000'
tar -czh . | docker build --network=host \
  --tag=jetson-agx/opengl:$TAG \
Dockerfile
ARG REPOSITORY
ARG TAG
# args
ARG BUILD_VERSION
ARG USER
ARG UID
# set the locale
    LANG=C.UTF-8 \
    LANGUAGE=C.UTF-8
# install packages
    dirmngr \
    gnupg2 \
    lsb-release \
    apt-utils \
    bash-completion \
    build-essential \
    ca-certificates \
    clang \
    clang-format \
    cmake \
    cmake-curses-gui \
    curl \
    gconf2 \
    gconf-service \
    gdb \
    git-core \
    git-gui \
    gvfs-bin \
    inetutils-ping \
    llvm \
    llvm-dev \
    nano \
    net-tools \
    pkg-config \
    shared-mime-info \
    sudo \
    tzdata \
    unzip \
    wget \
    else \
      exit 1 ;\
    fi \
# install packages
    mesa-utils \
# create user
USER $USER
# labels
docker run -it --rm \
  --device /dev/snd \
  --net=host \
  -e DISPLAY \
  --name jetson-agx-opengl-${TAG}-c \
  ${REPOSITORY}:${TAG} \
xhost -local:root"
WORKDIR $HOME
# update .bashrc
RUN echo \
    >> $HOME/.bashrc
CMD ["bash"]
run-standalone.sh
#!/bin/sh
#HOST_IP=192.168.0.84
CODE_NAME='bionic'
fi
# run container
xhost +local:root
  --device /dev/snd \
  --privileged \
  --runtime=nvidia \
  --net=host \
  -e DISPLAY \
xhost -local:root
Is there something else that I am missing? Thanks!
Please take a look at your scripts carefully. Just do a meld/diff of your files and some of the scripts that I originally posted here.
I did this at my end.
I noticed that you decided to add parameters to your scripts which are designed to work with nvidia-docker2 runtime on an x86_64 host, a package which is not yet available for aarch64. This is why you’re passing several gpu related device files to the container.
