Output Display Wait Time - Multi-streaming Dtection and Tracking in DeepStream Python
Thank you for your response @yingliu .
Model-engine-file is set in my config.
As you can see from the screenshot below. On the Left side, is my directory with the model-engine-file model_b1_gpu0_fp32.engine and, on the Right side, is my config file where I have mentioned the name of the model (highlighted).
Also, I want to convey that, this much wait time is not there when I run this program for a single stream.
But when more than one stream is given via the command line, only then do I witness this wait time or delay in the visualization of the output display.
