Hi all,
I have a MacBook Pro running OS X 10.10.2 and an NVIDIA GeForce GT 750M 2048 MB with CUDA 7.0.
I’m currently having difficulties debugging my CUDA program. I set a breakpoint inside a kernel to debug it, and whenever I run cuda-gdb and try to break in the kernel, my entire laptop freezes and crashes eventually. Before this happens however, I get several errors:
warning: Could not open OSO archive file “/BinaryCache/corecrypto/corecrypto-233.1.2~26/Symbols/BuiltProducts/libcorecrypto_static.a”
warning: `/BinaryCache/coreTLS/coreTLS-35.10.1~5/Objects/coretls.build/coretls.build/Objects-normal/x86_64/system_coretls_vers.o’: can’t open to read symbols: No such file or directory.
warning: Could not open OSO archive file “/BinaryCache/coreTLS/coreTLS-35.10.1~5/Symbols/BuiltProducts/libcoretls_ciphersuites.a”
warning: Could not open OSO archive file “/BinaryCache/coreTLS/coreTLS-35.10.1~5/Symbols/BuiltProducts/libcoretls_handshake.a”
warning: Could not open OSO archive file “/BinaryCache/coreTLS/coreTLS-35.10.1~5/Symbols/BuiltProducts/libcoretls_record.a”
warning: Could not open OSO archive file “/BinaryCache/coreTLS/coreTLS-35.10.1~5/Symbols/BuiltProducts/libcoretls_stream_parser.a”
I get similar results when trying to debug the program in NSight Eclipse Edition. The CUDA program runs fine if I run it without breakpoint, however I get a series of warnings as well, similar to above:
warning: /BinaryCache/cmph/cmph-1~1091/Objects/cmph.build/cmph.build/Objects-normal/x86_64/bdz.o': can't open to read symbols: No such file or directory. warning: /BinaryCache/cmph/cmph-1~1091/Objects/cmph.build/cmph.build/Objects-normal/x86_64/bdz_ph.o’: can’t open to read symbols: No such file or directory.
warning: /BinaryCache/cmph/cmph-1~1091/Objects/cmph.build/cmph.build/Objects-normal/x86_64/bmz.o': can't open to read symbols: No such file or directory. warning: /BinaryCache/cmph/cmph-1~1091/Objects/cmph.build/cmph.build/Objects-normal/x86_64/bmz8.o’: can’t open to read symbols: No such file or directory.
warning: /BinaryCache/cmph/cmph-1~1091/Objects/cmph.build/cmph.build/Objects-normal/x86_64/brz.o': can't open to read symbols: No such file or directory. warning: /BinaryCache/cmph/cmph-1~1091/Objects/cmph.build/cmph.build/Objects-normal/x86_64/buffer_entry.o’: can’t open to read symbols: No such file or directory.
warning: /BinaryCache/cmph/cmph-1~1091/Objects/cmph.build/cmph.build/Objects-normal/x86_64/buffer_manager.o': can't open to read symbols: No such file or directory. warning: /BinaryCache/cmph/cmph-1~1091/Objects/cmph.build/cmph.build/Objects-normal/x86_64/chd.o’: can’t open to read symbols: No such file or directory.
warning: /BinaryCache/cmph/cmph-1~1091/Objects/cmph.build/cmph.build/Objects-normal/x86_64/chd_ph.o': can't open to read symbols: No such file or directory. warning: /BinaryCache/cmph/cmph-1~1091/Objects/cmph.build/cmph.build/Objects-normal/x86_64/chm.o’: can’t open to read symbols: No such file or directory.
warning: /BinaryCache/cmph/cmph-1~1091/Objects/cmph.build/cmph.build/Objects-normal/x86_64/cmph.o': can't open to read symbols: No such file or directory. warning: /BinaryCache/cmph/cmph-1~1091/Objects/cmph.build/cmph.build/Objects-normal/x86_64/cmph_structs.o’: can’t open to read symbols: No such file or directory.
warning: /BinaryCache/cmph/cmph-1~1091/Objects/cmph.build/cmph.build/Objects-normal/x86_64/compressed_rank.o': can't open to read symbols: No such file or directory. warning: /BinaryCache/cmph/cmph-1~1091/Objects/cmph.build/cmph.build/Objects-normal/x86_64/compressed_seq.o’: can’t open to read symbols: No such file or directory.
warning: /BinaryCache/cmph/cmph-1~1091/Objects/cmph.build/cmph.build/Objects-normal/x86_64/fch.o': can't open to read symbols: No such file or directory. warning: /BinaryCache/cmph/cmph-1~1091/Objects/cmph.build/cmph.build/Objects-normal/x86_64/fch_buckets.o’: can’t open to read symbols: No such file or directory.
warning: /BinaryCache/cmph/cmph-1~1091/Objects/cmph.build/cmph.build/Objects-normal/x86_64/graph.o': can't open to read symbols: No such file or directory. warning: /BinaryCache/cmph/cmph-1~1091/Objects/cmph.build/cmph.build/Objects-normal/x86_64/hash.o’: can’t open to read symbols: No such file or directory.
warning: /BinaryCache/cmph/cmph-1~1091/Objects/cmph.build/cmph.build/Objects-normal/x86_64/jenkins_hash.o': can't open to read symbols: No such file or directory. warning: /BinaryCache/cmph/cmph-1~1091/Objects/cmph.build/cmph.build/Objects-normal/x86_64/linear_string_map.o’: can’t open to read symbols: No such file or directory.
warning: /BinaryCache/cmph/cmph-1~1091/Objects/cmph.build/cmph.build/Objects-normal/x86_64/miller_rabin.o': can't open to read symbols: No such file or directory. warning: /BinaryCache/cmph/cmph-1~1091/Objects/cmph.build/cmph.build/Objects-normal/x86_64/select.o’: can’t open to read symbols: No such file or directory.
warning: /BinaryCache/cmph/cmph-1~1091/Objects/cmph.build/cmph.build/Objects-normal/x86_64/vqueue.o': can't open to read symbols: No such file or directory. warning: /BinaryCache/cmph/cmph-1~1091/Objects/cmph.build/cmph.build/Objects-normal/x86_64/vstack.o’: can’t open to read symbols: No such file or directory.
warning: Could not open OSO archive file “/Volumes/Builds/nv/build/rel/gpu_drv/r346/r346_00/drivers/gpgpu/bin/310.41.15_mercury_x86_64_Darwin_release/libNVDAresmanAPI.a”
I can also run the CUDA samples which were prompted during the tutorial of setting up CUDA for Mac without any errors.
Does anybody know what is going on or how I can fix this issue?
Regards,
BananaCode
