Board was booting over PXE until I wanted to run some tests that required default booting. I changed the boot order and rebooted, and noticed it continues to boot over PXE, but times out and falls back to the default boot. I also noticed that the IP needs to be manually set, which is making me think that the board is not able to get the IP address while trying to boot over PXE. How do I troubleshoot this?
Hi heartsystem,
Is your issue about it could not boot from internal eMMC directly after you configure the boot-order in UEFI menu?
