Change video fps=30->10 not working
Software Version
DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
[*] DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[*] Linux
QNX
other
Hardware Platform
[*] DRIVE AGX Orin Developer Kit (not sure its number)
other
SDK Manager Version
2.1.0
other
Host Machine Version
[*] native Ubuntu Linux 20.04 Host installed with DRIVE OS Docker Containers
other
Issue Description
I am connecting a SONY IMX728 sensor to DRIVE AGX Orin.
I want to change recoreded RAW from 30fps to 10fps.
I make 2 change point, both has issue
Issue.1 set framerate=30->10 in sensor rig file, but sensor still recoding in 30fps
Issue.2 set framerate=30->10 in serializer, but serializer still compose raw file in 30fps
Error String
Logs
---- Issue.1 create sensor using rig file log ----
[28-10-2024 14:27:33] SensorFactory::createSensor() → camera.gmsl, camera-name=IMX728_RGGB,interface=csi-ab,CPHY-mode=1,link=1,output-format=raw+yuv,format=raw,isp-mode=yuv420-uint8,nito-file=/usr/share/camera/IMX728_RGGB_FoV120.nito,async-record=1,framerate=10,file-buffer-size=16777216
---- Issue.1 dwSAL_start(m_sal) output log ----
[28-10-2024 14:27:33] Platform:
[28-10-2024 14:27:33] Platform Config:
[28-10-2024 14:27:33] Description:
[28-10-2024 14:27:33] Number of device blocks: 1
[28-10-2024 14:27:33] Device Block : 0
[28-10-2024 14:27:33] csiPort: 2
[28-10-2024 14:27:33] i2cDevice: 0
[28-10-2024 14:27:33] Deserializer Name: MAX96712
[28-10-2024 14:27:33] Deserializer Description: Maxim 96712 Aggregator
[28-10-2024 14:27:33] Deserializer i2cAddress: 41
[28-10-2024 14:27:33] Simulator Mode: 0
[28-10-2024 14:27:33] Passive Mode: 0
[28-10-2024 14:27:33] Phy Mode: 1
[28-10-2024 14:27:33] Number of camera modules: 2
[28-10-2024 14:27:33] CameraModule index: 0
[28-10-2024 14:27:33] Name :IMX728_RGGB
[28-10-2024 14:27:33] Description: Sony IMX728 RGGB module - MIPI-IMX728, MAX96717
[28-10-2024 14:27:33] Serializer name: MAX96717F
[28-10-2024 14:27:33] Serializer description: Maxim 96717F Serializer
[28-10-2024 14:27:33] Serializer i2cAdress: 66
[28-10-2024 14:27:33] EEPROM name: M24C64
[28-10-2024 14:27:33] EEPROM i2cAddress: 84
[28-10-2024 14:27:33] EEPROM description: M24C64 64-Kbit serial I2C EEPROM
[28-10-2024 14:27:33] Sensor ID: 0
[28-10-2024 14:27:33] Sensor name: IMX728
[28-10-2024 14:27:33] Sensor description: Sony IMX728 Sensor
[28-10-2024 14:27:33] Sensor i2cAddress: 26
[28-10-2024 14:27:33] Sensor isTPGEnabled: 0
[28-10-2024 14:27:33] Sensor isTriggerMode: 1
[28-10-2024 14:27:33] cfa: 33
[28-10-2024 14:27:33] embeddedTopLines: 1
[28-10-2024 14:27:33] embeddedBottomLines: 20
[28-10-2024 14:27:33] inputFormat: 8
[28-10-2024 14:27:33] height: 2160
[28-10-2024 14:27:33] width: 3840
[28-10-2024 14:27:33] fps: 30.000000
[28-10-2024 14:27:33] Embedded Data: 0
---- Issue.2 CHECK_DW_ERROR(dwSensorSerializer_initialize) output log ----
[28-10-2024 14:27:35] CameraClient: camera params: format=raw,type=disk,file=/media/ams/EXT4/temp/20241028_fps_check_test/raw/app_10fps_rig_10fps/10sec/20241028142732-cam00.raw,framerate=10,bitrate=8000000
Dear @maxwell.aj ,
Could you check using frame-mod parameter .
Please see the recording parameters details at DriveWorks SDK Reference: Configuration Reference
Hi Siva
Thank you for quick reply. I will try it some time later and come back to you.
BR
