OrinNX flashing error with Minimal/Basic Filesystem Image
I’ve tried building the minimal and the basic OS images using the guide. Option: Minimal L4T - Guide to Minimizing Jetson Disk Usage
I successfully go through all the steps, and flash the my Orin NX board, but it fails to boot. It exits with message “Efi stub: exiting boot services and installing virtual address map…”
I do however, succeed in the flashing process when using the provided “Sample root filesystem”. So there must be a problem in the build process of the filesystem image. Currently testing this with Jetpack 5.1.3
Put both booting log from serial console and flashing log here.
