I’ve posted a related topic a while ago (here), back then I couldn’t get it to work, but I did not really needed, tho vsxu running on the intel 530 is not that great.
Recently I’ve working with Blender and Android Studio. Everytime I open Blender and try to render it takes forever and the screen even freezes, watching 1080p videos will also get the screen to freeze from time to time. I always need to set the cpu-frequency to performance mode…
I’ll try to give as much info as I can, the problem is slighty different from the previous post, tho both problems won’t allow it to work. I’ve already tried to contact nvidia through their email(linux-bugs@nvidia.com) a couple of times without any sort of answer from their side.
uname -a
Linux bonobobo 5.9.1-1-default #1 SMP Mon Oct 26 07:02:23 UTC 2020 (435e92d) x86_64 x86_64 x86_64 GNU/Linux
lspci | grep VGA
00:02.0 VGA compatible controller: Intel Corporation HD Graphics 530 (rev 06)
lspci | grep NVIDIA
01:00.0 3D controller: NVIDIA Corporation GM206M [GeForce GTX 965M] (rev a1)
hwinfo --gfxcard
17: PCI 100.0: 0302 3D controller
[Created at pci.386]
Unique ID: VCu0.C4vYvkQe035
Parent ID: vSkL.ssGVCrpcUlF
SysFS ID: /devices/pci0000:00/0000:00:01.0/0000:01:00.0
SysFS BusID: 0000:01:00.0
Hardware Class: graphics card
Device Name: "NVIDIA N16E-GR"
Model: "Hewlett-Packard Company OMEN-17-w001nv"
Vendor: pci 0x10de "nVidia Corporation"
Device: pci 0x1427 "GM206M [GeForce GTX 965M]"
SubVendor: pci 0x103c "Hewlett-Packard Company"
SubDevice: pci 0x825b "OMEN-17-w001nv"
Revision: 0xa1
Driver: "nvidia"
Driver Modules: "nvidia"
Memory Range: 0xa3000000-0xa3ffffff (rw,non-prefetchable)
Memory Range: 0x90000000-0x9fffffff (ro,non-prefetchable)
Memory Range: 0xa0000000-0xa1ffffff (ro,non-prefetchable)
I/O Ports: 0x4000-0x4fff (rw)
Memory Range: 0xa4080000-0xa40fffff (ro,non-prefetchable,disabled)
IRQ: 16 (3 events)
Module Alias: "pci:v000010DEd00001427sv0000103Csd0000825Bbc03sc02i00"
Driver Info #0:
Driver Status: nouveau is not active
Driver Activation Cmd: "modprobe nouveau"
Driver Info #1:
Driver Status: nvidia_drm is active
Driver Activation Cmd: "modprobe nvidia_drm"
Driver Info #2:
Driver Status: nvidia is active
Driver Activation Cmd: "modprobe nvidia"
Config Status: cfg=new, avail=yes, need=no, active=unknown
Attached to: #12 (PCI bridge)
24: PCI 02.0: 0300 VGA compatible controller (VGA)
Unique ID: _Znp.eW0JZl5DxA3
SysFS ID: /devices/pci0000:00/0000:00:02.0
SysFS BusID: 0000:00:02.0
Device Name: "Intel Skylake HD Graphics ULT GT2"
Vendor: pci 0x8086 "Intel Corporation"
Device: pci 0x191b "HD Graphics 530"
Revision: 0x06
Driver: "i915"
Driver Modules: "i915"
Memory Range: 0xa2000000-0xa2ffffff (rw,non-prefetchable)
Memory Range: 0xb0000000-0xbfffffff (ro,non-prefetchable)
I/O Ports: 0x5000-0x503f (rw)
Memory Range: 0x000c0000-0x000dffff (rw,non-prefetchable,disabled)
IRQ: 129 (114394 events)
Module Alias: "pci:v00008086d0000191Bsv0000103Csd0000825Bbc03sc00i00"
Driver Info #0:
Driver Status: i915 is active
Driver Activation Cmd: "modprobe i915"
Primary display adapter: #24
ls -l /dev/nvidia*
crw-rw----+ 1 root video 195, 0 Oct 30 13:26 /dev/nvidia0
crw-rw----+ 1 root video 195, 255 Oct 30 13:26 /dev/nvidiactl
crw-rw----+ 1 root video 195, 254 Oct 30 13:26 /dev/nvidia-modeset
/dev/nvidia-caps:
total 0
cr-------- 1 root root 240, 1 Oct 30 13:53 nvidia-cap1
cr--r--r-- 1 root root 240, 2 Oct 30 13:53 nvidia-cap2
modprobe -D nvidia
