Orin super jetpack 6.2 booting failed
Hello, this is Jetson Mom.
After burning the jetpack 6.2 image to the Orin Nano Super, I put the SD card into the Orin, but it doesn’t boot. Connect your monitor and USB keyboard to your developer kit at Jetson Orin Nano Developer Kit Getting Started Guide | NVIDIA Developer.
“Turn on the developer kit by plugging in the bundled DC power supply
Repeatedly press Esc key on the keyboard, especially after NVIDIA logo boot splash screen first appears on the monitor
You should see UEFI setup menu screen
Check the third line from the top (below “Not specified”), which should be the version number of Jetson UEFI firmware”
Below image shows that this Jetson Orin Nano Developer Kit unit has the old UEFI firmware, indicating that the unit first needs its firmware/QSPI updated in order to run JetPack 6.x. I did that, but I selected the image at the end and it doesn’t reboot. The order I did is organized at 젯슨맘 : 네이버 블로그.
Do you check your UEFI version is > 36.0 or older version?
Please follow the Overall flow (microSD-only method) section in doc.
When your UEFI version is older version, you need to install JP 5.1.3 image and update the firmware manually.
Thank you. It was solved with sdkmanager. The device was not recognized because the c type cable was defective. I solved it successfully by making a Ubuntu 22.04 laptop.
