hello etimmons,
fuse should be complete, it’s reporting… Successfully burnt fuses as per fuse info
since you’ve program the fuse, you have to re-flash the target by assign those keys.
you may see-also Topic 263458, we’ve check and confirm fuse burning, and image flashing on Orin NX with a success.
furthermore, please setup a serial console as well to gather the UART logs.
