AQR113C 10G Ethernet PHY of AGX Orin devkit -clock oscillator
Hi Team,
we are using 10G ethernet PHY(AQR113C) with external magnetics and connector in our AGX Orin based carrier board, we need to know any recommended part number for the 156.25MHZ MGBE clock oscillator,
we have checked the BOM files of the AGX Orin Devkit there is no part number given for the 156.25MHZ only the DHA560003 is provided in both BOM and SCH. this DHA is not available in any online it does not seem to be oscillator part?
we have selected oscillator HCSL type MPN-AK3BHDF1-156.2500T which can match the requirement of 156.25MHZ given in the Orin design guide, can you confirm whether we can use the clock oscillator?
Meantime we need to know the flashing procedure of the AQR113C’s SPI flash memory externally used? is there any firmware or driver available to configure the SPI flash of the AQR113c for the first to boot? we are using AGX Orin SOM with AQR113C with same connections as per the Devkit schematics with 10G magnetics and connector, we need to know how to flash the AQR113C IC for the first time & what is the sequence to configure
Please refer to MGBE REFCLK oscillator suggestion - AGX ORIN SOM - #13 by sgursal
