Unfortunately auto IP assignment does not work. But when I set eth1 speed to 100mb I was able to connect to the board. And as I said before, module TX2 NX works corerct with eth1 on 1000mb. Is there any limits on usb for Orin NX ?
I use following usb2 pins for eth1:
123 USB2_D_P USB2_D_P
121 USB2_D_N USB2_D_N
I don’t have original nvidia carrier board but I can provide any additional information you need to help find solution
It is actually not something that you can compare between a TX2 NX and Orin NX. Their kernel version is totally different.
Also, if you can detect this device, then it has nothing to do with USB setting. Which usb pins you are using are totally not related to current issue.
There is nothing I can help unless you reproduce same issue on NV devkit. I would say try other kind of card or try to use DHCP to test more cases to isolate the real case that would trigger this problem.
