What version of opencv installed in my Jetson?
Hi zotovsergei,
For JetPack-4.2.1, the OpenCV version is 3.3.1
You can check from sdkmanager → “Computer Vision” components
Thank you for the answer, I m confused by sea that in /usr/include i have the folder named opencv2?
Hi zotovsergei,
Are you install OpenCV by sdkmanager or by manually?
I used sdkmanager_0.9.13-4763_amd64, did not install OpenCV manually.
Hi zotovsergei,
Confirmed the “/usr/include/opencv2” folder is install by sdkmanager.
If you are not install by manually, the openCV version is 3.3.1.
