I’m posting the solution for getting an Ubuntu-16.04 docker image with JetPack 4.4.1 running on Jetson AGX which currently ships with Ubuntu-18.04.
The only thing that doesn’t work at the moment is username space remapping. Additionally, I haven’t mapped the host’s /usr/lib/cuda/lib64 folder to the docker container. You can edit the run-standalone.sh script if you need that or create another dockerfile based on this opengl image and add CUDA libraries to it.
The only extra step I need to do, compared to the Ubuntu-18.04 docker image that I created earlier was to add libglvnd.
build.sh
#!/bin/sh
BUILD_DATE=$(date -u +'%Y-%m-%d-%H:%M:%S')
CODE_NAME='xenial'
LIBGLVND_VERSION='v1.1.0'
JETPACK_VERSION='4.4.1'
TAG="jetpack-$JETPACK_VERSION-$CODE_NAME"
# use tar to dereference the symbolic links from the current directory,
# and then pipe them all to the docker build - command
tar -czh . | docker build - \
--build-arg REPOSITORY=arm64v8/ubuntu \
--build-arg TAG=$CODE_NAME \
--build-arg LIBGLVND_VERSION=$LIBGLVND_VERSION \
--build-arg BUILD_VERSION=$JETPACK_VERSION \
--build-arg BUILD_DATE=$BUILD_DATE \
--tag=jetson-agx/opengl:$TAG
Dockerfile
# jetson-agx/opengl:jetpack-$BUILD_VERSION-xenial
# build libglvnd
ARG REPOSITORY
ARG TAG
FROM ${REPOSITORY}:${TAG} as glvnd
RUN apt-get update \
&& DEBIAN_FRONTEND=noninteractive TERM=linux apt-get install --no-install-recommends -q -y \
autoconf \
automake \
ca-certificates \
git-core \
libtool \
pkg-config \
python \
libxext-dev \
libx11-dev \
x11proto-gl-dev \
&& rm -rf /var/lib/apt/lists/*
# args
ARG LIBGLVND_VERSION
WORKDIR /opt/libglvnd
RUN git clone --branch="${LIBGLVND_VERSION}" https://github.com/NVIDIA/libglvnd.git . \
&& ./autogen.sh \
&& ./configure --prefix=/usr/local --libdir=/usr/local/lib/aarch64-linux-gnu \
&& make -j"$(nproc)" install-strip \
&& find /usr/local/lib/aarch64-linux-gnu -type f -name 'lib*.la' -delete
# build opengl base image
ARG REPOSITORY
ARG TAG
LABEL maintainer "Elvis Dowson"
# args
ARG BUILD_VERSION
# setup environment variables
ENV container docker
ENV NVIDIA_DRIVER_CAPABILITIES ${NVIDIA_DRIVER_CAPABILITIES},display
# set the locale
ENV LC_ALL=C.UTF-8 \
LANG=C.UTF-8 \
LANGUAGE=C.UTF-8
# install packages
&& apt-get install -q -y \
dirmngr \
gnupg2 \
lsb-release \
# setup sources.list
RUN echo "deb-src http://us.archive.ubuntu.com/ubuntu/ $(lsb_release -cs) main restricted \n\
deb-src http://us.archive.ubuntu.com/ubuntu/ $(lsb_release -cs)-updates main restricted \n\
deb-src http://us.archive.ubuntu.com/ubuntu/ $(lsb_release -cs)-backports main restricted universe multiverse \n\
deb-src http://security.ubuntu.com/ubuntu $(lsb_release -cs)-security main restricted" \
> /etc/apt/sources.list.d/official-source-repositories.list
# install build tools
apt-transport-https \
apt-utils \
bash-completion \
build-essential \
ca-certificates \
clang \
clang-format \
cmake \
cmake-curses-gui \
curl \
gconf2 \
gconf-service \
gdb \
git-core \
git-gui \
gvfs-bin \
inetutils-ping \
llvm \
llvm-dev \
nano \
net-tools \
pkg-config \
shared-mime-info \
software-properties-common \
sudo \
tzdata \
unzip \
wget \
&& apt-get autoremove -y \
# download and install nvidia jetson xavier driver package
RUN if [ "$BUILD_VERSION" = "3.3" ]; then \
echo "downloading jetpack-$BUILD_VERSION" ; \
wget -qO- https://developer.download.nvidia.com/devzone/devcenter/mobile/jetpack_l4t/3.3/lw.xd42/JetPackL4T_33_b39/Tegra186_Linux_R28.2.1_aarch64.tbz2 | \
tar -xvj -C /tmp/ ; \
cd /tmp/Linux_for_Tegra ; \
elif [ "$BUILD_VERSION" = "4.4.1" ]; then \
wget -qO- https://developer.download.nvidia.com/devzone/devcenter/mobile/jetpack_l4t/4.1.1/xddsn.im/JetPackL4T_4.1.1_b57/Jetson_Linux_R31.1.0_aarch64.tbz2 | \