install PATH=$PATH:/bin:/usr/bin; if /sbin/modprobe --ignore-install nvidia; then if /sbin/modprobe nvidia_uvm; then if [ ! -c /dev/nvidia-uvm ]; then mknod -m 660 /dev/nvidia-uvm c $(cat /proc/devices | while read major device; do if [ "$device" == "nvidia-uvm" ]; then echo $major; break; fi ; done) 0; chown :video /dev/nvidia-uvm; fi; if [ ! -c /dev/nvidia-uvm-tools ]; then mknod -m 660 /dev/nvidia-uvm-tools c $(cat /proc/devices | while read major device; do if [ "$device" == "nvidia-uvm" ]; then echo $major; break; fi ; done) 1; chown :video /dev/nvidia-uvm-tools; fi; fi; if [ ! -c /dev/nvidiactl ]; then mknod -m 660 /dev/nvidiactl c 195 255; chown :video /dev/nvidiactl; fi; devid=-1; for dev in $(ls -d /sys/bus/pci/devices/*); do vendorid=$(cat $dev/vendor); if [ "$vendorid" == "0x10de" ]; then class=$(cat $dev/class); classid=${class%%00}; if [ "$classid" == "0x0300" -o "$classid" == "0x0302" ]; then devid=$((devid+1)); if [ ! -c /dev/nvidia${devid} ]; then mknod -m 660 /dev/nvidia${devid} c 195 ${devid}; chown :video /dev/nvidia${devid}; fi; fi; fi; done; /sbin/modprobe nvidia_drm; if [ ! -c /dev/nvidia-modeset ]; then mknod -m 660 /dev/nvidia-modeset c 195 254; chown :video /dev/nvidia-modeset; fi; fi NVreg_DynamicPowerManagement=0x01 NVreg_DeviceFileUID=0 NVreg_DeviceFileGID=482 NVreg_DeviceFileMode=0660
lsmod | grep nvidia
nvidia_drm 61440 0
nvidia_modeset 1187840 1 nvidia_drm
nvidia 19775488 4 nvidia_modeset
drm_kms_helper 266240 2 nvidia_drm,i915
drm 585728 14 drm_kms_helper,nvidia_drm,i915
modinfo nvidia
filename: /lib/modules/5.9.1-1-default/updates/nvidia.ko
alias: char-major-195-*
version: 450.80.02
supported: external
license: NVIDIA
suserelease: openSUSE Tumbleweed
srcversion: 64FD5F62568F4AA5B5B96F7
alias: pci:v000010DEd*sv*sd*bc03sc02i00*
alias: pci:v000010DEd*sv*sd*bc03sc00i00*
depends:
retpoline: Y
vermagic: 5.9.1-1-default SMP mod_unload modversions
parm: NvSwitchRegDwords:NvSwitch regkey (charp)
parm: NvSwitchBlacklist:NvSwitchBlacklist=uuid[,uuid...] (charp)
parm: nv_cap_enable_devfs:Enable (1) or disable (0) nv-caps devfs support. Default: 1 (int)
parm: NVreg_ResmanDebugLevel:int
parm: NVreg_RmLogonRC:int
parm: NVreg_ModifyDeviceFiles:int
parm: NVreg_DeviceFileUID:int
parm: NVreg_DeviceFileGID:int
parm: NVreg_DeviceFileMode:int
parm: NVreg_InitializeSystemMemoryAllocations:int
parm: NVreg_UsePageAttributeTable:int
parm: NVreg_MapRegistersEarly:int
parm: NVreg_RegisterForACPIEvents:int
parm: NVreg_EnablePCIeGen3:int
parm: NVreg_EnableMSI:int
parm: NVreg_TCEBypassMode:int
parm: NVreg_EnableStreamMemOPs:int
parm: NVreg_EnableBacklightHandler:int
parm: NVreg_RestrictProfilingToAdminUsers:int
parm: NVreg_PreserveVideoMemoryAllocations:int
parm: NVreg_DynamicPowerManagement:int
parm: NVreg_DynamicPowerManagementVideoMemoryThreshold:int
parm: NVreg_EnableUserNUMAManagement:int
parm: NVreg_MemoryPoolSize:int
parm: NVreg_KMallocHeapMaxSize:int
parm: NVreg_VMallocHeapMaxSize:int
parm: NVreg_IgnoreMMIOCheck:int
parm: NVreg_NvLinkDisable:int
parm: NVreg_EnablePCIERelaxedOrderingMode:int
parm: NVreg_RegisterPCIDriver:int
parm: NVreg_RegistryDwords:charp
parm: NVreg_RegistryDwordsPerDevice:charp
parm: NVreg_RmMsg:charp
parm: NVreg_GpuBlacklist:charp
parm: NVreg_TemporaryFilePath:charp
parm: NVreg_AssignGpus:charp
nvidia-smi
No devices were found
dmesg | grep ‘NVRM|NVIDIA|nvidia’
[ 7.543650] nvidia: loading out-of-tree module taints kernel.
