New Camera Frame Serializer seems to fail
Software Version
DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
2.1.0
other
Host Machine Version
other
Issue Description
We are exploring the async-record capabilities of the new Sensor Serializer. When I try to run the sample code with the following rig file, it never seems to work. This is the command that I ran:
./sample_camera --rig=rig_test.json --write-file=output.mp4 --offscreen=2
I tried with output.h264 and output.h265, but the error message says that the new codec only support mp4. Then, I started changing the parameters in the rig file. The only thing I know how to change is the “output-format” field. I will put output-format → error string in the next section. We have V1SIM728S1RU3120NB20 cameras. Does this mean that the new codec doesn’t support our cameras? Thanks!
rig.txt (1.4 KB)
Error String
output-format=raw:
[21-09-2024 21:09:59] Driveworks exception thrown: DW_INVALID_ARGUMENT: Support H264/H265 and LRAW encoder only
output-format=processed
[21-09-2024 21:10:30] Driveworks exception thrown: DW_INVALID_ARGUMENT: Support H264/H265 and LRAW encoder only
output-format=processed1
[21-09-2024 21:11:22] Driveworks exception thrown: DW_NOT_SUPPORTED: CameraClient: ISP0 and ISP1 Image Properties are same, not supported, set different attributes
output-format=processed2
[21-09-2024 21:12:00] Driveworks exception thrown: DW_INVALID_ARGUMENT: Support H264/H265 and LRAW encoder only
Dear @extern.ray.xie,
I tested with V1SIM728S1RU3070HB20 module on DRIVE OS 6.0.8.1 release and don’t see any issue when generating mp4/h264/h265 with sample_camera with newcodec
onInitialize: creating camera.gmsl with params: camera-name=V1SIM728S1RU3070HB20,interface=csi-ab,CPHY-mode=1,newcodecstack=1,link=0,output-format=processed,async-record=1,file-buffer-size=16777216
[30-09-2024 05:21:16] SensorFactory::createSensor() -> camera.gmsl, camera-name=V1SIM728S1RU3070HB20,interface=csi-ab,CPHY-mode=1,newcodecstack=1,link=0,output-format=processed,async-record=1,file-buffer-size=16777216
[30-09-2024 05:21:16] Found driver: camera.gmsl
It could be the issue specific to this camera module. Could you test with other cameras(if you have any) and update us.
Also, please set export DW_SIPL_NVMEDIA_VERBOSITY=4 and get sample_camera logs and syslog and dmesg logs
Hi Siva,
Thank you for your reply. Here are the logs you have requested for running the command:
./sample_camera --rig=rig_test.json --write-file=/home/nvidia/output.mp4 --offscreen=2
We don’t have any other camera modules that can run on 6.0.8 right now.
dmesg_log.txt (95.5 KB)
sample_camera_logs.txt (976.2 KB)
syslog.txt (5.3 MB)
Hello Siva,
I am trying to run Nvidia sample camera application(provided by Nvidia in the docker container) on Nvidia spc device. I am using GMSL camera.
Command:
./sample_camera --rig=rig.json --write-file=output.mp4 --offscreen=2
But I am unable to run this successfully, as Camera creation is failing. Could you please check the attached log and rig.json file and let me know any corrections are required in rig.json file.
rig.txt (1.1 KB)
Nvidia-camera-sample-output.txt (9.4 KB)
Dear @a.ratnakaram ,
Please file a new topic for your issue.
Hello Siva,
I have created a new topic for this issue, please check here:
How to run Nvidia sample camera application to capture an image from GMSL Camera - DRIVE AGX Orin / DRIVE AGX Orin General - NVIDIA Developer Forums
Dear @extern.ray.xie ,
This log does not have any error indication as in description. Can you quickly test the issue on DRIVE OS 6.0.10 if it is issue related to this camera and fixed/reproduced in DRIVE OS 6.0.10.
Hi Siva,
Sorry for not replying to this issue in a while. We are currently working on a different issue and will get back to you once we get back on this.