# fix error in tar command when extracting configuration files, by overwriting existing configuration files \
sed -i -e 's@tar xpfm ${LDK_NV_TEGRA_DIR}/config.tbz2@tar --overwrite -xpmf ${LDK_NV_TEGRA_DIR}/config.tbz2@g' apply_binaries.sh ; \
else \
echo "error: please specify jetpack version in build.sh" \
exit 1 ;\
fi \
&& ./apply_binaries.sh -r / \
# fix erroneous entry in /etc/ld.so.conf.d/nvidia-tegra.conf \
&& echo "/usr/lib/aarch64-linux-gnu/tegra" > /etc/ld.so.conf.d/nvidia-tegra.conf \
# add missing /usr/lib/aarch64-linux-gnu/tegra/ld.so.conf \
&& echo "/usr/lib/aarch64-linux-gnu/tegra" > /usr/lib/aarch64-linux-gnu/tegra/ld.so.conf \
&& update-alternatives --install /etc/ld.so.conf.d/aarch64-linux-gnu_GL.conf aarch64-linux-gnu_gl_conf /usr/lib/aarch64-linux-gnu/tegra/ld.so.conf 1000 \
# fix erroneous entry in /usr/lib/aarch64-linux-gnu/tegra-egl/ld.so.conf \
&& echo "/usr/lib/aarch64-linux-gnu/tegra-egl" > /usr/lib/aarch64-linux-gnu/tegra-egl/ld.so.conf \
&& update-alternatives --install /etc/ld.so.conf.d/aarch64-linux-gnu_EGL.conf aarch64-linux-gnu_egl_conf /usr/lib/aarch64-linux-gnu/tegra-egl/ld.so.conf 1000 \
&& rm -Rf /tmp/Linux_for_Tegra
# copy libglvnd from the previous build stage
COPY --from=glvnd /usr/local/lib/aarch64-linux-gnu /usr/local/lib/aarch64-linux-gnu
# symlink to nvidia.json --> /usr/share/glvnd/egl_vendor.d/10_nvidia.json has already been added to the target rootfs by the nv_tegra/nvidia_drivers installation
RUN echo "/usr/local/lib/aarch64-linux-gnu" >> /etc/ld.so.conf.d/glvnd.conf \
&& ldconfig
# labels
LABEL org.label-schema.schema-version="1.0"
LABEL org.label-schema.name="jetson-agx/opengl:jetpack-$BUILD_VERSION-xenial"
LABEL org.label-schema.description="NVIDIA Jetson AGX JetPack-$BUILD_VERSION OpenGL - Ubuntu-16.04."
LABEL org.label-schema.version=$BUILD_VERSION
LABEL org.label-schema.docker.cmd="xhost +local:root \
docker run -it \
--device /dev/nvhost-as-gpu \
--device /dev/nvhost-ctrl \
--device /dev/nvhost-ctrl-gpu \
--device /dev/nvhost-ctxsw-gpu \
--device /dev/nvhost-dbg-gpu \
--device /dev/nvhost-gpu \
--device /dev/nvhost-prof-gpu \
--device /dev/nvhost-sched-gpu \
--device /dev/nvhost-tsg-gpu \
--device /dev/nvmap \
--device /dev/snd \
--net=host \
-e DISPLAY \
-e PULSE_SERVER=tcp:$HOST_IP:4713 \
-e PULSE_COOKIE_DATA=`pax11publish -d | grep --color=never -Po '(?<=^Cookie: ).*'` \
-e QT_GRAPHICSSYSTEM=native \
-e QT_X11_NO_MITSHM=1 \
-v /dev/shm:/dev/shm \
-v /etc/localtime:/etc/localtime:ro \
-v /tmp/.X11-unix:/tmp/.X11-unix \
-v /var/run/dbus/system_bus_socket:/var/run/dbus/system_bus_socket:ro \
-v ${XDG_RUNTIME_DIR}/pulse/native:/run/user/1000/pulse/native \
-v ~/mount/backup:/backup \
-v ~/mount/data:/data \
-v ~/mount/project:/project \
-v ~/mount/tool:/tool \
--rm \
--name jetson-agx-opengl-jetpack-$BUILD_VERSION-xenial \
jetson-agx/opengl:jetpack-$BUILD_VERSION-xenial \
xhost -local:root"
# update .bashrc
RUN echo \
'export LD_LIBRARY_PATH=/usr/local/cuda/lib64:/usr/lib/aarch64-linux-gnu/tegra:/usr/lib/aarch64-linux-gnu/tegra-egl:/usr/lib/aarch64-linux-gnu:/usr/local/lib/aarch64-linux-gnu:/usr/local/lib${LD_LIBRARY_PATH:+:${LD_LIBRARY_PATH}}\n\
export NO_AT_BRIDGE=1\n\
export PATH=/usr/local/cuda/bin:$PATH\n' \
>> $HOME/.bashrc
CMD ["bash"]
run-standalone.sh
#!/bin/sh
HOST_IP=`hostname -I | awk '{print $1}'`
REPOSITORY='jetson-agx/opengl'
CODE_NAME='xenial'
# setup pulseaudio cookie
if [ x"$(pax11publish -d)" = x ]; then
start-pulseaudio-x11;
echo `pax11publish -d | grep --color=never -Po '(?<=^Cookie: ).*'`
fi
# run container
xhost +local:root
docker run -it \
--device /dev/snd \
--net=host \
-e DISPLAY \
--rm \
--name jetson-agx-opengl-${TAG} \
xhost -local:root
