I am using Nvidia optical flow SDK 1.1 on Ubuntu 18.04, Cuda 10.2, GPU 1660Ti.
I am computing the optical flow between a sequence of frames.
Everything works well for a while until suddenly the program crashes.
I have tries to use the Nsight debugger, but this one crashes at the end of the first optical flow calculation.
I attach here first the errors I get when running from the command line, and then the Debugger errors.
The errors I get when running from the command line:
!!!Error signal 11:
/nmr/local/ver13/13.6/nmr/Release/lib/libnmrSystemCPU.so(+0xebdb)[0x7f68683f6bdb]
/lib/x86_64-linux-gnu/libc.so.6(+0x3efd0)[0x7f6866476fd0]
/usr/lib/x86_64-linux-gnu/libcuda.so.1(+0x217d25)[0x7f685f127d25]
/usr/lib/x86_64-linux-gnu/libcuda.so.1(+0xf758a)[0x7f685f00758a]
/usr/lib/x86_64-linux-gnu/libcuda.so.1(cuCtxPopCurrent_v2+0x59)[0x7f685f17b029]
/usr/lib/x86_64-linux-gnu/libnvcuvid.so.1(+0x71fe4)[0x7f67ed749fe4]
/usr/lib/x86_64-linux-gnu/libnvcuvid.so.1(+0xee234)[0x7f67ed7c6234]
/usr/lib/x86_64-linux-gnu/libnvidia-opticalflow.so.1(+0x3bc5)[0x7f67edbf3bc5]
/nmr/local/ver13/13.6/nmr/Release/lib/libnmrOflCPU.so(_ZN19NvOFBufferCudaArrayD1Ev+0x4a)[0x7f6868f66c9a]
/nmr/local/ver13/13.6/nmr/Release/lib/libnmrOflCPU.so(_ZN19NvOFBufferCudaArrayD0Ev+0x9)[0x7f6868f66d29]
Nsight Debugger messages:
Coalescing of the CUDA commands output is off.
$1 = 0xff
The target endianness is set automatically (currently little endian)
No source file named nmrDbgCuda.cc.
No source file named nmrOflCuda.cc.
No source file named NvOFNmr.cc.
No source file named cmnPBitRaisePredict.cc.
[Thread debugging using libthread_db enabled]
Using host libthread_db library “/lib/x86_64-linux-gnu/libthread_db.so.1”.
[New Thread 0x7fffa8e4b700 (LWP 11259)]
[New Thread 0x7fffa864a700 (LWP 11260)]
[New Thread 0x7fffa3e49700 (LWP 11261)]
[New Thread 0x7fffa1648700 (LWP 11262)]
[New Thread 0x7fffa0e47700 (LWP 11263)]
[New Thread 0x7fff9e646700 (LWP 11264)]
[New Thread 0x7fff9be45700 (LWP 11265)]
Thread 1 “nmrEncP” hit Temporary breakpoint 16, main (argc=48, argv=0x7fffffffd738) at /nmr/svn/ver13/13.6/nmr/nmrEncP/modules/utils/nmrEncP.cc:7
7 {
[New Thread 0x7fff9161a700 (LWP 11272)]
[New Thread 0x7fff90e19700 (LWP 11273)]
[New Thread 0x7fff75fff700 (LWP 11274)]
Thread 1 “nmrEncP” hit Breakpoint 13, NMR_NS::CmnPBit::commonRaiseLevelPredictTimeInit (this=0x7fffffffc8c0, bufChl=…, wavLev=…, bufLev=…, wavChl=…, kL=0, isSim=false) at /nmr/svn/ver13/13.6/nmr/nmrCmnP/modules/cmnPBit/cpu/cmnPBitRaisePredict.cc:75
75 if (oflFlag==OFL_METHOD_NVIDIA_CUDA)
Thread 1 “nmrEncP” hit Breakpoint 15, calcFlow (nF=17, inpMovFrames=0x7fffffffba70, floUFrames=0x7fffffffb8e0, floVFrames=0x7fffffffb750, gpuId=0, fwdFlag=true) at /nmr/svn/ver13/13.6/nmr/nmrOfl/modules/oflCuda/cpu/NvOFNmr.cc:60
60 MatNmrCpu<uint8_t> movFrames[nF];
Thread 1 “nmrEncP” hit Breakpoint 11, calcFlow (nF=17, inpMovFrames=0x7fffffffba70, floUFrames=0x7fffffffb8e0, floVFrames=0x7fffffffb750, gpuId=0, fwdFlag=true) at /nmr/svn/ver13/13.6/nmr/nmrOfl/modules/oflCuda/cpu/NvOFNmr.cc:65
65 nC = movFrames[0].getNCols();
Thread 1 “nmrEncP” hit Breakpoint 8, calcFlow (nF=17, inpMovFrames=0x7fffffffba70, floUFrames=0x7fffffffb8e0, floVFrames=0x7fffffffb750, gpuId=0, fwdFlag=true) at /nmr/svn/ver13/13.6/nmr/nmrOfl/modules/oflCuda/cpu/NvOFNmr.cc:85
85 calcFlow(movFrames, movUVFlows,
[New Thread 0x7fff757fe700 (LWP 11291)]
[New Thread 0x7fff74ffd700 (LWP 11293)]
[Thread 0x7fff74ffd700 (LWP 11293) exited]
[Thread 0x7fff757fe700 (LWP 11291) exited]
warning: Cuda API error detected: cuArrayDestroy returned (0x2c5)
Error: Internal error reported by CUDA debugger API (error=CUDBG_ERROR_INVALID_CONTEXT(0x1d)). The application cannot be further debugged.