[ 7.543662] nvidia: module license 'NVIDIA' taints kernel.
[ 7.633774] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 7.657029] nvidia-nvlink: Nvlink Core is being initialized, major device number 239
[ 7.657828] nvidia 0000:01:00.0: enabling device (0000 -> 0003)
[ 7.757942] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 450.80.02 Wed Sep 23 01:13:39 UTC 2020
[ 7.900652] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 450.80.02 Wed Sep 23 00:48:09 UTC 2020
[ 7.910871] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ 7.910873] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 1
[ 9.336812] audit: type=1400 audit(1604064365.368:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=1019 comm="apparmor_parser"
[ 9.337817] audit: type=1400 audit(1604064365.372:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=1019 comm="apparmor_parser"
[ 46.305647] nvidia 0000:01:00.0: Enabling HDA controller
[ 48.225659] nvidia 0000:01:00.0: Enabling HDA controller
[ 52.250085] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x31:0xffff:973)
[ 52.250198] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 231.137699] nvidia 0000:01:00.0: Enabling HDA controller
[ 384.065801] nvidia 0000:01:00.0: Enabling HDA controller
[ 388.126050] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x31:0xffff:973)
[ 388.126072] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 541.381710] nvidia 0000:01:00.0: Enabling HDA controller
[ 719.809725] nvidia 0000:01:00.0: Enabling HDA controller
[ 789.825844] nvidia 0000:01:00.0: Enabling HDA controller
[ 793.906177] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x31:0xffff:973)
[ 793.906284] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 1031.201856] nvidia 0000:01:00.0: Enabling HDA controller
[ 1168.673735] nvidia 0000:01:00.0: Enabling HDA controller
[ 1172.738263] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x31:0xffff:973)
[ 1172.738286] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 1383.557742] nvidia 0000:01:00.0: Enabling HDA controller
[ 1387.558199] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x31:0xffff:973)
[ 1387.558226] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 1443.201867] nvidia 0000:01:00.0: Enabling HDA controller
[ 1447.202288] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x31:0xffff:973)
[ 1447.202329] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 1482.273759] nvidia 0000:01:00.0: Enabling HDA controller
[ 1486.274116] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x31:0xffff:973)
[ 1486.274219] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 1516.417777] nvidia 0000:01:00.0: Enabling HDA controller
[ 1520.466920] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x31:0xffff:973)
[ 1520.467028] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 1561.985877] nvidia 0000:01:00.0: Enabling HDA controller
[ 1565.986107] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x31:0xffff:973)
[ 1565.986210] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 1581.569720] nvidia 0000:01:00.0: Enabling HDA controller
[ 1585.618258] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x31:0xffff:973)
[ 1585.618280] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 1641.793883] nvidia 0000:01:00.0: Enabling HDA controller
[ 1645.794107] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x31:0xffff:973)
[ 1645.794210] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 1692.673888] nvidia 0000:01:00.0: Enabling HDA controller
[ 1696.674185] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x31:0xffff:973)
[ 1696.674217] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 1801.409893] nvidia 0000:01:00.0: Enabling HDA controller
[ 1805.462367] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x31:0xffff:973)
[ 1805.462406] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 1895.713812] nvidia 0000:01:00.0: Enabling HDA controller
[ 1967.425723] nvidia 0000:01:00.0: Enabling HDA controller
[ 1971.426346] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x31:0xffff:973)
[ 1971.426399] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 2606.977949] nvidia 0000:01:00.0: Enabling HDA controller
[ 2675.045772] nvidia 0000:01:00.0: Enabling HDA controller
[ 2722.341946] nvidia 0000:01:00.0: Enabling HDA controller
[ 3461.697861] nvidia 0000:01:00.0: Enabling HDA controller
[ 3468.353996] nvidia 0000:01:00.0: Enabling HDA controller
[ 3471.489999] nvidia 0000:01:00.0: Enabling HDA controller
[ 3480.421844] nvidia 0000:01:00.0: Enabling HDA controller
[ 3913.889844] nvidia 0000:01:00.0: Enabling HDA controller
[ 3917.890405] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x31:0xffff:973)
[ 3917.890427] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
cat /etc/X11/xorg.conf
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 450.80.02
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from data in "/etc/sysconfig/mouse"
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "IMPS/2"
Option "Device" "/dev/input/mice"
Option "Emulate3Buttons" "yes"
Option "ZAxisMapping" "4 5"
EndSection
# generated from default
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BusID "1:00:00"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "AllowEmptyInitialConfiguration" "True"
SubSection "Display"
Depth 24
EndSubSection
EndSection
ls -laR /etc/X11
/etc/X11:
total 16
drwxr-xr-x 1 root root 206 Oct 30 13:53 .
drwxr-xr-x 1 root root 5486 Oct 30 11:48 ..
