下图是Orin针对MGBE的参考设计电路:
希望请教一下,这个外部晶振的具体作用是什么?
没有上述晶振,对于MGBE的功能配置的影响是什么?
期待您的及时回复!
期待您的及时回复!
It provides the clock to Orin. It is necessary for the design.
| Multi-Gigabit Ethernet on AGX Orin | 2 | 1087 | October 10, 2025 | |
| What if we are mssing 156.25MHz clocking in orin carrier (not using MGBE)? | 10 | 402 | March 17, 2025 | |
| MGBE REFCLK oscillator suggestion - AGX ORIN SOM | 10 | 549 | November 8, 2025 | |
| Jetson Orin missing MGBE 156.25MHz reference clock and mitigation solution | 4 | 305 | May 23, 2025 | |
| MGBE - missing 156.25 MHz Reference Clock | 2 | 561 | September 7, 2023 | |
| MGBE PRBS testing | 2 | 333 | May 6, 2024 | |
| Is there a internal switch within MGBEs of Jetson Orin | 2 | 828 | December 16, 2022 | |
| MGBE (10G) AQR113C can not work on my custom carrier board | 1 | 603 | April 11, 2024 | |
| AQR113C 10G Ethernet PHY of AGX Orin devkit -clock oscillator | 1 | 293 | October 29, 2025 | |
| MGBM two Orin | 3 | 678 | January 4, 2023 |
