Laptop information:
OMEN by HP Laptop PC - 17-w005np
Specs:
https://support.hp.com/us-en/product/omen-by-hp-17-w000-laptop-pc-series/10862328/model/12261509/document/c05201048
>uname -a
Linux linux-tp01 5.2.14-1-default #1 SMP Tue Sep 10 10:52:01 UTC 2019 (374b0ae) x86_64 x86_64 x86_64 GNU/Linux
SO I followed:
https://en.opensuse.org/SDB:NVIDIA_drivers
https://en.opensuse.org/SDB:NVIDIA_SUSE_Prime
NVIDIA Installed drivers:
https://i.imgur.com/njfBgzE.png
I used to have the G05 drivers but the same happened.
https://i.imgur.com/PXHaucI.png
# lspci | grep VGA
# lscpu | grep Arch
# hwinfo --gfxcard | grep Model
# hwinfo --arch
https://i.imgur.com/lwhNxIZ.png
# lspci | grep VGA
# lscpu | grep Arch
https://i.imgur.com/aklLo6W.png
#prime-select nvidia
#prime-select intel
https://i.imgur.com/OynAZRs.png
dmesg
cat /etc/X11/xorg.conf
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 390.129 (buildmeister@swio-display-x64-rhel04-14) Tue Jul 23 01:37:59 PDT 2019
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from data in "/etc/sysconfig/mouse"
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "IMPS/2"
Option "Device" "/dev/input/mice"
Option "Emulate3Buttons" "yes"
Option "ZAxisMapping" "4 5"
EndSection
# generated from default
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
HorizSync 28.0 - 33.0
VertRefresh 43.0 - 72.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
EndSubSection
EndSection
https://i.imgur.com/H6hNlhh.png
#nvidia-xconfig -a
https://i.imgur.com/sqJUyBZ.png
(#)nvidia-smi
https://i.imgur.com/zQD3dAR.png (Same error even doing what they say in the print…)
nvidia-settings
https://i.imgur.com/SwMn2tB.png
inxi -G
#hwinfo --gfxcard
17: PCI 100.0: 0302 3D controller
[Created at pci.386]
Unique ID: VCu0.C4vYvkQe035
Parent ID: vSkL.ssGVCrpcUlF
SysFS ID: /devices/pci0000:00/0000:00:01.0/0000:01:00.0
SysFS BusID: 0000:01:00.0
Hardware Class: graphics card
Device Name: "NVIDIA N16E-GR"
Model: "nVidia GM206M [GeForce GTX 965M]"
Vendor: pci 0x10de "nVidia Corporation"
Device: pci 0x1427 "GM206M [GeForce GTX 965M]"
SubVendor: pci 0x103c "Hewlett-Packard Company"
SubDevice: pci 0x825b
Revision: 0xa1
Driver: "nvidia"
Driver Modules: "nvidia"
Memory Range: 0xa3000000-0xa3ffffff (rw,non-prefetchable)
Memory Range: 0x90000000-0x9fffffff (ro,non-prefetchable)
Memory Range: 0xa0000000-0xa1ffffff (ro,non-prefetchable)
I/O Ports: 0x4000-0x4fff (rw)
Memory Range: 0xa4000000-0xa407ffff (ro,non-prefetchable,disabled)
IRQ: 16 (no events)
Module Alias: "pci:v000010DEd00001427sv0000103Csd0000825Bbc03sc02i00"
Driver Info #0:
Driver Status: nouveau is not active
Driver Activation Cmd: "modprobe nouveau"
Driver Info #1:
Driver Status: nvidia_drm is not active
Driver Activation Cmd: "modprobe nvidia_drm"
Driver Info #2:
Driver Status: nvidia is active
Driver Activation Cmd: "modprobe nvidia"
Config Status: cfg=no, avail=yes, need=no, active=unknown
Attached to: #12 (PCI bridge)
24: PCI 02.0: 0300 VGA compatible controller (VGA)
Unique ID: _Znp.eW0JZl5DxA3
SysFS ID: /devices/pci0000:00/0000:00:02.0
SysFS BusID: 0000:00:02.0
Device Name: "Intel Skylake HD Graphics ULT GT2"
Model: "Intel HD Graphics 530"
Vendor: pci 0x8086 "Intel Corporation"
Device: pci 0x191b "HD Graphics 530"
Revision: 0x06
Driver: "i915"
Driver Modules: "i915"
Memory Range: 0xa2000000-0xa2ffffff (rw,non-prefetchable)
Memory Range: 0xb0000000-0xbfffffff (ro,non-prefetchable)
I/O Ports: 0x5000-0x503f (rw)
Memory Range: 0x000c0000-0x000dffff (rw,non-prefetchable,disabled)
IRQ: 129 (81505 events)
Module Alias: "pci:v00008086d0000191Bsv0000103Csd0000825Bbc03sc00i00"
Driver Info #0:
Driver Status: i915 is active
Driver Activation Cmd: "modprobe i915"
Primary display adapter: #24
Let me know if you need more info. Thanks in advance.
