I’m busy with a system design with the Orin NX and I’ve 2 questions about the VDD_IN.
Can you connect a battery output directly to the VDD_IN pins by means of using a load switch, filtering and buffering in between the battery and Orin NX? The load switch, filtering and buffering will make sure the power rail is stable. Of course the voltage will slowly drop over time. The battery has a voltage of 10V8-16V8.
Related to question 1, What is the efficiency of the Orin NX (PMIC) over the range of 5V-20V input? Can you share data of VDD_IN voltage vs efficiency like a graph for example?
