Openpose instruction on Xavier Devkit
Hi community member,
Could you please help in installing openpose on xavier board?
I could installed the caffe on devkit but I met some issue when installed the opepnpose.
Best regards.
Kaka
You can follow this installation guide first:
[url]https://github.com/CMU-Perceptual-Computing-Lab/openpose/blob/master/doc/installation_jetson_tx2_jetpack3.3.md[/url]
Steps should be similar although it is for TX2.
Hi AstaLLL
Thank you for your comments.
Did you confirm whether Xavier can work it with following this method?
I had some issue to install the openpose.
Best regards.
Kaka
well, I installed both openpose and tf-openpose at xavier, I did not use the script mentioned above but used custom opencv and custom caffe installation paths that I passed to cmake as arguments. However, it turned out to work kind of too slow in my case.
Hi @Andrey1984,
I was also able to run OpenPose, can you please share your performance details? For OpenPose, it was giving me 3 FPS. Whereas for movilenet_v2_large, it is giving me 30+ FPS.
