xlucny
August 15, 2023, 2:13pm
1
According to Orin NX datasheet, all pcie ports are Gen4 capable. On a custom carrier board, I have a Gen4 (x1) ethernet module connected to pcie controller 1. However it is only running at link speed of 8GT/s.
Lspci hows the following for the controller:
0001:00:00.0 PCI bridge: NVIDIA Corporation Device 229e (rev a1) (prog-if 00 [Normal decode])
LnkCap: Port #0 , Speed 8GT/s, Width x1, ASPM not supported
LnkSta: Speed 8GT/s (ok), Width x1 (ok)
The ethernet module:
0001:01:00.0 Ethernet controller: Aquantia Corp. Device 94c0 (rev 03)
LnkCap: Port #0 , Speed 16GT/s, Width x2, ASPM not supported
LnkSta: Speed 8GT/s (downgraded), Width x1 (downgraded)
How would I “convince” the controller to allow Gen4 link speeds?
full lspci output (9.6 KB)
kayccc
August 16, 2023, 12:31am
3
Which JetPack you’re using? Could you try with JetPack 5.1.2?
Please use Jetpack 5.1.2 and try this setup:
Orin Unable to Reach 10 Gbps Networking - #3 by DaneLLL
See if you can achieve target throughput on the custom board.
xlucny
August 16, 2023, 8:31am
6
Okay, the nearest day I can get around to test this is on friday, so I’ll let you know then.
xlucny
August 18, 2023, 3:17pm
7
That solved the issue! Thanks.
LnkCap: Port #0 , Speed 16 GT/s, Width x1, ASPM not supported
LnkSta: Speed 16 GT/s (ok), Width x1 (ok)
LnkSta: Speed 16 GT/s (ok), Width x1 (downgraded)
system
Closed
September 11, 2023, 7:59am
9
