Hi, all:
we are debuging our custom board. In our costom board, the MGBE port is directly connnct to our switch 88q6113, just show as below.
on hareware we set the the port as 10GBASE-R
on software, I follow the instruction below
modify the MGBE dt as below
/* MGBE - A */
ethernet@6810000 {
status = "okay";
nvidia,mac-addr-idx = <1>;
/* 0=enable, 1=disable */
nvidia,pause_frames = <0>;
phy-mode = "10gbase-r";
/* 1:10G, 0:5G */
nvidia,uphy-gbe-mode = <1>;
/* 0:XFI 10G, 1:XFI 5G, 2:USXGMII 10G, 3:USXGMII 5G */
nvidia,phy-iface-mode = <0>;
nvidia,max-platform-mtu = <16383>;
fixed-link {
speed = <10000>;
full-duplex;
when the system setup, I get dmesg as below.
nvidia@tegra-ubuntu:~$ sudo dmesg | grep 681
[ 6.681009] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 12.243876] nvethernet 6810000.ethernet: Adding to iommu group 52
[ 12.250446] nvethernet 6810000.ethernet: failed to read skip mac reset flag, default 0
[ 12.258632] nvethernet 6810000.ethernet: failed to read MDIO address
[ 12.265211] nvethernet 6810000.ethernet: setting to default DMA bit mask
[ 12.272905] nvethernet 6810000.ethernet: failed to get phy reset gpio error: -2
[ 12.285153] nvethernet 6810000.ethernet: Ethernet MAC address: 48:b0:2d:78:9b:b1
[ 12.293099] nvethernet 6810000.ethernet: Macsec not enabled
[ 12.298848] nvethernet 6810000.ethernet: Macsec: Reduced MTU: 1466 Max: 16383
[ 12.308199] nvethernet 6810000.ethernet: eth1 (HW ver: 31) created with 10 DMA channels
here the detail dmesg
eth_dmesg.log (69.6 KB)
now the question is on the orin side
ethtool eth1
show the Link detected: no
so any suggestion about this issue, thx
