Hey I compiled OpenCv on TX1 its capturing images and saving images but i am receiving following error at the end
gpu::setDevice(0);
int detections_number;
cv::gpu::CascadeClassifier_GPU cascade_gpu;
ostringstream filename_cv;
filename_cv << imageCnt << ".jpg";
cascade_gpu.load("haarcascade_frontalface_alt.xml");
cv::Mat image_cv4t = imread(filename.str().c_str(), CV_LOAD_IMAGE_UNCHANGED);
gpu::GpuMat image_cv4t_device(image_cv4t);
putText(image_cv4t, "Camera:1", Point(53,110),
FONT_HERSHEY_SIMPLEX, 1, Scalar(255,250,0), 1, CV_AA);
gpu::GpuMat objbuf;
detections_number = cascade_gpu.detectMultiScale( image_cv4t_device,
objbuf, 1.2, 2);
cv::Mat obj_host;
Rect* faces = obj_host.ptr<Rect>();
objbuf.colRange(0, detections_number).download(obj_host);
for(int i = 0; i < detections_number;i)
cv::rectangle(image_cv4t, faces[i], Scalar(255));
imwrite(filename_cv.str(),image_cv4t);
Done! Press Enter to exit…
OpenCV Error: Gpu API call (NCV Assertion Failed: cudaError_t=29, file=/hdd/buildbot/slave_jetson_tx_3/35-O4T-L4T-R24/opencv/modules/gpu/src/nvidia/core/NCV.cu, line=336
) in NCVDebugOutputHandler, file /hdd/buildbot/slave_jetson_tx_3/35-O4T-L4T-R24/opencv/modules/gpu/src/cascadeclassifier.cpp, line 173
terminate called after throwing an instance of ‘cv::Exception’
what(): /hdd/buildbot/slave_jetson_tx_3/35-O4T-L4T-R24/opencv/modules/gpu/src/cascadeclassifier.cpp:173: error: (-217) NCV Assertion Failed: cudaError_t=29, file=/hdd/buildbot/slave_jetson_tx_3/35-O4T-L4T-R24/opencv/modules/gpu/src/nvidia/core/NCV.cu, line=336
in function NCVDebugOutputHandler
Aborted
