Orin nx occasional boot failure
we are using our self-developed carrier board with an ORIN NX 16G SOM. L4T:35.4.1,JETPACK:5.1.2,my Jetson Orin NX device occasionally fails to boot. This happens after it has been powered off for a while. It will start successfully when I power it on, but then it fails to restart. Here is the boot log from a failed startup. Can you explain what might be causing this issue?
Thank you for your help!
sessionxiaohy07(启动失败).log (125.9 KB)
Please flash with the latest bsp version like 5.1.5 to check whether the issue exists.
