AQR113C 10GbE PHY Program Binary File Support for AGX Orin
Hello Team,
We are in the process of planning to use the AQR113C 10GbE PHY for our custom board, which is already present in the AGX Orin EVK. We would like to inquire about the availability of the 10G PHY firmware or source file and whether you provide support for it. Your assistance in this matter would be highly appreciated.
Regards,
Parashuram
This is a 3rdparty component and please contact the vendor to get support.
Hello Dane,
Thank you for responding. We are a bit confusion about the firmware requirement for AQR113C-B1-C. According to the datasheet, we are unsure if firmware is needed. Could you kindly clarify whether programming is necessary? Alternatively, can we follow the EVK schematic and default Jetpack, expecting it to function similarly to the EVK without additional programming? Your guidance on this matter would be greatly appreciated.
Regards,
Parashuram
Hello Dane,
We are awaiting your reply. Any guidance you can provide would be greatly appreciated.
Regards,
Parashuram
For designing your board, please refer to our product design guide. The component is from 3rdparty and for more information, please contact the vendor for help.
Thank you for your guidance.
We will refer to the design guide for the AQR113C. Could you please clarify if firmware programming is required for the AQR113C PHY, or does it work with the default Jetpack configuration? We aim to replicate the design and expect the 10G functionality to match the EVK. Your clarification on the firmware requirement would be greatly appreciated.
Regards,
Parashuram
I’m looking for your guidance on whether firmware is required for the AQR113C-B1-i 10G PHY. We are planning to incorporate it into our design, and since it has been utilized in the AGX Orin EVK design, we are hopeful for a straightforward integration. Your support and clarification on this matter would be highly appreciated. Thank you.
Regards,
Parashuram
Please contact with the PHY vendor for The firmware.
Thanks for you’re reply.
