Using the sample frame grabber program provided with Driveworks on the Orin 6.0.6 platform, when running with 6 IMX728 cameras with ISP enabled with, I observed significant frame dropping.
I set the cameras to run at 30fps, 3840x2160 resolution, camera:V1SIM728S2RU4120HB20, and observed that ~60% of the captured frames were dropped @ ISP time.
I would like to to understand:
- Is the Orin platform expected to be able to run these 6 cameras at this framerate + resolution without dropping frames? Is there some inefficiency in the sample code or is this a fundamental HW limitation?
- Is there a way to reduce the frame rate for this camera down to 10Hz as a part of the sample driver code, or the driveworks api
I know the max ISP throughput of the Orin-X is 1.85 gigapixels per second, which should handle 30fps, 3840x2160 x6 cameras by that metric. Is there some inefficiency with the sample Driveworks camera application, or some other issue?
Statistics results for 6 cameras, 30fps, 8MPx:
[18-06-2024 20:19:53] Statistics for DW_SENSOR_STATE_DELTA_HOST_AND_HOST_TIME
Events: 375
Errors: 1
Drops: 249
minDelta: 33332.0000 us
maxDelta: 200023.0000 us
meanDelta: 77297.3750us
Standard deviation: 20531.7754
Software Version
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.3.10904
other
Host Machine Version
other
