Cuda-gdb on Mavericks
Does cuds-gdb work with Mac Desktop UI?
I have installed the newest cuda-mac-5.5.28_10.9_64 package.
When I try to test cuds-gdb bit reverse
(cuda-gdb) run
Starting program: /Users/baicai/Dropbox/GPU/CUDA/cuda_gdb test/bitreverse
warning: Could not open OSO archive file “/BinaryCache/Libsyscall/Libsyscall-2422.75.4~1/Symbols/BuiltProducts/libsystem_kernel.a”
warning: /private/var/tmp/Libsyscall/Libsyscall-2422.75.4~1/Libsyscall.build/Libsyscall_dynamic.build/Objects-normal/x86_64/_libc_funcptr.o': can't open to read symbols: No such file or directory. ... Breakpoint 1, main () at bitreverse.cu:23 23 unsigned int *d = NULL; int i; (cuda-gdb) continue Continuing. warning: /private/var/tmp/OSServices/OSServices-600.4~218/OSServices.build/OSServices.build/Objects-normal/x86_64/AppleIDAuthenticationClient.o’: can’t open to read symbols: No such file or directory.
warning: Could not open OSO archive file “/usr/local/UmbrellaPieces/Libraries/libSecurityCore.a”
[New Thread 0x1633 of process 499]
[Context Create of context 0x102802200 on Device 0]
A device about to be used for compute may already be in use for graphics.
This is an unsupported scenario. Further debugging might be unsafe. Aborting.
Disable the ‘cuda gpu_busy_check’ option to bypass the checking mechanism.
CUDA-GDB is supported on Mavericks.
Are those warning messages preventing you from debugging?
Are you using a beta version of Mavericks?
Thanks. These warnigns are fine, when I use console.
But when I debug in desktop, I got a message :
Is there a way I can debug on desktop or use nsight?
I am using 13 rmbp 15 with intel and nvidia GPU.
Debugging with the window server running (desktop) on Mac is only supported when the device is not used for graphics. This is what they debugger ‘cuda gpu_busy_check’ verifies. You can override it at your own risks. If the device is used for display, hitting a breakpoint in your cuda application will freeze the display.
To help mitigate the problem, you can try to:
  • disable any form of hardware acceleration
  • do not use anything openGL and the like
  • disable Automatic Graphics Switching in the System Settings->Energy Saver tab.
Some more information can be found at http://docs.nvidia.com/cuda/cuda-gdb/index.html#single-gpu-debugging
