Openpose-Jetson AGX
I’ve been attempting to set up openpose on my AGX. Whenever I try to run a demo example,
./build/examples/openpose/openpose.bin --image_dir examples/media/ --net_resolution 80x32
It throws an error
Starting OpenPose demo…
Configuring OpenPose…
Starting thread(s)…
Auto-detecting all available GPUs… Detected 1 GPU(s), using 1 of them starting at GPU 0.
Killed
or it shuts down my device after a few attempts
I tried setting the power mode to MAXN; I believe it is related to memory, but I’m not sure how to get rid of it.
Killed error is sometimes related to the out-of-memory.
Would you mind monitoring Xavier with tegrastats to see if the memory is enough or not first?
$ sudo tegrastats
I have checked and It is going out of memory within a few seconds of running the demo .
Have you checked the below document to lower the memory requirement?
Thanks for the suggestion. I have tried this also but same error again
So you will need a more lightweight model.
Since GPU cannot use swap memory, the memory amount is limited by the hardware capability.