-rw-r--r-- 1 root root 22 Oct 30 13:53 watch.txt
drwxr-xr-x 1 root root 36 Oct 17 18:30 xdm
drwxr-xr-x 1 root root 46 Oct 15 14:12 xinit
-rw-r--r-- 1 root root 1317 Oct 30 13:52 xorg.conf
-rw-r--r-- 1 root root 1317 Oct 30 13:52 xorg.conf.backup
drwxr-xr-x 1 root root 32 Oct 30 13:19 xorg.conf.d
-rw-r--r-- 1 root root 938 Oct 7 04:58 xorg.conf.install
-rw-r--r-- 1 root root 0 Oct 30 13:44 xorg.conf.nvidia-xconfig-original
/etc/X11/xdm:
total 8
drwxr-xr-x 1 root root 36 Oct 17 18:30 .
drwxr-xr-x 1 root root 206 Oct 30 13:53 ..
-rw-r--r-- 1 root root 1641 Oct 14 14:43 xdm-config
-rw-r--r-- 1 root root 820 Oct 14 14:43 Xservers
/etc/X11/xinit:
total 4
drwxr-xr-x 1 root root 46 Oct 15 14:12 .
lrwxrwxrwx 1 root root 41 Oct 7 13:24 xinitrc.common -> ../../../usr/etc/X11/xinit/xinitrc.common
drwxr-xr-x 1 root root 118 Oct 15 14:12 xinitrc.d
/etc/X11/xinit/xinitrc.d:
total 12
drwxr-xr-x 1 root root 118 Oct 15 14:12 .
drwxr-xr-x 1 root root 46 Oct 15 14:12 ..
-rwxr-xr-x 1 root root 199 Sep 30 16:26 50-systemd-user.sh
-rwxr-xr-x 1 root root 172 Aug 25 20:41 libcanberra-gtk-module.sh
-rwxr-xr-x 1 root root 40 Aug 26 01:32 xdg-user-dirs.sh
/etc/X11/xorg.conf.d:
total 4
drwxr-xr-x 1 root root 32 Oct 30 13:19 .
-rw-r--r-- 1 root root 399 Oct 7 05:00 00-keyboard.conf
prime-select nvidia
WARNING: Unable to use the nvidia-cfg library to query NVIDIA hardware.
ERROR: Unable to query GPU information
Reconfiguration failed
Restoring previous configuration: intel
inxi -G
Graphics: Device-1: Intel HD Graphics 530 driver: i915 v: kernel
Device-2: NVIDIA GM206M [GeForce GTX 965M] driver: nvidia v: 450.80.02
Device-3: Cheng Uei Precision Industry (Foxlink) HP Wide Vision HD type: USB driver: uvcvideo
Display: x11 server: X.Org 1.20.9 driver: modesetting FAILED: nvidia unloaded: fbdev,nouveau,nv,vesa
resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa DRI Intel HD Graphics 530 (SKL GT2) v: 4.6 Mesa 20.2.1
cat /etc/prime/xorg-intel.conf
Identifier "layout"
Screen "intel"
EndSection
Section "Device"
Identifier "intel"
Driver "modesetting"
BusID "PCI:0:2:0"
EndSection
Section "Screen"
Identifier "intel"
Device "intel"
EndSection
cat /etc/prime/xorg-nvidia.conf
Identifier "layout"
Screen 0 "nvidia" 0 0
Inactive "intel"
EndSection
Section "Device"
Identifier "intel"
Option "AccelMethod" "none"
BusID "PCI:0:2:0"
EndSection
Section "Device"
Identifier "nvidia"
Driver "nvidia"
BusID "PCI:1:0:0"
EndSection
Section "Screen"
Identifier "nvidia"
Device "nvidia"
EndSection
nvidia-xconfig -a
Using X configuration file: "/etc/X11/xorg.conf".
ERROR: Unable to determine number of GPUs in system; cannot honor '--enable-all-gpus' option.
Backed up file '/etc/X11/xorg.conf' as '/etc/X11/xorg.conf.backup'
New X configuration file written to '/etc/X11/xorg.conf'
nvidia-bug-report.sh
http://www.alunos.ipb.pt/~a37529/NVIDIA_BUGS/nvidia-bug-report.gz
nvidia-bug-report.sh --extra-system-data
http://www.alunos.ipb.pt/~a37529/NVIDIA_BUGS/nvidia-bug-report-extra-sys-data.gz
Thanks in advance
