Orin nx8g flash
Are you sure 60620800 is correct?
We’d really suggest just try with a 64GB or larger drive.
Did you run the flashing command manually or through SDK Manager?
manually
Then please just try with 64GB or larger as we do not verify with 32GB drives.
OK,thinks
flash_1-4.4.4.1_0_20230810-161612.log (7.7 KB)
Changed 64 gigabytes of storage, still failed
Then what if with SDK Manager?
Also a failure
What do you got from serial console?
With the same error?
Share the log here.
flash_1-4.4.4.1_0_20230810-163721.log (7.8 KB)
Then how about serial console?
SDKM_logs_2023-08-10_16-52-32.zip (1.0 MB)
SDKM_logs_JetPack_5.1.2_Linux_for_Jetson_Orin_NX_modules_2023-08-10_16-31-05.zip (229.6 KB)
No, by saying serial console, I mean this:
Also, have you tried pre-formatting the USB drive into a single ext4 partition?
20230810171347-Log.txt (105.1 KB)
Do you have other storage devices for test?
Like an NVMe Drive or an SD card.
I’m currently using an SD card, which is plugged into a USB card reader
