Based on the provided context, I will attempt to answer your question about the Jetson Orin NX, Jetpack 6.0, GPIO, and NVIDIA.
The Jetson Orin NX is a system on module (SOM) developed by NVIDIA, which is part of the Jetson Orin series. It is designed for edge AI applications and comes with a range of features, including support for GPIO (General Purpose Input/Output) pins.
GPIO pins are used to connect external devices to the Jetson module, such as sensors, actuators, and other peripherals. The Jetson Orin NX has a total of 40 GPIO pins, which can be configured as inputs or outputs.
To access and control the GPIO pins on the Jetson Orin NX, you can use the gpioset and gpioget commands, which are part of the Jetson Linux distribution. These commands allow you to set and get the values of individual GPIO pins.
In your question, you mentioned the following GPIO pins:
These pins are part of the GPIO bank on the Jetson Orin NX, and can be accessed using the gpioset and gpioget commands.
For example, to set the value of PI00 to high, you can use the following command:
gpioset gpiochip0 510=1
Similarly, to get the value of PI01, you can use the following command:
gpioget gpiochip0 511
The gpiochip0 refers to the GPIO bank on the Jetson Orin NX, and the numbers 510 and 511 refer to the specific GPIO pins.
In addition to the gpioset and gpioget commands, you can also use the devmem command to access the GPIO pins directly. This command allows you to read and write to the GPIO registers on the Jetson Orin NX.
For example, to set the value of PI00 to high using the devmem command, you can use the following command:
devmem 0x024340000 32 0x00000001
This command writes the value 0x00000001 to the GPIO register at address 0x024340000, which sets the value of PI00 to high.
Overall, the Jetson Orin NX provides a range of features and tools for accessing and controlling GPIO pins, including the gpioset and gpioget commands, as well as the devmem command.
In comparison to other Jetson modules, such as the Jetson Orin Nano and the Jetson AGX Orin, the Jetson Orin NX has a similar GPIO architecture and can be accessed using the same commands and tools.
However, the specific GPIO pins and their functions may vary between different Jetson modules, so it’s always a good idea to consult the documentation for your specific module to ensure that you are using the correct GPIO pins and commands.
I hope this helps! Let me know if you have any further questions.
