我使用ORIN NX 8G + 128G的SSD,定制的载板,在之前我使用sudo ./tools/backup_restore/l4t_backup_restore.sh -b jetson-orin-nano-devkit命令备份了一份镜像,然后更换载板SSD和ORIN NX,使用sudo ./tools/backup_restore/l4t_backup_restore.sh -r jetson-orin-nano-devkit进行恢复,有两个核心板,一个可以成功,另一个显示失败,失败内容如下,请问是什么原因呢
Hi tiancai1234,
For the custom carrier board, are you using the custom BSP package?
Or do you have custom board config?
It seems you have to specify -e nvme0n1
in both commands for NVMe SSD.
Please try the following commands instead.
Backup:
$ sudo ./tools/backup_restore/l4t_backup_restore.sh -b -e nvme0n1 jetson-orin-nano-devkit
Restore:
$ sudo ./tools/backup_restore/l4t_backup_restore.sh -r -e nvme0n1 jetson-orin-nano-devkit
Please share the result of cat /etc/nv_tegra_release
for further check.
版本是35.3.1
Could you verify with the latest R35.6.0?
Or just copy the backup/restore tool from R35.6.0.
