ORIN AGX on Xavier AGX EVB
Can I assamble the ORIN AGX on the Xavier AGX EVB and vica versa?
I want to operate the 1G ETH on the ORIN AGX but I can’t check it on the ORIN EVB, cause it don’t have 1G ETH phy.
This is not fully compatible. Suggest to use AGX Orin devkit.
I know that it’s not fully compatible.
I want to check only the 1G Ethernet.
As you know, the ORIN AGX devkit don’t have the a 1G Ethernet on board.
Is it possible to use the Orin AGX on the Xavier AGX devkit for this test?
I can’t comment as we didn’t do the verification.
