I have a Jetson Orin Nano dev kit (SKU 0005) which I damaged one of the 4GB RAM chip. After remove it I am trying to use it as the 4GB model instead of discard it. Would it be that possible?
I have tried flashing with SDK Manager overriding SKU to 0004 but it fails to boot.
I am debugging via UART and I’m encountering a consistent SDRAM initialization failure very early in boot.
Context
Module: Jetson Orin Nano 8GB (production unit)
Fuse info from UART:
FUSE_SKU_INFO_0 = 0xd5
SKU: Prod
Boot device: QSPI (stock devkit)
Debug via UART (115200 8N1)
Issue
The module has a hardware defect (one DRAM chip have been removed and pads damage so it can not be restored ).
Because of this, I am trying to see if it is possible to use it as a reduced-memory (4GB-like) configuration.
nano.log (30.7 KB)
However, boot fails very early in MB1:
I> Task: SDRAM init
I> MemoryType: 4 MemBctRevision: 1
I> MSS CAR: Init PLLM
I> MSS CAR: Init PLLHUB
I> Encryption: MTS: en, TX: en, VPR: en, GSC: en
E> MSS: Failed to initialize SDRAM.
C> Task 0x2f failed (err: 0x48480112)
E> Top caller module: MSS, error module: MSS, reason: 0x12
The board then resets and repeats the same failure.
What I understand so far
SDRAM init is performed by MB1 using MEM-BCT
The configuration appears tightly coupled to:
SKU (fuses)
DRAM topology
The current MEM-BCT expects full 8GB layout and fails training
My question
Is there any supported or experimental way to make this module usable as a 4GB configuration?
Specifically:
SKU / Fuse override
Is it possible to override or ignore FUSE_SKU_INFO_0 during boot?
Or force a different SKU selection in the boot chain?
Or writing a new value will solve it?
MEM-BCT / SDRAM config
- Can I generate or modify a MEM-BCT for a reduced DRAM topology (e.g., half population)?
L4T / flashing side
Can flash.sh or board config be forced to use a 4GB Orin Nano profile even if the module is fused as 8GB?
Would this realistically work, or will MB1 still fail before that matters?
Any workaround
Is there any way to bypass or partially initialize memory to allow boot (even with reduced capacity)?
Or is this fundamentally impossible due to MB1/firmware constraints?
Goal
If possible, I’d like to reuse the module as a reduced-capacity device instead of discarding it.
Any guidance from NVIDIA or others who have worked with MB1/MEM-BCT would be very appreciated.
