ORIN cann't use XFI (fixed-link mode)
Hi nv team,We need to use the XFI interface on our custom carrier board ,and the XFI connected FPGA XFI without phy。 So,I programed the nvethernet DT ,but it‘s not work!
ODMDATA="gbe-uphy-config-22,hsstp-lane-map-3,nvhs-uphy-config-0,hsio-uphy-config-0,gbe0-enable-10g";
My dtb is configured as following:
#include <dt-bindings/gpio/tegra234-gpio.h>
	/* MGBE - A */
	ethernet@6810000 {
		status = "okay";
		nvidia,mac-addr-idx = <0>;
		nvidia,max-platform-mtu = <16383>;
		/* 0=enable, 1=disable */
		nvidia,pause_frames = <0>;
		//phy-handle = <&mgbe0_aqr113c_phy>;
		phy-mode = "10gbase-r";
                nvidia,uphy-gbe-mode = <1> ;
		/* 0:XFI 10G, 1:XFI 5G, 2:USXGMII 10G, 3:USXGMII 5G */
		nvidia,phy-iface-mode = <0>;
		/*add by zhenghang*/
		fixed-link {
         		speed=<10000>;
	       		full-duplex;
When start up, print the following error message:
[ 54.961203] [xpcs_lane_bring_up][416][type:0x4][loga-0x0] Failed to get PCS block lock
[   54.961436] [xpcs_init][451][type:0x4][loga-0x0] TX/RX lane bring-up failed
[   54.961629] [mgbe_set_speed][4220][type:0x4][loga-0x0] xpcs_init failed
[   57.009009] [xpcs_lane_bring_up][416][type:0x4][loga-0x0] Failed to get PCS block lock
[   57.009255] [xpcs_init][451][type:0x4][loga-0x0] TX/RX lane bring-up failed
[   57.009454] [mgbe_set_speed][4220][type:0x4][loga-0x0] xpcs_init failed
[   59.057201] [xpcs_lane_bring_up][416][type:0x4][loga-0x0] Failed to get PCS block lock
[   59.057434] [xpcs_init][451][type:0x4][loga-0x0] TX/RX lane bring-up failed
[   59.057630] [mgbe_set_speed][4220][type:0x4][loga-0x0] xpcs_init failed
[   61.105203] [xpcs_lane_bring_up][416][type:0x4][loga-0x0] Failed to get PCS block lock
[   61.105442] [xpcs_init][451][type:0x4][loga-0x0] TX/RX lane bring-up failed
[   61.105640] [mgbe_set_speed][4220][type:0x4][loga-0x0] xpcs_init failed
[   63.152679] [xpcs_lane_bring_up][416][type:0x4][loga-0x0] Failed to get PCS block lock
[   63.152913] [xpcs_init][451][type:0x4][loga-0x0] TX/RX lane bring-up failed
Can you help me analyze this problem?
THANKS!
Sorry for the late response, our team will do the investigation and provide suggestions soon. Thanks
Please be sure to use NVbugs to support your project.
Topic closed.
