Orin Industrial Questions
I have the following questions regarding the Jetson AGX Orin Industrial device.
  • Can you share the Bill of Materials?
  • Are the storage and operation temperature limits the same? We were expecting the storage limits to be wider than the operational limits.
  • Can you share with us the testing setup used to perform vibration testing?
    • Do you have any vibration data for frequencies higher than 1000 Hz or at higher Grms levels?
    • What parts were identified as the weakest link during vibration testing?
  • Regarding the TOPS vs the TTP Temp, it appears that the industrial thermal resistance values (𝜃) in the thermal design guide still list “TBD”. Have these values been determined?
  • Do you have any data regarding decompression for the industrial version?
  • Do you have any data regarding fungus resistance for the industrial version?
  • Under what conditions was the operating life value calculated? Will different use cases shorten or extend its operating life?
Hi, the docs we can share are all in the DLC, please check there.
Hello Trumany,
I have read through many of the documents in the DLC. It is possible I have missed some relevant information, however, these questions regard topics I could not find information on. Is there any way you can help me track down answers to this questions?
You can find the carrier BOM, module data sheet, thermal design guide and etc. in DLC. We don’t share other docs than that.
